On Board Ram Disable via Bios Editing
  • Loami Souza
    • Apr 2025
    • 4
    • Brasil
    #401
    Can anyone help me to disable the onboard RAM?
    MODEL: Asus X515EA
    S/N : R6N0B601300925C
    • peste
      • Dec 2016
      • 12718
      • ROMANIA
      #402
      MODEL: Asus X515EA
      you posted the update on the site..did you look at it??is it ok???did you compare it with your original bios???
      why don't you post the original bios??
      • Loami Souza
        • Apr 2025
        • 4
        • Brasil
        #403
        hello Peste, this is the original BIOS from the ASUS website, I have already tested it on my laptop.​
        Link: https://www.asus.com/laptops/for-hom...me=ASUS-X515EA
        • f@brice
          • Nov 2019
          • 65
          • France
          #404
          peste, is it ok for you to answer ?
          • peste
            • Dec 2016
            • 12718
            • ROMANIA
            #405
            did you install it from the stick??if it works then why do you want to disable the onboard ram memory?..
            I'm just curious..or did I not understand what you want to do???
            • Loami Souza
              • Apr 2025
              • 4
              • Brasil
              #406
              Yes, I can, but the integrated RAM is showing errors and corrupting data when I start the laptop. To make sure that the problem was the integrated RAM, I removed the memory that was in the slot and ran a memtest, and it shows several memory errors. It becomes unstable at various times.
              ​So I want to disable the integrated RAM and use only the memory that is in the slot.
              • peste
                • Dec 2016
                • 12718
                • ROMANIA
                #407
                try..
                • Loami Souza
                  • Apr 2025
                  • 4
                  • Brasil
                  #408
                  try..
                  Unfortunately it didn't work, when I try to update it shows the error "Selected file is not a UEFI BIOS!". I've tried everything I found on the internet, it accepts the original BIOS. I'm going to buy a BIOS burner to see if it works with this file. Thank you for your support.​
                  • f@brice
                    • Nov 2019
                    • 65
                    • France
                    #409
                    the bios file size seems to not be good, 19Mo.
                    • Valiumpill
                      • Jan 2020
                      • 5
                      • Uruguay
                      #410
                      To whom it may concern:
                      Attached, you will find the original bios dump.
                      This is a ASUS K501L.
                      SERIAL: F6N0CX060983235
                      MOTHERBOARD PART NUMBER: K501LX REV 2.0.
                      Onboard ram disable, would be really apreciated.
                      Thank you all guys!!!
                      • f@brice
                        • Nov 2019
                        • 65
                        • France
                        #411
                        your bios file seems to be corrupted, uefitool confirm.
                        Did you use clip to extract it?
                        • Valiumpill
                          • Jan 2020
                          • 5
                          • Uruguay
                          #412
                          You are right. my bad.
                          Here is the other functiona bin.
                          Thanks again fellow
                          • f@brice
                            • Nov 2019
                            • 65
                            • France
                            #413
                            Thanks again fellow
                            Try and reply please
                            • Valiumpill
                              • Jan 2020
                              • 5
                              • Uruguay
                              #414
                              It worked!
                              Any paypal account so i cand send grattitude?
                              • f@brice
                                • Nov 2019
                                • 65
                                • France
                                #415
                                happy for you.
                                yes of course ;-)
                                support@badcaps.net
                                everybody will profite.
                                • Valiumpill
                                  • Jan 2020
                                  • 5
                                  • Uruguay
                                  #416
                                  I though it worked. Laptop turns on and 20 secconds latter, it turns off. even in bios. any idea?
                                  • f@brice
                                    • Nov 2019
                                    • 65
                                    • France
                                    #417
                                    no idea, sorry.
                                    • josimuddin
                                      • Jul 2024
                                      • bangladesh
                                      #418
                                      Hello Guys,
                                      i Need On Board Ram Disable Bios Bin.
                                      i have OLD Bios.
                                      Laptop Model: asus x540ubr rev 2.0
                                    • jhuztine2881
                                      • 34
                                      • Philippines
                                      #419
                                      i need bin for ideapad s145 nm-c121 ram disabled on board.
                                      orig bin files attached.
                                      • danito
                                        • Jun 2016
                                        • 899
                                        • Romania
                                        #420
                                        no ram
                                        • grimacelord
                                          by grimacelord
                                          07-10-2025, 02:52 PM
                                        • throwaway327
                                          by throwaway327
                                          Model No: RC72LA
                                          Serial No: SBNVKD001014459
                                          06-18-2025, 05:52 PM
                                        • DynaxSC
                                          by DynaxSC
                                          11-17-2023, 10:56 AM
                                        • jbonavita
                                          by jbonavita
                                          Some issues
                                          Things I tried
                                          04-29-2025, 09:38 PM
