Dell XPS 9360 (LA-F051P rev 1.0) BIOS needed
  • jacobtc
    • Apr 2016
    • 274
    • Denmark
    Does anyone have a working BIOS for this laptop? I read the original BIOS, and have attached in.
    Symptoms can be read in my other thread: https://www.badcaps.net/forum/showthread.php?t=107907
  • hoaca388
    Badcaps
    • Jan 2022
    • 11741
    Re: Dell XPS 9360 (LA-F051P rev 1.0) BIOS needed
    Xps 13 9360
    • jacobtc
      • Apr 2016
      • 274
      • Denmark
      Originally posted by hoaca388
      Xps 13 9360
      Thanks, I will give it a go.
      • jacobtc
        • Apr 2016
        • 274
        • Denmark
        Weird, I now get a 5 white, 2 amber error code, this means "invalid memory installed" according to Dell... The machine has soldered RAM. The power button lights up now, but turns off again after a couple seconds, and the error described shows up.
          • 20929
          Try this one.Give it a few minutes. If it eventually boots up ok you can update to the latest from dell support to update all the other firmware
          • jacobtc
            • Apr 2016
            • 274
            • Denmark
            Sadly it gives me the same memory error.
            EDIT: https://www.dell.com/support/manuals...b5a&lang=en-us
            Weird that it gives me the "Invalid memory installed" error, and not the "Memory or RAM failure"... Could this mean that the memory is okay?
            • phamduy221
              • Jan 2021
              • 54
              • vietnam
              i need ut5 and ut6 bios of la-f051p can someone help me, thanks
              • ngovanchung
                • Apr 2022
                • 12
                • vietnam
                Please help me, the screen does not display, the lights are flashing 2 yellow - 1 white.
                • peste
                  • Dec 2016
                  • 12822
                  • ROMANIA
                  post S/T, full name and model, motherboard model, ,etc.
                  • ngovanchung
                    • Apr 2022
                    • 12
                    • vietnam
                    Dell xps 9360
                    CAZ70 LA-F051P
                    REV: 1.0 (A00) 2017-06-29
                    S/T : lost the old casing, cannot retrieve it
                    • zenius
                      by zenius
                      12-08-2024, 06:13 AM
                    • mikeybass
                      by mikeybass
                      04-23-2025, 04:30 PM
                    • 417731
                      BIOS needed for Dell Vostro 3405
                      by 417731
                      Hi, I have a problem while updating the bios 1.27.0. After that the display went off & the bios states as Dell Inspiron 3505 in the F2 boot > bios > Device when I plug into a secondary monitor. As I don't have any experience in bios, request you to please help me to flash the Vostro bios as they share the common motherboard (GDI53 LA-K037P).
                      Model: Dell Vostro 3405
                      Tag:F0B1YF3
                      CPU:Ryzen 3500U
                      Thanks in advance
                      07-06-2025, 06:48 PM
                    • re1nhold
                      Bios needed, Dell E5550, Tag FSFB262, Zam80 La-911P Rev.1
                      by re1nhold
                      Hello Guys
                      I'm currently fixing two different Dell latitudes,
                      I need a E5550 BIOS - SERVICE TAG is: FSFB262
                      So far I flashed about 6 BIOS from this forum already,
                      none worked,
                      only fan spin ~3s, LCD black, keyboard LED on/off ok,
                      I tried manual extraction with scripts for ages so to speak. VM is untried yet.
                      This laptop is not burnt, it seems to just have a corrupted BIOS.
                      I extra baught ram. This has to work friends.
                      Do you generate it this way in Windows in CMD?:
                      Code:
                      E5550A24.exe /writeromfile C:\bios.fd
                      07-18-2025, 09:18 AM
                    • Aarush653
                      Dell Latitude 5340 corrupt bios - clean bios needed
                      by Aarush653
                      Working on a Dell 5340 new Intel 13th gen with a corrupt bios flash.
                      Worked good before failed flash now won't power at all.
                      May have been a bad connection.
                      Want to get a clean rebuild bios like new motherboard so can input Service Tag on bootup.
                      32mb chip - 25Q256JVEN
                      Attach Dell Bios Update file v1.14 - original Dell update...
                      10-14-2024, 04:28 PM
