Lenovo Ideapd 5-15ITL05 Bios request
  • alfredosn
    • Jun 2016
    • 19
    • México
    Hello friens , i have a Lenovo Ideapd 5 15ITL05 wont charge battery, so i have these escenarys
    laptop with battery and charger plugged.... laptop power on but wont charge battery and no detect the ac adapter
    laptop only with ac adapter plugged .... laptop power on but wont charge battery and obvuisly no detect the battery
    laptop only with the battery plugged .... laptop power on but wont charge battery and obvuisly no detect the ac adapter
    does somebody has a working bios dump for this laptop, the MB is NM-D211 Rev 1.0
  • Mazorca
    • Jan 2017
    • 463
    Re: Lenovo Ideapd 5 15ITL05 Bios request
    Post your old BIOS backup, I will clean the ME Region to see if that helps. Do three readings.
    • IDislikemakingLogins
      • Feb 2017
      • 38
      • moon
      Have a dead unit in atm... someone has done work to it and have removed replaced the bios chips and the ec. so not sure the state of this dump... this system seams to have a dead smc chip. this board dose not have the video chip populated
      15ITL05 type 82fg
      • alfredosn
        • Jun 2016
        • 19
        • México
        15ITL05 type 82fg
        Hi friend. do you know, what chip is the main bios? this mb has 3 bios chips
        • Mazorca
          • Jan 2017
          • 463
          Usually the largest has the main bios, but do make a reading of all three, sometimes ec comes in 32MB and main in 32MB too. Someone here will figure them out. Best is to look at the schematics if you have them.
            • Feb 2017
            • 38
            • moon
            From what i can tell the ub2 1mb one is for the usb3 retimer
            the uc704-uc703 8mb has the me and discriptor
            theuc702 16mb has the uefi
            depending on the fault i have had luck just doing the uefi 16mb chip but its usily best to do both the 16mb and the 8mb.
            ignore the 1mb unless having usbc problems.
            Im prity shure they combine the 8mb and 16mb chips.... i still dont know why they do it that way meby its cost cutting
            • teto8485
              • Nov 2016
              • 64
              • egypt
              lenovo Flex 5-14ITL05 LC56-14T 203013-1 bios
              need to fix this bios plz
                • 22119
                Re: lenovo Flex 5-14ITL05 LC56-14T 203013-1 bios
                Serial number ? ,Model Type ?
                • teto8485
                  • Nov 2016
                  • 64
                  • egypt
                  Re: Lenovo IdeaPad Flex 5 14ITL05 bios dump
                  ok
                  • hardware1
                    • Sep 2021
                    • 2949
                    • N/A
                    Here's your new file, try it and let me know.
                    all donations are welcome,
                    • teto8485
                      • Nov 2016
                      • 64
                      • egypt
                      no power not working i try an other one working but didnot read m2 hdd plz hellp old bin no data the oreginal bin
                        • 22119
                        ok
                        As its a 5-15ITL05 and not a 5-14ITL05 your posts have been moved to a 5-15ITL05 thread.
                        Different Model Types can have different bios versions ! You can find which bios version you need by entering the laptop serial at Lenovo support,then looking at the bios update version number.You can check that number by looking at your own backup with a hex editor,and searching for the same FXCN .If you ask for more help in future it does save us time if you post the serial and/or the model type
                        try this one
                        • hackymc
                          • Feb 2017
                          • 33
                          • Romania
                          Need Bios Lenovo Ideapad 15 15itl05
                          Hello everyone, i need a dump for this model if somebody have.
                          Mine laptop turn on, no fan spin, and black screen.
                          This is the dump
                          • hardware1
                            • Sep 2021
                            • 2949
                            • N/A
                            Re: Need Bios Lenovo Ideapad 15 15itl05
                            This is the dump
                            You should have another chip, it must be 16MB.
                            • hackymc
                              • Feb 2017
                              • 33
                              • Romania
                              First dump is from Winbound chip , i made a dump from this now XM25QH128A.
                              I will attach dump here. Thanks
                              • hardware1
                                • Sep 2021
                                • 2949
                                • N/A
                                Here's your new files, try them and let me know.
                                • elbostan
                                  EL.BOSTAN TEAM
                                  • Apr 2012
                                  • 30
                                  • egypt
                                  this is factory file 8m and 16m
                                  give me report please
                                  • ravenmx
                                    • May 2018
                                    • 180
                                    • puebla
                                    thanks your bios works , whit others no detec m2,... your bios factory ok thanks you
                                    • drorleb
                                      • Feb 2023
                                      • israel
                                      hello i cant find the 16mb chip , can someone uplode a picture where is it?
                                      i found the 8mb chip but not the 16mb
                                      • Geoffreynt
                                        • Jul 2022
                                        • Zambia
                                        uc702
                                        • lucaszmn
                                          by lucaszmn
                                          Problem:
                                          Initial Findings:
                                          • I concluded that the
                                          08-12-2025, 03:01 PM
                                        • Wahaz
                                          by Wahaz
                                          10-30-2023, 08:42 PM
                                        • grimacelord
                                          Lenovo Legion T5-26AMR5 Desktop - Corrupt BIOS
                                          by grimacelord
                                          Hello there.
                                          I am working on a Lenovo Legion T5-26AMR5 desktop that currently has a corrupt BIOS and I have been unsuccessful thus far in trying to fix it myself.
                                          History:
                                          1. This computer came to me initially with an error message that said "BiInitializeLibrary failed 0xc0000001" or "0135 fan error". It would always be one of the two errors. It should be noted that when it produced the fan error, there was no physical problem with the fans. They were all spinning just fine.
                                          I searched for this error online and discovered...
                                          03-15-2023, 03:29 PM
                                        • to5it0
                                          Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e 2H1703-27220F Rev. A Marked as U2501 on the motherboard.
                                          by to5it0
                                          Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
                                          I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
                                          This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
                                          I have opened the laptop and identified the main BIOS chip...
                                          10-24-2025, 01:35 AM
                                        • mkdj
                                          Lenovo IdeaPad 3 - Hard Disk not recognized in BIOS
                                          by mkdj
                                          Dear all,
                                          I have recently fixed a Lenovo IdeaPad 3 15 ALC6 that was not booting due to a BIOS issue. After flashing the BIOS, the laptop boots up, but hard disk is not recognized in BIOS. Is says "Hard Disk : Not Installed". I have tried with 2 different drives (one that I know is working on another laptop) but I get the same result. I do not know if disks were recognized before I got the laptop and fix it, but I don't see any reason why not. I can boot on USB though.
                                          Here the steps I have taken to fix the laptop:
                                          - downloaded latest BIOS from Lenovo Website...
                                          10-18-2025, 03:43 AM
