Dell XPS 9360 (LA-F051P rev 1.0) BIOS needed
  • jacobtc
    • Apr 2016
    • 274
    • Denmark
    Does anyone have a working BIOS for this laptop? I read the original BIOS, and have attached in.
    Symptoms can be read in my other thread: https://www.badcaps.net/forum/showthread.php?t=107907
  • hoaca388
    Badcaps
    • Jan 2022
    • 12316
    Re: Dell XPS 9360 (LA-F051P rev 1.0) BIOS needed
    Xps 13 9360
    • jacobtc
      • Apr 2016
      • 274
      • Denmark
      Originally posted by hoaca388
      Xps 13 9360
      Thanks, I will give it a go.
      • jacobtc
        • Apr 2016
        • 274
        • Denmark
        Weird, I now get a 5 white, 2 amber error code, this means "invalid memory installed" according to Dell... The machine has soldered RAM. The power button lights up now, but turns off again after a couple seconds, and the error described shows up.
          • 21841
          Try this one.Give it a few minutes. If it eventually boots up ok you can update to the latest from dell support to update all the other firmware
          • jacobtc
            • Apr 2016
            • 274
            • Denmark
            Sadly it gives me the same memory error.
            EDIT: https://www.dell.com/support/manuals...b5a&lang=en-us
            Weird that it gives me the "Invalid memory installed" error, and not the "Memory or RAM failure"... Could this mean that the memory is okay?
            • phamduy221
              • Jan 2021
              • 54
              • vietnam
              i need ut5 and ut6 bios of la-f051p can someone help me, thanks
              • ngovanchung
                • Apr 2022
                • 12
                • vietnam
                Please help me, the screen does not display, the lights are flashing 2 yellow - 1 white.
                • peste
                  • Dec 2016
                  • 13550
                  • ROMANIA
                  post S/T, full name and model, motherboard model, ,etc.
                  • ngovanchung
                    • Apr 2022
                    • 12
                    • vietnam
                    Dell xps 9360
                    CAZ70 LA-F051P
                    REV: 1.0 (A00) 2017-06-29
                    S/T : lost the old casing, cannot retrieve it
                    • zenius
                      by zenius
                      12-08-2024, 06:13 AM
                    • mikeybass
                      by mikeybass
                      04-23-2025, 04:30 PM
                    • capoplays
                      Help with BIOS update on Dell G15 5515 after chip replacement
                      by capoplays
                      Hey everyone,
                      I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
                      The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
                      When I check the BIOS using the F12 menu Flash...
                      Yesterday, 06:53 AM
                    • Akhlz001
                      by Akhlz001
                      09-20-2025, 07:15 PM
                    • 417731
                      BIOS needed for Dell Vostro 3405
                      by 417731
                      Hi, I have a problem while updating the bios 1.27.0. After that the display went off & the bios states as Dell Inspiron 3505 in the F2 boot > bios > Device when I plug into a secondary monitor. As I don't have any experience in bios, request you to please help me to flash the Vostro bios as they share the common motherboard (GDI53 LA-K037P).
                      Model: Dell Vostro 3405
                      Tag:F0B1YF3
                      CPU:Ryzen 3500U
                      Thanks in advance
                      07-06-2025, 06:48 PM
