On Board Ram Disable via Bios Editing
  • eltunisie
    • Apr 2018
    • 15
    • english
    #521
    Him would you please disable onboard ram of this model
    Model: Lenovo ideapad 3-14ITL6
    MB: hs460-hs560 nm-d472 rev:2.0
      • 21984
      Files should be attached to your post in a zip or rar. Read the post above yours, you can try using the ram disable script.
      • eltunisie
        • Apr 2018
        • 15
        • english
        #523
        IAM SORRY MY BROTHER
        i edit my post and upload attachments
        • f@brice
          • Nov 2019
          • 78
          • France
          #524
          Try and report, please
          • eltunisie
            • Apr 2018
            • 15
            • english
            #525
            working no display
            • eltunisie
              • Apr 2018
              • 15
              • english
              #526
              THANKS LONG TIME ANG FINAL GOOD WORK
              • Jon397
                • May 2025
                • russiya
                #527
                Please help me disable RAM
                Model: Lenovo IdeaPad 3-17ITL6 Laptop - Type 82H9
                MB: hs460 hs560 hs760 nm-d471 rev:2.0
                I'm uploading my bios backup
                Disable RAM.mps writes error
                  • 21984
                  The bios is split across 2 chips, 8MB and 16MB. Try again with the 16MB bios
                  • Jon397
                    • May 2025
                    • russiya
                    #529
                    I need to dump another chip that is 16mb ?
                      • 21984
                      Yes
                      • Jon397
                        • May 2025
                        • russiya
                        #531
                        Yes
                        I took a backup of the bios 16mb and processed it through Disable RAM.mps. The laptop still doesn't display anything, but the processor has started to heat up. Previously, it was cool, and the power button indicator is still flashing.Below is the bios that I removed from my laptop. It has not been edited.
                        • f@brice
                          • Nov 2019
                          • 78
                          • France
                          #532
                          Not sure it's better, but you can compare with the one you modified.
                          • Jon397
                            • May 2025
                            • russiya
                            #533
                            Unfortunately, it didn't produce the desired result either.
                            • Valiumpill
                              • Jan 2020
                              • 6
                              • Uruguay
                              #534
                              Hello guys. x415ea turns of after 2 seconds. I hope that disabling ram, works again. Here ius the archive.
                              Hope you can disable it. thanks a lot
                                • 21984
                                Post the laptop serial number and Try the ram disable script - https://www.badcaps.net/forum/troubl...20#post3232220
                                • BOGOSY77
                                  • Aug 2018
                                  • 57
                                  • PITON
                                  #536
                                  Hello friends,
                                  Can you disable on board ram on this bios?
                                  I send you my bios to edit.
                                  Lenovo Think book yoga 14s G2 IAP
                                  S/N: MP2EYMLA
                                  Lenovo HLXA4 LA-L931P Rev:1A bios
                                  Thank you.
                                  • peste
                                    peste commented
                                    Editing a comment
                                    post moved...next time look for a thread with the name and model, motherboard model of the laptop, and post there, if you can't find it, then make a new thread..
                                • peste
                                  • 13661
                                  • ROMANIA
                                  #537
                                  Originally posted by BOGOSY77
                                  Hello friends,
                                  S/N: MP2EYMLA
                                  Thank you.
                                  try..
                                  • BOGOSY77
                                    • Aug 2018
                                    • 57
                                    • PITON
                                    #538
                                    Hello, No power with this bios.
                                    Does I need to remove the soldered Ram on board prior flash this bios?
                                    Thanks,
                                    • LBTT1121
                                      • Nov 2024
                                      • 1062
                                      • Việt Nam
                                      #539
                                      Hello friends,
                                      S/N: MP2EYMLA
                                      Thank you.
                                      try
                                      • uranus
                                        Just a humanoid
                                        • Sep 2014
                                        • 21
                                        • Israel
                                        #540
                                        please kindly disable on board ram
                                        Thinkbook 14 G2 ITL
                                        MB: FLV34 LA-K051P REV 1B
                                        SNID: MP23GC07
                                        • peste
                                          peste commented
                                          Editing a comment
                                          post merged...next time look for a thread with the name and model, motherboard model of the laptop, and post there, if you can't find it, then make a new thread..
                                      • pirati
                                        by pirati
                                        10-27-2025, 04:20 PM
                                      • grimacelord
                                        by grimacelord
                                        07-10-2025, 02:52 PM
                                      • DynaxSC
                                        by DynaxSC
                                        11-17-2023, 10:56 AM
                                      • jbonavita
                                        by jbonavita
                                        Some issues
                                        Things I tried
                                        04-29-2025, 09:38 PM
                                      • throwaway327
                                        by throwaway327
                                        Model No: RC72LA
                                        Serial No: SBNVKD001014459
                                        06-18-2025, 05:52 PM
