Lenovo flex 5-14alc05
  • jeyzed
    • Oct 2024
    • 6
    IdeaPad Flex 5 14ALC05 Black Screen
    Hello!
    I'm trying to fix a roommate's friend's Lenovo IdeaPad Flex 5 14ALC05 that got bricked through Lenovo Vantage. The screen simply stays black and the Esc and Capslock LEDs are lighting up.
    BIOS Chip: Winbond 74M12JWSIQ
    S/N: PW003TC3
    MTM: 82HU00JWUS
    MO: PWN0B1B0900A
    Factory ID: CQ
    Type 82HU
    I dumped the bios with my CH341A and NeoProgrammer.
    Might someone be able to help me with this?
    Thanks and regards!
    • shiyab
      • Sep 2023
      • 1592
      • india
      #202
      Hello!
      S/N: R91244FL
      Board FRU/PN: 5B21B84990
      Boardcode: 455.0MD02.0001 1A
      Type 82HU
      I tried writing a bios file I found on here and probably fried the chip since I only removed the laptop battery but not the CMOS battery when writing. The BIOS chip is no longer being recognized by NeoProgrammer using the CH341A through the 1.8V adapter, I just purchased a new bios chip here.
      The laptop still has a black screen when turne on and the Esc and Capslock LEDs are still lighting up.
      Thanks and regards!​
      hi try
      • jeyzed
        • Oct 2024
        • 6
        It didn't work :/ here's a dump of what I'm reading from the BIOS right now. I really appreciate the help, thank you!
          • 21667
          It`s corrupt. Are you using a clip, are you using a 1.8V adapter
          • jeyzed
            • Oct 2024
            • 6
            I'm using both! Should I pull out the heat gun and do some surgery to remove the BIOS chip?
              • 21667
              What sort of heat gun do you have, if it`s a proper temperature controlled hot air station then sure. If it`s one of those paint stripper 1000°F​ ones you will likely cause damage to the chip and board.
              • jeyzed
                • Oct 2024
                • 6
                I was planning on ordering a proper heat gun for de-soldering, do you know good heat guns to purchase?
                  • 21667
                  I don`t know what to recommend, depends on your budget. Try this bios, it has your DMI included from post 203. I don`t know which post shiyab replied to but the serial number is different, and he did not add any DMI to the bios. Try again with the clip. keep it steady
                  • jeyzed
                    • Oct 2024
                    • 6
                    It did not work and I'm getting the same probably corrupted bios dump from the chip. I ordered a new chip and I'll try to replace it and dump the bios you provided. Thank you for the dump!
                    • Shako
                      • Jan 2025
                      • 14
                      Hi guys. Can you please help me with my BIOS? Can you repair it, I would like to keep my S/N in BIOS. Lenovo Ideapad Flex 14alc05 Ryzen 3, 8GB RAM
                      S/N: PW00Z070
                      MTM: 82HU00E9GE
                      MO: PWN0B2117001
                      Thank you very much.
                      • volinakis
                        • Jan 2021
                        • 2872
                        • N/A
                        #211
                        S/N: PW00Z070
                        MTM: 82HU00E9GE
                        MO: PWN0B2117001
                        try
                        • Shako
                          • Jan 2025
                          • 14
                          Originally posted by volinakis
                          try
                          It works 🙂🙂 Thank you very very much. This is my first laptop that I managed to save. I am still learning. Thank you. Thank you.
                          • volinakis
                            • Jan 2021
                            • 2872
                            • N/A
                            #213
                            you are welcome. Try to read bios guides made by masters of this forum, is very useful.
                            https://www.badcaps.net/forum/troubl...t=phoenix+bios
                            • Shako
                              • Jan 2025
                              • 14
                              Hi. First thank you one more time for yesterday. I am sorry that I am writing here I couldnt find the right post. I told my friend today how you helped me with the BIOS and he sad that he also has a laptop with same symptoms like my had. He has Yoga 9 14IAP7 and I found 4 BIOS chips 3 from winbond and one giga device. I only managed to extract bios data from gigadevice chip. I tried guides that you sent me here yesterday but I guess I am not that good yet 😔 Can you please help me with this file as well. Thanks in advance.
                              Lenovo Yoga 9 14IAP7
                              S/N: PF3LTW28 MO: PF9XB2321393
                              MTM: 82LU006GE
                                • 21667
                                MTM: 82LU006GE
                                Only bios requests for the flex 5-14alc05 should be posted in this thread topic. I have copied your post to a new thread --> https://www.badcaps.net/forum/troubl...-9-14iap7-bios
                                • Shako
                                  • Jan 2025
                                  • 14
                                  Ok sorry for that. Thank you.
                                  • marknolan
                                    • Feb 2025
                                    • 6
                                    • Ireland
                                    #217
                                    Model: IdeaPad Flex 5 14ALC05
                                    Serial: R912JSQ8
                                    MTM: 82HU00BXUK
                                    Failed during Windows BIOS update. Black screen on boot. All help very much appreciated!
                                      SMDFlea commented
                                      Editing a comment
                                      post moved to 5 14ALC05 thread topic. Post your backup..
                                  • ismailakyoltr
                                    • Mar 2015
                                    • 108
                                    • TURKEY
                                    #218
                                    Model : IdeaPad Flex 5 14ALC05
                                    Serial : PW00B7A2
                                    Mtm : 82HU007FTX
                                    Bios Ic : 74M12JWSIQ
                                    Mb : LC56-14A SVT 203021-1 448.0MD07.0011
                                    IO : NPCE386PB0DX
                                    He screen black and Capslock LEDs are lighting up.
                                    Thank you.​
                                    • peste
                                      • 13422
                                      • ROMANIA
                                      #219
                                      Serial : PW00B7A2
                                      Mtm : 82HU007FTX
                                      IO : NPCE386PB0DX
                                      Thank you.​
                                      see post #15.
                                      https://www.badcaps.net/forum/troubl...05#post1849513
                                      • ismailakyoltr
                                        • Mar 2015
                                        • 108
                                        • TURKEY
                                        #220
                                        Originally posted by peste
                                        I extracted it with 7zip but the size is not full. I can't do it. And when I run it, it is not in temp.
                                          Lenovo IdeaPad Flex 5 Hybrid (2-in-1) Flex Specification for Upgrade or Repair
                                          This specification for the Lenovo IdeaPad Flex 5 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Flex 5 boardview and Flex 5 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo...
                                          09-07-2024, 07:20 AM
                                          09-07-2024, 06:38 AM
