On Board Ram Disable via Bios Editing
  • Maxpower3
    Bad Veteran
    • Feb 2018
    • 1356
    • France
    #561
    Originally posted by rena629
    I've already tried BIOS Memory SPD Removal Tool 1.6
    it is not this program but identical result
    • toannh92it
      • Oct 2021
      • 9
      • Viet Nam
      #562
      Asus X513ean has an onboard ram error, I tried to delete the ram with SPD v1.7 but failed, I even deleted and added an external ram code but still failed. I programmed the bios of X515EA, the machine displays but does not recognize NVME and only recognizes external ram.
      Information:
      - Asus X513EAN REV 5.3
      - SN: MAN0CV12674042B
      - Original X513EAN BIOS is attached below.
      - X515EA BIOS displays but does not recognize NVME attached below.
      • f@brice
        • Nov 2019
        • 78
        • France
        #563
        @toannh92it, compare this file with SPD v1.7 one, if it's different, try it, and report result please.
        • AlfredoHdez
          • Apr 2022
          • 7
          • México
          #564
          Please help disable on board ram for
          Asus Vivobook 15 X1504Z-NJ972W
          BOARD X1404ZA R3.0
          SN S5N0CX07K58421A
          • toannh92it
            • Oct 2021
            • 9
            • Viet Nam
            #565
            Thank you, I tried with SDP 1.6 and 1.7, but the device posted the 0.7xx amp line and then turned off again. I tried programming the bios of the a515ea and the device showed a good image, only recognizing the removable ram, but not nvme.
            I tried replacing the entire profile of a515 with x513 but the status is still the same as above.
            • toannh92it
              • Oct 2021
              • 9
              • Viet Nam
              #566
              BOARD X1404ZA R3.0
              SN S5N0CX07K58421A
              no ram original & no ram clearme
                • 21984
                There should be a QR code on the motherboard similar to this https://www.badcaps.net/filedata/fetch?id=3528659 ,scan it .The model number in the scan is the bios version you want.
                • AlfredoHdez
                  • Apr 2022
                  • 7
                  • México
                  #568
                  • AlfredoHdez
                    • Apr 2022
                    • 7
                    • México
                    #569
                    Support me to rebuild it, please. It turns on without an image.
                    Marca: ASAP
                    Modelo:
                    BOARD: JOYARD4_J_X133S_V10 2020216 r1
                    SN: 1404824348958
                    ​​​​​​Thank you
                    • Nguyễn vy
                      • Mar 2023
                      • Việt nam
                      #570
                      Information:
                      bạn làm được vui lòng cho mình xin file x513ea noram
                      • danito
                        • Jun 2016
                        • 1101
                        #571
                        english only
                        • pirati
                          by pirati
                          10-27-2025, 04:20 PM
                        • grimacelord
                          by grimacelord
                          07-10-2025, 02:52 PM
                        • DynaxSC
                          by DynaxSC
                          11-17-2023, 10:56 AM
                        • jbonavita
                          by jbonavita
                          Some issues
                          Things I tried
                          04-29-2025, 09:38 PM
                        • throwaway327
                          by throwaway327
                          Model No: RC72LA
                          Serial No: SBNVKD001014459
                          06-18-2025, 05:52 PM
