Dell E5570 MB LA-C841P bios
  • NBel
    • May 2016
    • 11
    • Moldova
    Try, it is dump form the board with shorted CPU, windows key cleared with XXX.
    ps. had a lot of those boards, most of them with failed cpu drmos, and cpu dead. and one with hissing noise, from PL801. Changing PL801 from 2r2 to 3r3 seems to solve the problem.
  • AJHO
    • Jan 2022
    • Netherlands
    Re: Dell E5570 MB LA-C841P help with +VCC_GT power
    Hello all,
    I'm new to this forum and to bios flashing, so I hope I can learn a lot from you all.
    Does any of you recognize a cpu error shown by blinking leds 2x orange and 1x white after flashing?
    Rgrds,
    AJ.
    • AJHO
      • Jan 2022
      • Netherlands
      I downloaded a flash file (E5570 DELL.rar) from another thread in this forum "Dell Latitude E5570 bios nedded" and this solved my cpu error my system is up and running again. now I have to update from 1.5.0 to the latest.
      • m.sabry2110
        • Oct 2017
        • 136
        • egypt
        Thank you it's working 100%
        • zenius
          by zenius
          12-08-2024, 06:13 AM
        • mikeybass
          by mikeybass
          04-23-2025, 04:30 PM
        • capoplays
          Help with BIOS update on Dell G15 5515 after chip replacement
          by capoplays
          Hey everyone,
          I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
          The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
          When I check the BIOS using the F12 menu Flash...
          10-24-2025, 06:53 AM
        • Akhlz001
          by Akhlz001
          09-20-2025, 07:15 PM
        • Sathsul
          Dell Latitude 5431 issues with dumping bios
          by Sathsul
          So, i kinda spend significant ammount of the last couple of days trying to flash a new bios, and or unlocking the current bios password with little to no results.
          The whole thing started with it being the 8fc8 bios, i found the tools to unlock that but i needed a bios dump. So i pursued that, im at a point where i dessoudered the chip, and succesfully soudered it to the ch341, dumped whatever was on it.
          However, the tools supposed to unlock the 8fc8 say that there is no 8fc8 hex inside. And when i followed diffrent tutorials to just flash a new bios onto the chip i got stuck on the...
          10-28-2025, 07:49 AM
