Dump Asus X509FAC
  • toni comp
    • May 2012
    • 13
    • indonesia
    #61
    HELLO i need bios asus x509fac rev 2.0 , bios dump here
    • lapfix
      • Mar 2020
      • 2764
      • my workshop
      #62
      What's your issue ..bios password , no display , no power !!
      If you have serial post it
      • toni comp
        • May 2012
        • 13
        • indonesia
        #63
        Laptop hangs while Windows is running. SN: MCN0CX25R11151B
        • aquif
          • Sep 2014
          • 61
          • India
          #64
          Originally posted by hoaca388
          Re: Dump Asus X509FAC
          Those files already have a clean ME region.
          please fix this bios with clean me
          problem- keyboard working
          abnormal
            • 22424
            abnormal
            post the laptop serial number
            • aquif
              • Sep 2014
              • 61
              • India
              #66
              model-x409fa-ek617t
              S/N-MBN0CX13C537450
                • 22424
                model-x409fa-ek617t
                S/N-MBN0CX13C537450
                Find the QR code on the motherboard - https://www.badcaps.net/filedata/fetch?id=2092293 ,scan it and post what it says or post a clear picture of it
                • aquif
                  • Sep 2014
                  • 61
                  • India
                  #68
                  here it is
                  • shiyab
                    • Sep 2023
                    • 1749
                    • india
                    #69
                    here it is
                    hi try
                    • aquif
                      • Sep 2014
                      • 61
                      • India
                      #70
                      Originally posted by shiyab
                      hi try
                      same problem
                      • mkdj
                        by mkdj
                        Dear all,
                        10-19-2025, 04:41 AM
                      • razor_amd
                        by razor_amd
                        12-15-2020, 07:07 PM
                      • pirati
                        by pirati
                        10-27-2025, 04:20 PM
                      • DynaxSC
                        by DynaxSC
                        06-14-2024, 03:49 PM
                      • Ahari
                        by Ahari
                        I...
                        08-13-2025, 06:12 AM
