Lenovo flex 5-14alc05
  • simonemont
    • Jun 2025
    • Italia
    #281
    I'm trying to fix my daughter's Lenovo IdeaPad Flex 5 14ALC05, the screen simply stays black and the Esc and Capslock LEDs are lighting up, fan is on.
    S/N: PW023V0L
    MTM: 82HU00MTIX
    MO:: PWN0B2511006
    I dumped the bios with my CH341A but it seems that the bios is "empty". I don't know how to recover the DMI
    Can anyone help me?
    • AHSAN TARIQ
      • Jan 2025
      • 61
      • Pakistan
      #282
      S/N: PW023V0L
      MTM: 82HU00MTIX
      MO:: PWN0B2511006
      Can anyone help me?
      try post number 279 it tested and 100 work bios
        • 20848
        S/N: PW023V0L
        MTM: 82HU00MTIX
        MO:: PWN0B2511006
        Can anyone help me?
        Make more backups and compare them. Are you using a clip, is the chip supported
        • Shako
          • Jan 2025
          • 14
          Hi guys. Can you please fix my corrupted bios for Lenovo Ideapad Flex 5 14alc05
          SN: PW011TTK
          MTM: 82HU0133GE
          MO: PWN0B212400C
          And could you please make it so that I keep my original serial number. Thanks in advance.
            • 20848
            SN: PW011TTK
            MTM: 82HU0133GE
            MO: PWN0B212400C
            Everything you need is at post 34 .Any problems let us know.
            • Shako
              • Jan 2025
              • 14
              I made it . Thanks al lot.
                SMDFlea commented
                Editing a comment
                Great, well done :-)
            • Luis Celis
              • Jan 2024
              • 9
              • usa
              #287
              Re: Lenovo flex5 14alc05
              I hope it works fine.
              Hello, i flashed this and my system worked, dont know if i need any information from the original bios, but i will upload and if anyone can help id appreciate it. Thank you in advance. Originally before flashing it was flashing power button and fan would spin full speed but nothing on the screen.
              SN: PW00Z70S
              MTM: 82HU00JPUS
              MO: PWN0B2118004
              • hoaca388
                Badcaps
                • Jan 2022
                • 11726
                #288
                SN: PW00Z70S
                MTM: 82HU00JPUS
                MO: PWN0B2118004
                Flex 5-14ALC05 Laptop (ideapad) - Type 82HU
              • Luis Celis
                • Jan 2024
                • 9
                • usa
                #289
                Thank you so much!
                • ZixuTech
                  • Oct 2017
                  • 88
                  i am dealing with 74M12JWSIQ which doesnt get detected.
                  IC not responding
                  Current programmer: CH341 Black
                  LC56-14A SVT
                  203021-1
                  Suspecting faulty ROM. Any recommendations as replacement?
                  Would Any 1.8V 120 Flash size would work?
                  XM25QH128A I have here seems to be 3.3V
                    • 20848
                    IC not responding
                    It doesn`t get detected because you are doing something wrong or the chip is not in the support list. Don`t assume it`s a fault ROM just because you can`t read it. Choose a different chip that is in the list for example W25Q128JW (1.8V) and try reading it again. If you`re using a clip or pogo adapter it`s not the most reliable way, desoldering the chip and putting it in or on an adapter is the best way.
                    • ZixuTech
                      • Oct 2017
                      • 88
                      Thanks SMDflea
                      I should have specified that this is with the ic desoldered and placed on a SOP socket on 25xx side
                      I have tried with the clip initially, but hasn't detected it. Unless that clip damaged the chip somehow. :/
                      Where the XM25QH128A IC on that socket reads fine, but gives me this error when programming XM25QH128A with GJCN27WW.bin or W25Q128FW_dump.bin from another but same board numbers.
                      Code:
                      22:40:05
                      Programming memory(verifying)... Main Memory
                      Verification error on address: 0x00000000, Device: 0x00, Buffer: 0x02
                      Execution time: 00:00:00.032
                      Seems there is no W25Q128JW on the CH341 Black list. Has anyone come across new list updates? My NeoProgrammer 2.2.0 Chiplist is from 29/09/2021
                        • 20848
                        Thanks SMDflea
                        Code:
                        22:40:05
                        You can add new chip support to NeoProgrammer https://www.badcaps.net/forum/troubl...41a-programmer
                        Attached is ASProgrammer 2.1.2 ,it has pretty good XMC support.
                        Attached is my NeoProgrammer chiplist ,the 25Q128JW is supported.
                          Lenovo IdeaPad Flex 5 Hybrid (2-in-1) Flex Specification for Upgrade or Repair
                          This specification for the Lenovo IdeaPad Flex 5 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Flex 5 boardview and Flex 5 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo...
                          09-07-2024, 07:20 AM
                          09-07-2024, 06:38 AM
