board & case
Dump Asus Vivobook Pro 14 15 M3500QA ver. 2.1
yes, sorry for my mistake, even in the file name the date is from almost two weeks ago, I didn't notice it, I'm struggling with hypoxia which probably increases the damage because I'm making more and more mistakes, the correct file is from today
as I wrote, the topic is no longer relevant, but maybe the file will be useful someday
Attached FilesComment
Hello! Could someone help me?
I bought an Asus D3500Q with a damaged battery connector. I repaired it, and that part is fine now, but when I turn it on, half of the BIOS is inaccessible (I can't change the settings).
I tried updating it using the machine's own EZBios, but when I select the BIOS file (downloaded from Asus), it says it's not an acceptable BIOS.
I read the chip, and it reads fine. I've tried some BIOS files shared in this same post, but I haven't been able to make them work. I replaced the chip with a new one— with the original bios, it still does the same thing; with other bios, the screen stays black or the laptop won't turn on.
The QR Code info is:
QCCXJE76D22700105
N72NBCX003JCKMB
M3500QC
60NB0UT0-MB2301, 212
The motherboard is a: M3500QA R2.1
Serial number ?Hello! Could someone help me?
QCCXJE76D22700105
N72NBCX003JCKMB
M3500QC
The motherboard is a: M3500QA R2.1↵
https://www.badcaps.net/donateComment
D3500QCAttached Files↵
THKS! It worked, at least now it lets me change the settings, but:- It doesn't recognize any ports — USB, HDD, M.2
- One of the fans doesn't turn on
The issue with the ports is strange because they work with the other one, but I have a question: if I use this BIOS you helped me with to update through EzBios, would there be any problem?
bad bios no data
M3500QC 2.1 RYZEN9 SN ------ N7N0CX16H535304
https://www.asus.com/fr/supportonly/...2Fjrw%3D%3D%2F
BIOS 1.8V
You can using # 68 , D3500QC.bad bios no data
BIOS 1.8V↵
Good morning, could you help me with this error? I'm telling you this Asus arrived because it wasn't giving video. I installed the BIOS published on this page and it gave video fine, but then I shut it down or restarted and it gives that error. I also updated the BIOS to 312 and it doesn't give video. The board model is M3500QA REV 2.1, I don't have the SN model because it's already erased. The BIOS is 1.8V and it's a Ryzen 7 5000 Series.1 PhotoComment
Look on the board for a QR code and upload your dump.
Good morning, could you help me with this error? I'm telling you this Asus arrived because it wasn't giving video. I installed the BIOS published on this page and it gave video fine, but then I shut it down or restarted and it gives that error. I also updated the BIOS to 312 and it doesn't give video. The board model is M3500QA REV 2.1, I don't have the SN model because it's already erased. The BIOS is 1.8V and it's a Ryzen 7 5000 Series.↵
Look, I'm attaching it. If you could help me, thank you very much.
Attached Files1 PhotoComment
ASUS Vivobook Pro 15 OLED (M3500QA, AMD Ryzen 5000 Series)
by shadow666Hi
i need dump bios for
ASUS Vivobook M3500Q
Motherboard : M3500QA
Rev : 2.1
CPU : AMD Ryzen 7 5800H
GPU : NVIDIA GeForce RTX 3050
i tested any bios in this topic but don,t working , I think the files placed in this thread are for the uma motherboard
i,m attached backup bios & problem is notebook power on but don,t boot and blank screenCode:https://www.badcaps.net/forum/troubleshooting-hardware-devices-and-electronics-theory/troubleshooting-laptops-tablets-and-mobile-devices/bios-requests-only/95276-dump-asus-vivobook-pro-15
Regards...-
Channel: BIOS Requests ONLY!
by mkdjDear all,
I would appreciate if someone could take time to explain the issue, so that I can learn. But I would...-
by razor_amdWith ASUS, not everything is quite so simple. I will show you my way. It may be longer or harder but it is the right way to do it in my humble opinion.
This is the picture of 3 similar ASUS motherboards, all of them being X555LD...-
This specification for the ASUS VivoBook ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD boardview and ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...09-07-2024, 02:50 AM
by lrouw84Hi there,
I did a fresh win 11 install, and after the automatic updates, windows rebooted and automatically started asus ez flash.....-
- Loading...
