13-aw0023dx BIOS PWD Removal
  • mgrharry
    • Sep 2016
    • 211
    • usa
    Got an HP 13-aw0023dx here and the owner set and then forgot the BIOS power on password
    For giggles, I tried a BIOS dump someone had posted in an earlier thread for a corrupted BIOS on this same model, which apparently came from a similar but not exactly matching model, but the system doesn't even post with that. I also tried the HP emergency BIOS recovery option (Winkey + B + power) but while it does go through the motions and reflash the BIOS, at the end it still prompts for power on password.
    I've attached a dump of the BIOS.
  • peste
    • Dec 2016
    • 12852
    • ROMANIA
    Re: 13-aw0023dx BIOS PWD Removal
    use RCUnlocker and unlock it yourself..you don't have the password in this bios ... look for another bios chip on the board ..
    • mgrharry
      • Sep 2016
      • 211
      • usa
      Thanks for the tip. Wasn't aware of this tool, it looks great. I'm wondering though if it works for power on passwords or only BIOS password lock? I can see that it says "missing unlockable content" if I drop my dumped bin file onto it. When I open the bin I uploaded in UEFITool it appears to be structured like a valid BIOS dump, from what I can assess based on my limited familiarity.
      I've attached pics of the Winbond chip I dumped and the only other two that look like possible alternate BIOS chips, Winbond 25q80dv1g and MXIC mx25l8008ezni.
      • mgrharry
        • Sep 2016
        • 211
        • usa
        And attached is the BIN file extracted from the latest HP BIOS download for this model.
        • mgrharry
          • Sep 2016
          • 211
          • usa
          Odd thing here, I tried flashing a BIOS from a previous posting (https://www.badcaps.net/forum/showthread.php?p=1000108) for the same model that the OP had said worked but was slow to boot and displayed mfg mode msg and got no post. reflashed the original bios dump and it still doesn't post. it will occasionally boot into bios restore mode with winkey + b and go through a restoring bios process but then it shuts off and won't post again for a number of tries. Trying to understand how the BIOS backup restore feature works on this model and what it may have to do with the issues I'm having. Any thoughts?
          • peste
            • Dec 2016
            • 12852
            • ROMANIA
            use version 086F9 from post # 4 in this thread.. if you have the same motherboard.
            • mgrharry
              • Sep 2016
              • 211
              • usa
              I tried that 086F9 bios and it doesn't post. Also when I restore my original BIOS dump back to the chip it still doesn't post. I can get it to go to BIOS recovery mode by holding Winkey + B while pushing power button and it goes through the motions of restoring the BIOS backup but they instead of rebooting it just powers off and won't post again.
              • mgrharry
                • Sep 2016
                • 211
                • usa
                Main BIOS chip is highlighted. Is there another chip I need to dump / reprogram?
                • DanielDacko
                  • Mar 2015
                  • 325
                  • Macedonia
                  Check this marked one.
                  I don't provide help for people using CH341A and a clip.
                  • mgrharry
                    • Sep 2016
                    • 211
                    • usa
                    OK, that highlighted chip is an MX25L8006. A dump is attached
                    • mgrharry
                      • Sep 2016
                      • 211
                      • usa
                      Anyone know what purpose this MX25L8006 chip serves on this board?
                      • hoaca388
                        Badcaps
                        • Jan 2022
                        • 11786
                        MX25L8006 is not bios chip. Check below picture, it's look like a WSON chip. Lets me know name of that chip
                        • mgrharry
                          • Sep 2016
                          • 211
                          • usa
                          I've attached a photo indicating the chip model for the two WSON chips on top of board.
                          • hoaca388
                            Badcaps
                            • Jan 2022
                            • 11786
                            Try read data of both wson chips.
                            • mgrharry
                              • Sep 2016
                              • 211
                              • usa
                              Dump of 25q80dv is attached. I uploaded dump of mx25l8006 in a previous post.
                              • hoaca388
                                Badcaps
                                • Jan 2022
                                • 11786
                                If your model is HP Specter x360 - 13-aw0023dx, chip bios must be 16MB (eg 25Q 128.. with Winbond chip).
                                  • 20966
                                  • mgrharry
                                    • Sep 2016
                                    • 211
                                    • usa
                                    I tried the bios dump you posted, hp-13-aw0023dx-pwd-unlocked.zip, but get only quarter fan spin and short power cycle, no post. You also posted this EC bin file however, but I'm not sure which chip this is for?
                                    On the bottom of board there is SLB9670 TPM chip next to IT5570VG-256
                                    • mgrharry
                                      • Sep 2016
                                      • 211
                                      • usa
                                      Also, to return to a previous question, I'm trying to understand how the system seems to be in a worse state now than it was originally. I backed up the primary winbond bios file (dump was attached to original post), then tried flashing the 086F9 bios recommended by peste and but it did not post. Normally I would think that should be no problem, since I had made a backup of the bios before any modifications, and I reflashed that original bios backup, which should have restored the system back to it's power on password protected status. Instead, the system would no longer post normally, and the only way I could get a response out of it was to startup with Winkey+B whereby it would go through the motions of performing a BIOS restore from previous version, but at the end it still would not post. So clearly what I had thought of as a safeguard, backing up the main bios chip, was not sufficient in this case. What explains that?
                                      And thanks to peste, smdflea and everyone else for suggestions, just finding this one to be a headscratcher.
                                      • peste
                                        • Dec 2016
                                        • 12852
                                        • ROMANIA
                                        I think you wrote or read the bios chips with errors..from the beginning when you read the bios chip you read it with errors..that's why when you put back the one with the password (original) the screen is black...or maybe not did you stick the bios chips well.. which programmer did you use?? if you use this clip it gives errors... you have to remove the chip from the motherboard before reading or writing..
                                        • Habble7
                                          by Habble7
                                          Suspected Cause:
                                          Troubleshooting Attempts:
                                          05-22-2025, 07:28 AM
                                        • Buzzfuzz2k
                                          Bios password removal on a Unowhy dump
                                          by Buzzfuzz2k
                                          Hi Everyone,
                                          I'm facing a problem with a locked bios with a password and i can't find how to remove it...
                                          The small computer is only booting on a M2 ssd Windows partition and i get a "signed partition error" if i try to boot on the same SSD with another Os (linux for example).
                                          the Computer is a Unowhy small pc
                                          N° UYM6524702229
                                          After failling trying to boot on other "none Windows" partition, i wanted to try to remove the bios password.
                                          My first attempt was to get the bios dump from windows...
                                          11-13-2023, 07:37 AM
                                        • haitham sharabati
                                          [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
                                          by haitham sharabati
                                          Hello engineers 😀,
                                          I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
                                          🔧 Device Info:
                                          - Model: HP 15-da2007ne
                                          - Product Number: 8XF55EA#ABV
                                          - Serial Number: CND0338P0D
                                          - CPU: Intel Celeron N4000
                                          - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
                                          💀 Problem:😅
                                          - Device shows “Administrator Password”...
                                          08-07-2025, 04:54 AM
                                        • Citymin
                                          by Citymin
                                          S/N : 5RNK9FFT70...
                                          08-05-2025, 05:12 AM
                                        • DynaxSC
                                          by DynaxSC
                                          11-17-2023, 10:56 AM
