On Board Ram Disable via Bios Editing
Asus X513ean has an onboard ram error, I tried to delete the ram with SPD v1.7 but failed, I even deleted and added an external ram code but still failed. I programmed the bios of X515EA, the machine displays but does not recognize NVME and only recognizes external ram.
Information:
- Asus X513EAN REV 5.3
- SN: MAN0CV12674042B
- Original X513EAN BIOS is attached below.
- X515EA BIOS displays but does not recognize NVME attached below.
Attached Filesif you find these attachements useful please consider making a small donation to the site
@toannh92it, compare this file with SPD v1.7 one, if it's different, try it, and report result please.
Please help disable on board ram for
Asus Vivobook 15 X1504Z-NJ972W
BOARD X1404ZA R3.0
SN S5N0CX07K58421A
ThanksAttached Filesif you find these attachements useful please consider making a small donation to the site
Thank you, I tried with SDP 1.6 and 1.7, but the device posted the 0.7xx amp line and then turned off again. I tried programming the bios of the a515ea and the device showed a good image, only recognizing the removable ram, but not nvme.@toannh92it, compare this file with SPD v1.7 one, if it's different, try it, and report result please.
I tried replacing the entire profile of a515 with x513 but the status is still the same as above.Comment
no ram original & no ram clearme
There should be a QR code on the motherboard similar to this https://www.badcaps.net/filedata/fetch?id=3528659 ,scan it .The model number in the scan is the bios version you want.
Support me to rebuild it, please. It turns on without an image.
Marca: ASAP
Modelo:
BOARD: JOYARD4_J_X133S_V10 2020216 r1
SN: 1404824348958
Thank youAttached Filesif you find these attachements useful please consider making a small donation to the site
bạn làm được vui lòng cho mình xin file x513ea noramAsus X513ean has an onboard ram error, I tried to delete the ram with SPD v1.7 but failed, I even deleted and added an external ram code but still failed. I programmed the bios of X515EA, the machine displays but does not recognize NVME and only recognizes external ram.
Information:
Type the laptop serial number
read the forum rules..https://www.badcaps.net/forum/troubl...before-posting
Sorry for the inconvenience ,here is the serial number of the machine .please help ,thank you
Type the laptop serial number M7N0CV10H472284Comment
If the ram is ddr4 try the macro script patcher https://www.badcaps.net/forum/troubl...20#post3232220 .Alternatively search the internet for SPD removal tool. If it doesn`t boot after patching the ram flash your old bios back .Disabling by hardware might be one option, check the forum posts.
Please send me a Bios without RAM for:
Lenovo V15-ADA
Model Name: 82C7
SN: PF22HLR3
MTM: 82C70005GE
Cheers
Patch your own bios backup , try the script patcher https://www.badcaps.net/forum/troubl...20#post3232220Comment
Hello, please could you please disable the ram?
Thank you very much
Lenovo V15 G2 ALC (HV461&HV561 NM-D522 Rev: 2.0)
by piratiHello everyone,
I decided to try flashing a new BIOS, but since I didn’t want to desolder...-
Channel: BIOS Requests ONLY!
by grimacelordHello,
Anyway, I took dumps of both chips and then downloaded the latest update for this motherboard from ASUS's website...-
by DynaxSCHi, I have an MSI PRO B660M-G DDR4 board with damaged BIOS and i need a bios dump from a real board, along with MAC, UUID and Serial Number info (eg. a BIOS screenshot and pictures from the board stickers).
I need to reconstruct the bios on my board, based on another bios image form a real board - meaning a bios image containing MAC address, UUID and Serial number. A stock BIOS is not suffiecient, as it is impossible to discover where the MAC, UUID and SerialNumber are stored. Tried with a similar board, but there are too much differences, and the stock BIOS is missing a lot of...11-17-2023, 10:56 AM -
by jbonavitaHi, my laptop wont boot at all
Some issues
Things I tried
1- Update / clear ME: Took the non working bios, made a backup, and did this: https://www.badcaps.net/forum/troubl...theory/trouble...-
by throwaway327ASUS ROG Ally X - (Handheld Gaming PC)
Model No: RC72LA
Serial No: SBNVKD001014459
I used a tool called 'Smokeless-UMAF' to access usually hidden settings in the bios. I tweaked one or two 'safe' things but made the mistake of tweaking a lot of settings under 'USB/Thunderbolt Configurations' when I didn't know what they did. For...-
- Loading...
