Try our new boardview, bios, & schematic search. Over 1.3 million files for download!
Lenovo flex 5-14alc05
  • fonteene21
    replied
    Originally posted by peste
    read the post above and this..the bios from the post above is virgin, use the HxD program (it's free on the internet), enter both bios into the program (your laptop and the virgin one),
    select that interval mentioned in both bios, copy the interval in your bios and pass it to the virgin bios (copy - paste)....and that's it...
    Dear Pest,
    Thank you for your help.
    Using the HxD program (which is available for free online),
    both BIOS files (copy and paste) worked successfully.
    Now I can fix it myself in the future.
  • peste
    replied
    Originally posted by fonteene21
    The screen is completely black, the Caps Lock light is on, the Esc light is off, the power button is blinking, the CPU is hot, and the fan is spinning.
    After trying a normal BIOS dump from this thread, it started up successfully.
    Could you please correct the BIOS information to the following?
    flex 5 14ALC05
    LC56-14a
    S/N: R912TNM1
    MTM: 82HU009XJP
    MO: R9N08151800B
    Please, someone help me.
  • fonteene21
    replied
    flex 5 14ALC05
    LC56-14a
    S/N: R912TNM1
    MTM: 82HU009XJP
    MO: R9N08151800B
    Premium supporters get full download access and other benefits.
  • peste
    replied
    Originally posted by Mirzamesic
    Hi, i have same model, not booting/no image. Used one of the bios dumps from here just to test and can confirm that it would go to boot menu at least with image. I need the original bios to be repaired
    MODEL: IdeaPad Flex 5 14ALC05.
    SN: R911YA06
    MTM:82HU006NGE
    MOBO: F4302:10A32V
    you have everything you need 5 posts above..
  • Mirzamesic
    replied
    SN: R911YA06
    MTM:82HU006NGE
    MOBO: F4302:10A32V
  • Sparo
    commented on 's reply
    Hi, and thank you for the feedback. That is the spirit! 👍
  • wisam alashkar
    thank you ,this file has helped me alot.
  • fonteene21
    replied
    Originally posted by SMDFlea
    https://www.badcaps.net/forum/troubl...95#post1769295
    Try some older bios versions. If there is no change there is a hardware issue.
    Hello everyone.
    The reason it wouldn't boot was hardware-related.
    Even after flashing to several correct BIOS versions found here, the voltage remained at 20V 0.6A, the ESC and CAPS keys stayed lit, and it wouldn't POST.
    After investigating, I determined that the chipset was overheating in a localized area, and that a chipset short circuit was the cause.
    Thank you for your advice.
    replied
    I've tried several BIOS dumps from this thread, but my laptop still won't boot.
    The screen is black, the Caps Lock, Esc, and power buttons remain lit, and the CPU and SSD get hot.
    Did I do something wrong with the new dump? Or am I using the wrong clean dump?
    flex 5 14ALC05
    LC56-14a
    S/N: PW02XGE
    MTM: 82HU00R9JP
    MO: PWN0B270400H
    Can anyone help me?
  • fonteene21
    replied
    flex 5 14ALC05
    LC56-14a
    S/N: PW02XGE
    MTM: 82HU00R9JP
    MO: PWN0B270400H
    Can anyone help me?
  • fonteene21
    replied
    bios extracted from Lenovo website update for Flex 5 14ALC05, Flex 5 15ALC05
    DMI 5EA000 - 5EDFFF
    KEYWIN 61709C - 6170B8
    Attached Files if you find these attachements useful please consider making a small donation to the site
    Unfortunately, using this BIOS didn't work either.
    I tried removing the chip from the motherboard and rewriting the BIOS with a programmer, but...​
  • peste
    replied
    Hello, I think my BIOS is corrupted. Could you please help me?
    The CAPS.ESC key stays lit, the fan spins occasionally, but the computer won't boot.
    Lenovo Ideapad Flex 5 14ALC05
    S/N - PW02XSGE
    MTM - 82HU00R9JP
    MO - PWN0B270400H
    DMI 5EA000 - 5EDFFF
  • fonteene21
    replied
    S/N - PW02XSGE
    MTM - 82HU00R9JP
    MO - PWN0B270400H​
  • m1ch43lzm
    replied
    Originally posted by Nicox
    Hi everyone, guys I hope you can help me, I'll start by saying I'm a bit of an idiot......
    Lenovo IdeaPad Flex 5 14ALC05 I think blocked via Lenovo Vantage. The screen is black and the Caps Lock LEDs light up
    s/n R91225F00
    mtm: 82HU000VIX
    bios ic winbond 74M12JWSIQ
    I bought a CH341Apro programmer, and I thought that by simply loading a new bios I could solve the problem, but I realized that I'm a big idiot, I haven't done any assistance for 20 years from…
    Try, BIOS extracted from Lenovo website, DMI+Win key inserted
    Flex 5-14ALC05 Laptop (ideapad) - Type 82HU
    BIOS ver. GJCN34WW
    S/N R9125F00
    MTM 82HU000VIX
    DMI 5EA000-5EA3FF
    Win key 617000-6170CF
  • m1ch43lzm
    Thread merged, don't post pictures unless asked
  • Nicox
    replied
    s/n R91225F00
    mtm: 82HU000VIX
  • playmedia
    worked perfect thank you.
  • m1ch43lzm
    replied
    Laptop should boot with a clean BIOS, just the S/N, MTM, model name will show as INVALID and will be missing the Win license, older version GJCN27WW is available at post 7 on the first page
    Also the BIOS chip is 1.8V, did you use 1.8V adapter with the CH341A? Maybe the problem isn't the BIOS
  • Jasva
    replied
    BIOS ver. GJCN34WW
    S/N R912JDSC
    MTM 82HU00EXMH​
    DMI 5EA000-5EA3FF
    This one unfortunately does not work. I checked my motherboard with a multimeter and all the voltages seem to be normal and pointing towards the bios or the ram. So a few qustions about the bios, does the bios version matter? For example the newer versions have the number 34, but does that really matter and would a 27 or 29 also just work? Next to that, how important is the DIM data, should the computer also start on a clean dump?
    It seems very unlikely to me that the problem lies with the RAM, and I am hoping maybe I still need to figure out a correct dump
  • Jasva
    Unfortunately this one also does not work, maybe it is not a BIOS error?
    I am using neoprogrammer and both the blank check and verification gave back a success
  • Boardview and Schematic Bot
    Lenovo IdeaPad Flex 5 Hybrid (2-in-1) Flex Specification for Upgrade or Repair
    by Boardview and Schematic Bot
    This specification for the Lenovo IdeaPad Flex 5 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Flex 5 boardview and Flex 5 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo...
    09-07-2024, 07:20 AM
    09-07-2024, 06:38 AM
