Da0p5hmb8f1 bios
  • LowBudgetEngineer
    • Sep 2021
    • 9
    • Unite States
    Da0p5hmb8f1 bios
    Hi, I need BIOS for DA0P5HMB8F1
    Brand:HP
    Model: 15 DY2091WM
    Thank you
  • Bonzas
    • 471
    • Indonesia
    Re: Da0p5hmb8f1 bios
    Post your backup or serial number here
    • s2qer
      • Jan 2017
      • 9
      • iraq
      i need bios dump pls
      DA0P5HMB8F1 rev: f
      • satishkumar
        • Sep 2015
        • 164
        • India
        DA0P5HMB8F1 rev: f
        upload ur original old bios and laptop serial number
        • s2qer
          • Jan 2017
          • 9
          • iraq
          I got a working bios file
          I wanted to share it with you
            • Jun 2022
            • 15
            • Nigeria
            works perfect %100 thanks
            • sleandru
              • Mar 2020
              • 10
              • Brasil
              NEED THE EC BIOS, SOMEONE HAVE IT ?
              • peste
                • Dec 2016
                • 12748
                • ROMANIA
                read..https://www.badcaps.net/forum/troubl...before-posting
                • Blackam8899
                  • Sep 2020
                  • 44
                  • Rosario
                  here
                  • ingenieroedu
                    • May 2023
                    • 68
                    • Colombia
                    Hello colleagues, I need help with this file, it starts in bios recovery mode. I have tried using the USB tool without success. I leave a copy to someone who can help me.
                    hp model 15-dy2024nr
                    sn/ 5CD1384LR5
                    motherboard model da0p5hmb8f1 rev f​
                      • 20807
                      sn/ 5CD1384LR5
                      Use the Guides to find and extract a virgin bios
                      [Guide] How to find the right HP bios version to flash https://www.badcaps.net/forum/troubl...flash?t=122195
                      [Guide] How to extract ready for programming dump from HP update executable file https://www.badcaps.net/forum/showthread.php?t=121948
                      Copy the DMI (serial,feature Byte,win key) from your backup to the virgin bios using a hex editor.Select the same offsets (select block in HxD) in both bios,copy from the old,paste to the new.
                      Offsets: 801000 - 8020FF and 886000 - 88603F
                      HxD Hex editor https://mh-nexus.de/en/hxd/​
                      • thoc
                        • Mar 2023
                        • vietnam
                        need help does not recognize hard drive,
                        model : 15-dy2024nr
                        SN : 5CD212BBTD
                          SMDFlea commented
                          Editing a comment
                          post moved to Da0p5hmb8f1 thread topic
                      • danito
                        • Jun 2016
                        • 902
                        • Romania
                        model : 15-dy2024nr
                        SN : 5CD212BBTD
                        here
                        • hoaca388
                          Badcaps
                          • Jan 2022
                          • 11713
                          model : 15-dy2024nr
                          SN : 5CD212BBTD
                          HP Laptop 15-dy2024nr (4X6F6UA)
                          ​BID : 087FD
                          • Carlos Simbaña
                            • Jun 2024
                            • 15
                            • Ecuador
                            Hello, please somebody could help me, the laptop doesn´t recognize the nvme ssd, I appreciate the help.
                            Model: 15-dy2093dx
                            Serial number: 5CD130HR9M
                            ProdID: 405F7UA#ABA
                            • peste
                              • Dec 2016
                              • 12748
                              • ROMANIA
                              Model: 15-dy2093dx
                              ProdID: 405F7UA#ABA
                              The bios posted is corrupt...make a new copy and post again...
                              The bios chip must be unsoldered from the board before writing or reading..
                              do not use the clip, you may have errors..if you do not have anything to unsolder it with,
                              solder wires between the programmer and the bios chip..
                              here is a video for example..https://www.youtube.com/watch?v=DWWi...nnel=ThisIsHow
                              • Habble7
                                by Habble7
                                Suspected Cause:
                                Troubleshooting Attempts:
                                05-22-2025, 07:28 AM
                              • DynaxSC
                                by DynaxSC
                                11-17-2023, 10:56 AM
                              • cekcons
                                g1 assassin Rev 1 bios dump - main and backup needed
                                by cekcons
                                main and backup ic dead so i cant post corrupt bios cause its 01 all over.
                                thanks
                                01-23-2024, 03:26 AM
                              • MDSI
                                HP OMEN 17-an012nf BIOS dump with EC (DAG3BAMBAF0 REV : F)
                                by MDSI
                                I'm requesting a full BIOS dump (including EC firmware) for an HP OMEN 17-an012nf laptop.
                                Details:
                                Model : HP OMEN 17-an012nf
                                Motherboard Part Number : DAG3BAMBAF0 REV : F
                                Serial Number (S/N) : 5CD7280D51
                                BIOS chip : Winbond W25Q64VSIQ
                                Programmer : EZP2023+
                                Issue : The motherboard is not powering on. Only the 5V rail is present. The 3.3V rail is missing because EN1 on the SY8286B remains stuck at 0V. This signal is driven directly by the EC/SIO. I replaced the 3.3V regulator and confirmed it's working.
                                I already...
                                07-28-2025, 07:11 AM
                              • grimacelord
                                Trying To Find UUID In BIOS Dump - HP 14-dq0055dx
                                by grimacelord
                                This laptop is the same laptop I was working on in this thread and I wasn't sure if I should post a new topic or post in that thread because I already solved the issue that thread was discussing and this is a completely different issue although it is dealing with the same laptop. I decided to make a new thread since it's a new issue, but please move if I made a mistake.
                                Motherboard model number: DA0PAMB46A1 REV: A
                                Secondary motherboard model number: 0PAB
                                SKU: 685K4UA
                                Serial number is: 5CD3223BJP
                                Recently reflashed this laptop with latest BIOS and once...
                                05-07-2024, 08:06 AM
