On Board Ram Disable via Bios Editing
Asus X513ean has an onboard ram error, I tried to delete the ram with SPD v1.7 but failed, I even deleted and added an external ram code but still failed. I programmed the bios of X515EA, the machine displays but does not recognize NVME and only recognizes external ram.
Information:
- Asus X513EAN REV 5.3
- SN: MAN0CV12674042B
- Original X513EAN BIOS is attached below.
- X515EA BIOS displays but does not recognize NVME attached below.
@toannh92it, compare this file with SPD v1.7 one, if it's different, try it, and report result please.
Attached FilesComment
Please help disable on board ram for
Asus Vivobook 15 X1504Z-NJ972W
BOARD X1404ZA R3.0
SN S5N0CX07K58421A
ThanksAttached FilesComment
Thank you, I tried with SDP 1.6 and 1.7, but the device posted the 0.7xx amp line and then turned off again. I tried programming the bios of the a515ea and the device showed a good image, only recognizing the removable ram, but not nvme.@toannh92it, compare this file with SPD v1.7 one, if it's different, try it, and report result please.
I tried replacing the entire profile of a515 with x513 but the status is still the same as above.Comment
no ram original & no ram clearme
There should be a QR code on the motherboard similar to this https://www.badcaps.net/filedata/fetch?id=3528659 ,scan it .The model number in the scan is the bios version you want.
Support me to rebuild it, please. It turns on without an image.
Marca: ASAP
Modelo:
BOARD: JOYARD4_J_X133S_V10 2020216 r1
SN: 1404824348958
Thank youComment
bạn làm được vui lòng cho mình xin file x513ea noramAsus X513ean has an onboard ram error, I tried to delete the ram with SPD v1.7 but failed, I even deleted and added an external ram code but still failed. I programmed the bios of X515EA, the machine displays but does not recognize NVME and only recognizes external ram.
Information:
by piratiHello everyone,
I decided to try flashing a new BIOS, but since I didn’t want to desolder...-
Channel: BIOS Requests ONLY!
by grimacelordHello,
Anyway, I took dumps of both chips and then downloaded the latest update for this motherboard from ASUS's website...-
by DynaxSCHi, I have an MSI PRO B660M-G DDR4 board with damaged BIOS and i need a bios dump from a real board, along with MAC, UUID and Serial Number info (eg. a BIOS screenshot and pictures from the board stickers).
I need to reconstruct the bios on my board, based on another bios image form a real board - meaning a bios image containing MAC address, UUID and Serial number. A stock BIOS is not suffiecient, as it is impossible to discover where the MAC, UUID and SerialNumber are stored. Tried with a similar board, but there are too much differences, and the stock BIOS is missing a lot of...11-17-2023, 10:56 AM -
by jbonavitaHi, my laptop wont boot at all
Some issues
Things I tried
1- Update / clear ME: Took the non working bios, made a backup, and did this: https://www.badcaps.net/forum/troubl...theory/trouble...-
by throwaway327ASUS ROG Ally X - (Handheld Gaming PC)
Model No: RC72LA
Serial No: SBNVKD001014459
I used a tool called 'Smokeless-UMAF' to access usually hidden settings in the bios. I tweaked one or two 'safe' things but made the mistake of tweaking a lot of settings under 'USB/Thunderbolt Configurations' when I didn't know what they did. For...-
- Loading...
