Asus FX506LI dabkxdmb8f0 no video
  • osman68i
    • May 2015
    • 338
    • The Netherlands
    does someone have a working bios for asus fx506li dabkxdmb8f0?
    laptop start without video.
    model : fx506LI
    SN: M4NRCX04H317164
    original bios is attached.
    maybe someone can fix this bios
  • DanielDacko
    • Mar 2015
    • 325
    • Macedonia
    Re: Asus FX506LI dabkxdmb8f0 no video
    Injected latest bios from the site into your dump, try and report.
    I don't provide help for people using CH341A and a clip.
      • 20898
      something isn`t right with your file,check it with a hex editor
      • osman68i
        • May 2015
        • 338
        • The Netherlands
        tested but laptop is not starting
        bios is not ok.
        • DanielDacko
          • Mar 2015
          • 325
          • Macedonia
          If this backup doesn't work, than I can't help you...
          • osman68i
            • May 2015
            • 338
            • The Netherlands
            I have tried but same result.
            thanks for your time
            • adamgouadma
              • Jul 2017
              • 184
              • setif
              model : fx506LI
              SN: M4NRCX04H317164
              thanks
              • chandrakant
                • Nov 2017
                • 38
                • india
                Working But Late Display
                • lapfix
                  • Mar 2020
                  • 2720
                  • my workshop
                  there s a whit sticker near ram socket , post his picture
                  • razor_amd
                    by razor_amd
                    12-15-2020, 07:07 PM
                  • grimacelord
                    by grimacelord
                    07-10-2025, 02:52 PM
                  • throwaway327
                    by throwaway327
                    Model No: RC72LA
                    Serial No: SBNVKD001014459
                    06-18-2025, 05:52 PM
                  • jbonavita
                    by jbonavita
                    Some issues
                    Things I tried
                    04-29-2025, 09:38 PM
                  • lrouw84
                    by lrouw84
                    Hi there,
                    01-28-2023, 01:31 PM
