HP ZBOOK 14U G6 Bios
  • rui4892
    • Mar 2017
    • 57
    • Portugal
    #41
    Originally posted by hoaca388
    Check hardware.
    machine is working with files from post #17, thank you.
    with endpoint error and manufacturing mode but working for testing...
    • rui4892
      • Mar 2017
      • 57
      • Portugal
      #42
      the problem returns when doing Windows updates, the solution I found was... go to the EFI partition, originally 100mb, delete the HP folder and respective files, and reduce the size of the EFI partition to around 40mb... the machine still tries to update the firmware but stays at the initial warning and reboots and continues to start Windows.
      • pronto
        • Mar 2019
        • 129
        • morocco
        #43
        hi I have problem on bios hp zbook 14u g6, i try another bios but sound and battery not charging here old dumps
        hp zbook 14u g6
        motherboard/ 6050A3022501
        SN/5CG0416BSC
        • farizmohammed
          • Dec 2017
          • 6
          • India
          #44
          Hello
          I need help with a BIOS file for my laptop
          current condition : when i turn on the Caps Lock LED blink once and laptop doses not boot
          Attached my current Bios backup.
          could someone please share a clean BIOS file for this board?
          🖥️ Laptop Model: HP ZBook 14u G6
          🔢 Serial Number: 5CG0010KY6
          🔧 Product ID: 4YP13AV
          🔢 Mother Board part Number: 6050a3022501-mb-a01
          • peste
            • Dec 2016
            • 13880
            • ROMANIA
            #45
            post merged..next time look for a thread with the name and model, motherboard model of the laptop, and post there, if you can't find it, then make a new thread..
            • GlobalSerwis
              • Jun 2025
              • 19
              • Poland
              #46
              HP Zbook 14U G6
              6050A3022501-MB-A01
              SN : 5CG92914G2
              ProdID : 4YP12AV
              Please remove BIOS password, I have already tried HPUnlocker.
                SMDFlea commented
                Editing a comment
                Post moved from 840 G6 topic...
            • hoaca388
              Badcaps
              • Jan 2022
              • 12431
              #47
              Originally posted by GlobalSerwis
              HP Zbook 14U G6
              6050A3022501-MB-A01
              SN : 5CG92914G2
              ProdID : 4YP12AV
              Pasword removed.
              • GlobalSerwis
                • Jun 2025
                • 19
                • Poland
                #48
                Pasword removed.
                Thank you very much for your help, the BIOS works, no password. 😊
                • johansel
                  • Feb 2022
                  • 39
                  • colombia
                  #49
                  Good morning.
                  Can you help me fix this BIOS?
                  It updated and stopped showing video.
                  HP ZBook 14u G6
                  S/N: 5CG0236B99
                  • johansel
                    • Feb 2022
                    • 39
                    • colombia
                    #50
                    Originally posted by johansel
                    Good morning.
                    HP ZBook 14u G6
                    S/N: 5CG0236B99
                    Good morning.
                    • Philip2809
                      • Apr 2025
                      • 3
                      • Sweden
                      #51
                      Hello, I would need some help with this bios. I have two machines with problems; will start with the first one. I will attach the original bios that I read, it has problems with blinking lights, sadly forgot how many but looked like bios issue so I tried to flash from post #17 here, and when I turn it on I get 7 blinks from caps lock, when I plug in the usb c charger the white charger led is on and then once I get a 6 blinks of orange. For the previous person with 7 blinks you said to check hardware; what should I check? I have plugged everything in except battery, ssd and wifi card; the laptop should work without those?
                      HP ZBook 14u G6
                      PID: 6TP69EA
                      SN: 5CG9507MX2
                      BID: 19WWCFBT601#SAK8#DAK8
                      MOBO: 6050A3022501-MB-A01(A1)
                      Thanks in advance!
                      • peste
                        • Dec 2016
                        • 13880
                        • ROMANIA
                        #52
                        HP ZBook 14u G6
                        PID: 6TP69EA
                        SN: 5CG9507MX2
                        Thanks in advance!
                        yes it works without them you just need the motherboard and the ram memory..of course and the display...
                        • Philip2809
                          • Apr 2025
                          • 3
                          • Sweden
                          #53
                          Yes, those I had plugged in, but sadly I am getting the 7 blinks. I wanted to try the other bios files here but accidentally knocked one of the small black things (i think resistor) to the side and when I tried to place it back I accidentally lost it and cannot find it; does anyone has a boardview/schematic where I can find the value of it of it is possible to bridge it, or maybe take one from somewhere else on the board? It looked like there was similar ones at the debug pins.
                          • peste
                            • Dec 2016
                            • 13880
                            • ROMANIA
                            #54
                            post a clear picture of the region on the board where the pieces jumped out so we can see..
                            • Philip2809
                              • Apr 2025
                              • 3
                              • Sweden
                              #55
                              Click image for larger version  Name:	missing1.png Views:	0 Size:	443.9 KB ID:	3723615 Click image for larger version  Name:	missing2.png Views:	0 Size:	523.7 KB ID:	3723616
                              Yes, attached pictures of what I accidentally lost; and how it should look based on the other same laptop I have.
                              How it should look:
                              Click image for larger version  Name:	correct.png Views:	0 Size:	676.6 KB ID:	3723614
                              Similar ones at debug port?
                              Click image for larger version  Name:	debug-similar.png Views:	0 Size:	583.1 KB ID:	3723613
                              Got schematic from here:
                              https://www.badcaps.net/forum/troubl...itebook-840-g6
                              The board number matches even tho they say elitebook 840, hp reusing same board with different cpu etc?
                              Anyway it looks to be R369 in the boardview, but I havnt found it in the schematic pdf yet.
                              Thank for all the help once again!
                              edit: found it:
                              Click image for larger version  Name:	image.png Views:	0 Size:	204.0 KB ID:	3723619
                              edit2: also found the debug ones; R4866 however they are 50k, the one I removed looked to be 100k
                              • johansel
                                • Feb 2022
                                • 39
                                • colombia
                                #56
                                Good morning.
                                HP ZBook 14u G6
                                S/N: 5CG0236B99
                                • noname2024
                                  • Aug 2024
                                  • 295
                                  • CỎ MỸ XỊN
                                  #57
                                  Good morning.
                                  HP ZBook 14u G6
                                  S/N: 5CG0236B99
                                  try
                                  • johansel
                                    • Feb 2022
                                    • 39
                                    • colombia
                                    #58
                                    Originally posted by noname2024
                                    try
                                    I did the test but it didn't work and the fault persists.
                                    • hoaca388
                                      Badcaps
                                      • Jan 2022
                                      • 12431
                                      #59
                                      Good morning.
                                      HP ZBook 14u G6
                                      S/N: 5CG0236B99
                                      HP ZBook 14u G6 Mobile Workstation
                                      • yasin
                                        • Jan 2022
                                        • 14
                                        • iran
                                        #60
                                        hi. ineed bios and ec
                                        led power jack blinking
                                        zbook 14u g6
                                        SN 5cg014bk7r
                                        P N 6050A3022501
                                        • macabook
                                          by macabook
                                          🧩 Initial Issue
                                          07-24-2025, 02:17 PM
                                        • cr4zychriss
                                          by cr4zychriss
                                          • Rebrand: PC Specialist
                                          11-14-2025, 04:04 PM
                                        • pirati
                                          by pirati
                                          10-27-2025, 04:20 PM
                                        • Vesko356
                                          by Vesko356
                                          08-11-2023, 03:27 AM
                                        • zlr8r
                                          Hp Zbook Firefly 14 G10 - corrupted Bios's ? - please check
                                          by zlr8r
                                          Greetings
                                          I am hoping someone could have a check of my Hp Zbook Firefly 14 G10 , 2 x 32MB Bios files... (powers on / black screen).
                                          Serial Number: 5CG3202C16
                                          Product #/SKU: 739P0AV
                                          CT Number: PRTUE00WBI30YX
                                          Description: HP ZBook Firefly 14 inch G10
                                          BuildID: 23WWWGAZ602#SABU#DABU
                                          Feature Byte: 476J6S6b7B7M7Q7U7W7m7saBaEapaqauawbUbhcAfPgSguhKj4jhk8mEn7nVngpDpVpWpnpqprqMqkqz.G3
                                          MAC address not found.
                                          • I extracted both 32mb bios files (Main + EC). But when i run the main 32mb bios through MFIT.exe , it produces this error; ie:,
                                          10-28-2025, 01:56 PM
