macbook air A2337 MDM
  • jacospama
    • Aug 2019
    • 240
    • Ghana
    i want bypass mdm on Macbook Air A2337 emc 3598
  • volinakis
    • Jan 2021
    • 2874
    • N/A
    Re: macbook air A2337 MDM
    check8m
    • mferna14
      • Jun 2018
      • 1046
      check8m
      Do you have a solution for this???? What is "check8m"??? is this a solution or what??? Just wanted to know whether the MDM can be removed permanently from MacBook Air A2337?? Thanks dear if you can answer this for me??
      • volinakis
        • Jan 2021
        • 2874
        • N/A
        search on net "checkm8"
        • mferna14
          • Jun 2018
          • 1046
          Ok... thanks, will surely check this... Hope it resolves all my MacBook Locks problems.
          • Arshad alam4659
            • Aug 2020
            • 157
            • India
            Macbook air a2337 820-02016 nand chip was short (hynix 256 gb) with liquid damaged but i dont have same board
            i have a2289 scrap board (820-01987) chip (tsb 4226) can i replace hynix chip with tsb 4226 or any option
            • peste
              peste commented
              Editing a comment
              post merged..next time look for a thread with the name and model, motherboard model of the laptop, and post there, if you can't find it, then make a new thread..
          • adamgouadma
            • Jul 2017
            • 202
            • setif
            Hello guys I want to bypass mobile device management on my MacBook Air A2337 emc 3598 SN. FVFHQ57NQ6LR
            • tommy97
              MacBook A1932 & A2337 MDM - Permanent solution?
              by tommy97
              we're getting quite a lot wiped A1932 & A2337 from scrap with MDM (Remote management), we'd like to find permanent solution to remove it without CPU swap as it gets not economical, I found iremove.tools website which offer permanent solution, however if they got shut-down i believe laptops would also get locked? Does anyone have any knowledge about this service & about any other possible method?
              06-18-2025, 02:43 AM
            • brockauly
              Macbook M1 A2337 EMC 3598 weird battery charging problem
              by brockauly
              Hi guys,
              If I unplugged the battery and the charger, then plug the battery then the charger, it charges without problem.
              Then if I unplug the charger and plug it back, it won't charge anymore.
              In the first case, main voltage is regulated at ~12.5V and charges the battery.
              After unplugging the charger, main voltage drops to battery voltage at ~11.5V.
              After replugging the charger, main voltage stays at ~11.5V and won't go up to ~12.5V again.
              I found C520A (2.2ยต after current sensor from USB-C source) completely burnt and removed it properly. I cleaned...
              02-05-2025, 10:51 AM
            • rounin
              MacBook Air A2337 (820-02016) USB-C Port Issue โ€“ Only Works in One Orientation (CC Line Problem?)
              by rounin
              I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck โ€” hoping someone here can shed some light.
              ๐Ÿ›  Original Issue
              The machine initially wouldn't negotiate 20V over USB-C โ€” stuck at 5V.
              โš ๏ธ New Problem: One USB-C Port Only Works in One Orientation...
              04-19-2025, 01:18 AM
            • tobeend
              Bypass mdm macbook m2 ventura
              by tobeend
              1. RESET MACOS WITH IPSW
              a. Power off MacBook, press and hold the power button to enter Recovery
              b. Open Disk Utility, remove Macintosh HD
              c. Reboot, connect to the network to Activate Mac.
              d. Plug the C cord in the first port of the MacBook into the other Mac, then power off the MacBook
              d. Hold down the Control (L) + Option (L) + Shift (R) + Power key combination for 10 seconds
              e. Release the other keys, but keep holding the Power key for another 10 seconds
              f. MacBook is returned to DFU, open Apple Configurator 2 on the other Mac, right-click...
              05-26-2023, 07:18 AM
            • mkdj
              MacBook Air A2337 (820-02016) - 5V, won't turn on - please help me understand why
              by mkdj
              About me, my goal and the equipment I (don't) have:
              I am brand new to this forum, and I am eager to learn about repairing laptops. I have an engineer background although I haven't done electronics for a while. I have watched several Youtube videos in the last two months, trying to understand how to diagnose a faulty motherboard. I have a USB-C Amp meter and a classic multi meter. No DC Power Supply to inject voltage, no soldering iron to replace components.
              About my issue and my goal:
              A friend of mine has a MacBook Air M1 A2337 that does not...
              04-03-2025, 08:28 AM
