Dell Latitude 3420 Bios Password unlock
remove Cmos battery and main battery before writing bios chipset, then reconnect both, plug in ac adapter and start laptop from power button. At 1st boot press F2 and write service tag, permanently disable absolute, save (apply changes), restart, press Alt+F to exit from factory mode.----------------------------------------------------------------------------------------------------------------------------------------------------------------------
----------------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
I apologize, I wasn't careful to check my keyboard and just typed. I didn't notice. I regret this mistake, I hope it is not repeated later. I very much appreciate the support from all of you. It was just a distraction error.
Same result. Absolute is still present. and when I put the service tag and restart it no longer turns on.Comment
Hey Bios Cracker
Unfortunately, I can’t provide the BIOS dump file right now because I’ve lost admin access and I’m unable to extract the dump from the system without it. is there’s any alternative method ? (I have OS access)Comment
You must have a programmer to do this. The cheapest one is ch341a.Hey Bios Cracker
https://www.youtube.com/results?sear...mer+how+to+use↵
https://www.badcaps.net/donateComment
Hi, I have a Dell Latitude 3420 with eprom model GIGADEVICE 25R256DYIG and I try dump Bin file with a programmer CH341 but the software doesn't recognize the chip. I tried with and without voltage adapter for 1.8V.
I tried several Softwares versions, but these doesn't works.
Anyone has some ideia why this doesn't work? I read some papers saying that the programmer CH341 doesn't support this eprom 25R256DYIG.
I appreciate any help!
Thanks.Comment
hello everyone i need also admin password to be unlocked
thank you..
https://www.mediafire.com/file/npegt...+3420.bin/file
no attach file link other , use forum toolshello everyone i need also admin password to be unlocked
thank you..
https://www.mediafire.com/file/npegt...+3420.bin/fileComment
ok sir it was hard uploading using the tool but here it is..
Attached FilesComment
sorry the chip was not supported on my reader
so i tried again
st DSSJBS3Attached FilesComment
try and feedbackAttached FilesComment
I need an unprotected bios. Mine is protected with pwd at stratup FDCHHG3-0001. Could you please provide me an unlocked bios with no passWord and with Absolute disabled ?
dell latitude 3420 S/N: FDCHHG3
ThankAttached FilesComment
tryAttached FilesComment
in the same way, could you please unlock this one ?Attached FilesComment
by Godfather79Hello everyone in the community
Dear Sir,
I need help removing/unlocking the BIOS Service Tag password on my Dell Latitude 5520 laptop.
Problem details:
* Model: Dell Latitude 5520.
* Board ID (from BIOS file): TGL MB 8L 19819-1 (Southpeak15).
* Required Password Code: 3FE2 (BIOS Service Tag Lockout Code).
* Service Tag: (Enter your actual Service Tag from the laptop here)
* BIOS Status: I successfully modded the BIOS file and created FINAL_CLEANED_ME.bin (32MB) with a clean ME region (CSME 15.0), because the original dump was corrupt....-
Channel: BIOS Requests ONLY!
by Akhlz001Hi,
Could someone help trying to unlock this BIOS, seems that Dell have changed the layout of new Dell Pro 8FC8 bioses from checking HXD - 4000 bits do not need changing, only 2000. However after FF the section starting from '01000' upto 2000 bits and then soldering the chip back it seems that the microchip on the motherboard is recovering the bios back to original settings after first boot. Has anyone found a way to crack this extra layer of security Dell have implemented? Seems both HP and Dell have upped bios security to match Lenovo by implementing extra measures on a separate...-
by gizahaDell latitude 5580, motherboard cdp 80 la-e151p
Since ssd is replaced and had clean install windows, i've... -
by Jeff'sTechHello everyone.
I have come here with a rather specific question. I was given a Dell Latitude 7420 laptop with a busted screen, and wanted to see if I could refurbish it into my daily driver. I wanted to experiment and see if a 2-in-1 display would work as the chassis of the laptop and 2-in-1 7420 looked identical. I threw in the display and my hypothesis was correct, however, I was greeted with a locked BIOS and since I didn't know the password, I figured I'd try to unlock it somehow. I bought one of those POGO pin probe things for my CH341A programmer so I could read and make... -
This specification for the DELL Latitude 3420 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 3420 boardview and 3420 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude 3420...09-07-2024, 01:30 AM
- Loading...
