Dell Latitude 3420 Bios Password unlock
  • djesoric
    • Apr 2010
    • 28
    • Philippines
    #121
    thanks for this, laptop is working without password but absolute is still enabled.
      • 22030
      try
      • fonerangemalolos
        • Sep 2016
        • philippines
        #123
        hi can i request this bios password be removed? thanks in advance...
        UNIT: DELL 3420
        ST: B0J9SL3
        REQUEST: ADMIN REMOVE
        • minhdigital
          • Nov 2022
          • 765
          • Vietnam
          #124
          UNIT: DELL 3420
          ST: B0J9SL3
          Try
          • Integra
            • Mar 2017
            • 17
            • Croatia
            #125
            hello dell latitude 3420, i need bios admin password unlock, cant change boot menu and reinstall laptop. tnx in advance
            Also one question, from my dump You just remowe password, what about sn key and mac address
            ST: FHP0NG3
            • shiyab
              • Sep 2023
              • 1626
              • india
              #126
              ST: FHP0NG3
              hi try and feedback
              • Integra
                • Mar 2017
                • 17
                • Croatia
                #127
                Originally posted by shiyab
                hi try and feedback
                hi "we have a picture " tnx man
                • Integra
                  • Mar 2017
                  • 17
                  • Croatia
                  #128
                  ps, is there any info where I can learn to remove passwords from my dumps? tnx I m new here so dont be angry if I ask something that is maybe not allowed, sry in advance.
                  • babydoll8867
                    • Nov 2014
                    • 94
                    • romania
                    #129
                    can you help me unlock BIOS and disable Absolute for this Dell Latitude 3420 st:F3C8PG3,
                    thanks in advance!
                    • rex98
                      • Feb 2023
                      • 1293
                      • Mandaue CEBU, Philippines
                      #130
                      thanks in advance!
                      here
                      • babydoll8867
                        • Nov 2014
                        • 94
                        • romania
                        #131
                        Originally posted by rex98
                        here
                        Thank you very much, it worked!
                        • QK Hafeez
                          • Apr 2024
                          • 71
                          • South Africa
                          #132
                          DELL LATITUDE 3420 UNLOCK ADMIN PASSWORD PLZ
                            • 22030
                            Please post the service tag, it is required. Your backup is not good it should be around 9-10MB compressed whereas yours is only 405KB .
                            • QK Hafeez
                              • Apr 2024
                              • 71
                              • South Africa
                              #134
                              SERVICE TAG 85119S3
                              THIS FILE IS 32MB PLZ USE WINRAR
                                • 22030
                                SERVICE TAG 85119S3
                                I use 7-zip and winrar, i know how to use both. I`ve already told you your backup is bad. Open the bios with a hex editor and look at it, it`s mostly FF`s which means its mostly empty.
                                https://www.badcaps.net/forum/troubl...21#post1622421
                                When flashing a BIOS always make a backup first. Take 2 or 3 different dumps and make sure they are identical.
                                On Windows, you can use the command "fc /b" to check if two dumps are identical.
                                Make sure that the dumps looks good, i.e. not filled with 0x00 or 0xFF. After compression, if the file has a size of only a few kilobytes, the EEPROM was most likely not read properly.
                                Additionally, please read the FAQ at: https://www.badcaps.net/forum/showthread.php?t=98665
                                I assume you`re using a clip and it didn`t have a good connection.
                                • QK Hafeez
                                  • Apr 2024
                                  • 71
                                  • South Africa
                                  #136
                                  Ops
                                  i have empty chip already any other way sir , i thought backup is done lol
                                    • 22030
                                    Ops
                                    What do you mean its empty, have you erased it. If you havn`t erased it just make another backup. What programmer and software version are you using, are you using a clip and if so what type, is the chip type SOP8 or WSON8 , is the chip in the programmer support list , did you use Auto-detect or choose the chip manually.
                                    • QK Hafeez
                                      • Apr 2024
                                      • 71
                                      • South Africa
                                      #138
                                      SIR I AM USING RT809F BOX AND WHEN I MADE MACKUP AFTER THAT I HAVE erased BUT FILE THAT WAS BACKUP WAS EMPTY . NOW I HAVE RESTORE THAT FILE TO CHIP BUT LAPTOP NOT TRUNING SO I THING ORG BIN FILE IS erased
                                      NOW I AM SITING WITH NO ORG BACKUP FILE
                                      • kain0007
                                        • Jan 2017
                                        • 14
                                        • México
                                        #139
                                        Hello friends, could someone help me with this file? has password+absolute.
                                        I will thank you very much.
                                        DELL LATITUDE 3420
                                        SERVICE TAG: B7Z2VG3
                                        213105-2 CYBORG-L14 MB TGL​
                                        • volinakis
                                          • Jan 2021
                                          • 2874
                                          • N/A
                                          #140
                                          DELL LATITUDE 3420
                                          try
                                          • Godfather79
                                            Dell Latitude 5520 3FE2 Bios password Unlock Request (TGL SuothPeak15)
                                            by Godfather79
                                            Hello everyone in the community
                                            Dear Sir,
                                            I need help removing/unlocking the BIOS Service Tag password on my Dell Latitude 5520 laptop.
                                            Problem details:
                                            * Model: Dell Latitude 5520.
                                            * Board ID (from BIOS file): TGL MB 8L 19819-1 (Southpeak15).
                                            * Required Password Code: 3FE2 (BIOS Service Tag Lockout Code).
                                            * Service Tag: (Enter your actual Service Tag from the laptop here)
                                            * ​BIOS Status: I successfully modded the BIOS file and created FINAL_CLEANED_ME.bin (32MB) with a clean ME region (CSME 15.0), because the original dump was corrupt....
                                            Today, 10:04 AM
                                          • Akhlz001
                                            by Akhlz001
                                            09-20-2025, 07:15 PM
                                          • gizaha
                                            by gizaha
                                            02-13-2024, 07:18 AM
                                          • Jeff'sTech
                                            Dell Latitude 7420 BIOS Unlock Gone Wrong
                                            by Jeff'sTech
                                            Hello everyone.
                                            I have come here with a rather specific question. I was given a Dell Latitude 7420 laptop with a busted screen, and wanted to see if I could refurbish it into my daily driver. I wanted to experiment and see if a 2-in-1 display would work as the chassis of the laptop and 2-in-1 7420 looked identical. I threw in the display and my hypothesis was correct, however, I was greeted with a locked BIOS and since I didn't know the password, I figured I'd try to unlock it somehow. I bought one of those POGO pin probe things for my CH341A programmer so I could read and make...
                                            11-08-2023, 03:30 PM
                                            DELL Latitude 3420 Notebook 3000 Specification for Upgrade or Repair
                                            This specification for the DELL Latitude 3420 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 3420 boardview and 3420 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude 3420...
                                            09-07-2024, 01:30 AM
