Lenovo flex 5-14alc05
  • danito
    • Jun 2016
    • 1091
    #241
    Originally posted by Joandean14
    i already see the model this is flex 5 ACLO5 RYZEN 5
    THANK YOU!
    try
    [+] MTM: 82HV0075UK
    [+] MO: PW01P8WMPW90B2322006
    [+] Product Name: IdeaPad Flex 5 15ALC05
    [+] Serial Number: PW01P8WM
    [+] Pre Installed OS Lisc: SDK0T76473 WIN​
    • Nielsm
      • May 2021
      • 6
      • Denmark
      #242
      MTM 82HU003KMX
      MO R9N0B142300H
      SN R912JH05
      BIOS Chip Winbond W74M12JW SSIQ
      After BIOS update GJCN34WW from Lenovo website the laptop would not post.
      Novo-button from off or a simple off/on = still no post w/CAPS and ESC lights on.
      Sincerely
      • hoaca388
        Badcaps
        • Jan 2022
        • 12316
        #243
        Originally posted by Nielsm
        MTM 82HU003KMX
        MO R9N0B142300H
        SN R912JH05
        Sincerely
        Where's your backup bios ? Back it up even if it crashes.
        • Joandean14
          • Jul 2021
          • 23
          • Philiphines
          #244
          Originally posted by danito
          try
          [+] MTM: 82HV0075UK
          thankyou my friend i will try later
          • Nielsm
            • May 2021
            • 6
            • Denmark
            #245
            Good evening
            I've just received EZP2019 by mail today and read the bios.
            Though the EZP2019 does not self declare the correct chip when I push test!!
            The software reports 93_EEPROM, ATMEL, AT93C46@16
            However selecting SPI_FLASH, Winbond, W25Q128JV, Size 16 MB I managed to read the attached bios, where I could locate the SN in offset 005EA080 :-) Ie. some of the data is not corrupted.
            V/r Niels
            PS: how do I add the correct chip type to the EZP2019 chip database?
            • hoaca388
              Badcaps
              • Jan 2022
              • 12316
              #246
              Good evening
              V/r Niels
              "Invalid File Specified" . I got this message when downloading your file.
              • Joandean14
                • Jul 2021
                • 23
                • Philiphines
                #247
                try
                [+] MTM: 82HV0075UK
                hello thank you danito but this file is not working even turning on no post no power
                someone help me please thankyou
                • Nielsm
                  • May 2021
                  • 6
                  • Denmark
                  #248
                  Roger... My bad for not verifying the post.
                  Try this instead.
                  • hoaca388
                    Badcaps
                    • Jan 2022
                    • 12316
                    #249
                    Try this instead.
                    Flex 5-14ALC05 Laptop (ideapad) - Type 82HU
                    • Nielsm
                      • May 2021
                      • 6
                      • Denmark
                      #250
                      hoaca388, thanks a bunch. That worked like a charm 🙌
                      Let me elaborate on my way to success with EZP2019 programmer acquired from Amazon with 1.8V adapter (note: there's a newer version EZP2023. The software recognized the 2019 version however the chip database did not contain Flex 5 14ALC05 Winbond W74M12JW bios chip either).
                      1) saw a bunch of YouTubes irt. CH341A and EZP2019 how-to-program and do's/don'ts. I really considered afterwards if I should have bought en CH341A or maybe even the newer version CH347T / F (able 1.8 volt)
                      2) read a bunch of posts to include this awesome collaborate website 😀
                      3) how to place the in situ chip reader irt. pin 1 - 8
                      4) read up on Winbond.w74m12jw rev b data sheet to verify voltage usage (ie. do use 1.8 volt adapter)
                      4) troubleshot how to use the 1.8 volt adapter with the EZP2019 including how to place both adapter and in situ chip reader - ie. how to orient pin 1 right from the motherboard/bios chip to the EZP2019
                      5) use of software including setting variables to reduce interference, double verification of reading bios and Erase bios before writing then verifying bios data (Lesson Identified: if you only write - verify it's gonna produce an error)
                      • ovih
                        • Apr 2025
                        #251
                        Hi! I have a laptop that does the same issues. Power button blinks, caps-lock lights and no blink on ESC. This is what I have on the back.
                        MTM: 82HU0070RM
                        MO: R9N0B131200M
                        SN: R911YJHJ
                        Factory ID: KS
                        And how to update the bios?
                        • hoaca388
                          Badcaps
                          • Jan 2022
                          • 12316
                          #252
                          MTM: 82HU0070RM
                          MO: R9N0B131200M
                          SN: R911YJHJ
                          Factory ID: KS
                          • ovih
                            • Apr 2025
                            #253
                            How can I backup? Cause I dont think I have it. Right now, I've done the FN+R key-combination with the stick I plugged in changing to bin, wph and rom formats and still nothing. Everything stays on but the screen is black.
                            • peste
                              • 13550
                              • ROMANIA
                              #254
                              you need an SPI programmer...here is a video for example..https://www.youtube.com/watch?v=DWWi...nnel=ThisIsHow
                              • ovih
                                • Apr 2025
                                #255
                                Hi peste! Thanks for the video! Unfortunately, I do not have one, and I dont have the money. Any other choices?
                                  • 21841
                                  Have you tried pressing the novo button https://psref.lenovo.com/WDProduct/I...Flex_5_14ALC05 .If that doesn`t work your only option is to buy a cheap programmer EZP****/CH341A and try to fix it yourself, or take it to a repair shop, where it will cost a lot more money.
                                  • ovih
                                    • Apr 2025
                                    #257
                                    Do I have to hold the Novo button or how?
                                    Thanks!
                                    UPDATE: Pressed it, still does nothing.
                                    • NeeMan
                                      • Nov 2023
                                      • Electronic Country
                                      #258
                                      Hi
                                      I have a Lenovo IdeaPad Flex 5 14ALC05 screen stays black and the Esc and Caps lock LEDs are lighting up. Does not display with external screen.
                                      SN: R91242NT
                                      • hoaca388
                                        Badcaps
                                        • Jan 2022
                                        • 12316
                                        #259
                                        Originally posted by NeeMan
                                        Hi
                                        SN: R91242NT
                                        • NeeMan
                                          • Nov 2023
                                          #260
                                          THANK YOU! After a day of trying to flash it, it finally worked!
                                          I could read, write & unprotect but was getting different errors with different flash programs when verifying. Tried many different versions as well.
                                          NeoProgrammer
                                          Verify memory...
                                          Verification error on address: 000D4A00
                                          AsProgrammer
                                          Programming memory(verifying)...
                                          Verification error on address: 0000057C
                                          CH341A Programmer
                                          Chip main memory with the contents are in disagreement
                                          SOLUTION: Remove BIOS from motherboard and then flash it. Worked on the first try with NeoProgrammer. I did not test any other program but I'm sure the BIOS being soldered on the motherboard was giving the errors.
                                            Lenovo IdeaPad Flex 5 Hybrid (2-in-1) Flex Specification for Upgrade or Repair
                                            This specification for the Lenovo IdeaPad Flex 5 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Flex 5 boardview and Flex 5 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo...
                                            09-07-2024, 07:20 AM
                                            09-07-2024, 06:38 AM
