Hello, I need the BIOS and EC BIOS for the HP Zbook 14u g6 sn:5CG9270YWL PROID 4YP13QV. A malicious repairman removed it from the notebook. I need a clean BIOS set with 256 MB BIOS and 128 MB EC. I kindly request your assistance.
HP ZBOOK 14U G6 Bios
Hello, when I updated the BIOS in post 2, the notebook turns on and the fans speed up, then it shuts down. It keeps doing this.
1. I used the 1.16MB EEPROM file. I wrote the 32MB file I found elsewhere to the second EEPROM. The notebook turned on and worked, but there was no sound even though the sound card drivers were installed. The sound settings section was closed.
2. I used the 1.16MB EEPROM file and wrote the 32MB file I found elsewhere to the second EEPROM. In this case, the Ethernet port is not working. When I plug in the RJ45, the lights come on, but it does not obtain an IP address.
There is no activity. What do you recommend I do?Comment
Hello, please clean the HP ZBook BIOS. Thank you.Attached FilesPremium supporters get full download access and other benefits.
Thread merged..next time look for a thread with the name and model, motherboard model of the laptop, and post there, if you can't find it, then make a new thread..
Type the laptop serial number, full name and model, motherboard model, etc.
read the forum rules..https://www.badcaps.net/forum/troubl...before-posting
I have an HP ZBook 14U G6 that no longer boots after a failed BIOS update.
Can someone help me please?
Model: HP ZBook 14U G6
Serial: 5CG01664M5
Board: 6050A3022501-MB-A01(A1)
Both files, 32mb and 16mb attached.
Thank you,
DavidAttached FilesPremium supporters get full download access and other benefits.
try..Attached FilesPremium supporters get full download access and other benefits.
If you have found our forum useful please consider supporting us. Subscribe for a small monthly fee and receive extra benefits including our boardview / schematic archive.
It only takes 1 minute:
https://www.badcaps.net/settings/subscriptionsComment
Hello, helpful experts, could you please clean the BIOS of the attached ZBook 14u G6? I couldn't find the ME file. Thank you for your help.Attached FilesPremium supporters get full download access and other benefits.
tryAttached FilesPremium supporters get full download access and other benefits.
HP Zbook 14u g6 6050A3022501-MB-A01(A1) sn 5CG9414HD6 ProdId 4YP13AV
help me please, need clear bios. I lost my BIOS and need firmware for two flash drives. Posts 2 and 17 didn't work. The LED on the first one lights up, but there's no response to the button. The orange LED on the second one blinks 5 times.Comment
post S/N Service Tag or SNIDHP Zbook 14u g6 6050A3022501-MB-A01(A1)
read the forum rules..https://www.badcaps.net/forum/troubl...before-postingComment
Where can I find the service tag?
sn 5CG9414HD6
Someone please help. Someone flashed the BIOS before me and it's faulty. The caps lock was blinking. After flashing anything from the internet, my orange power LED is blinking differently each time. There were 5 blinks, 4, 3, 2, and then the last one was 1.Comment
help to fix bios
SerialNumber:5CG9410D3M
HP ZBook 14u G6 vpro
attached ec + bios
tanksAttached FilesPremium supporters get full download access and other benefits.
Hello every one
I need to fix this file
Laptop caps lock 7 time blinking
Hp zbook 14 u g6
S/N 5CG9442PTOAttached FilesPremium supporters get full download access and other benefits.
by macabookHello everyone,
Channel: BIOS Requests ONLY!
07-24-2025, 02:17 PM -
by cr4zychrissHello everyone,
I have successfully used a CH341A programmer and can read/write/verify both flash chips, but using my backups/extractions has failed to restore power. The root cause is likely a corrupted Intel Management Engine (ME) region or an incompatible EC/BIOS pairing. System & Hardware Details- Barebone / Chassis: TongFang GK7MRFR
- MB: MB: GK5MP5X V1.0 Prod :GK5MRFV10T04201310281
- Rebrand: PC Specialist
by TopPopSorry for the long story. I have a Dell Latitude 5530 (i7) laptop (South Peak 15 MLK MB DDR4 203102-1 FK8VG$JA) with an admin BIOS password that I want to remove. Service Tag: HYKFPT3. Other than that the laptop worked OK.
I found a CH341A Black and went looking for the BIOS chip on the motherboard. After trying to read one chip that was a firmware chip but not the BIOS I think I found the BIOS chip labeled Winbond 25Q256JVEN. Altogether I think I found 4 different firmware chips in the laptop. The BIOS chip is a WSON8 6x8. I used the CH341A, NeoProgrammer, and a cheap pogo pin clip... -
by piratiHello everyone,
by DenizBu: https://pcsupport.lenovo.com/tr/tr/p...065tx/mp2br7d9
I have a Lenovo IdeaPad Gaming 3 16IAH7. When the device first arrived, there was no display at all.
I had the BIOS cleaned, but the issue was not resolved and there was still no image.
Later, I flashed a different BIOS dump from the same model. With this BIOS, the device boots and display works, but the GPU is not detected in the BIOS (RTX 3060 is missing).
After that, I tried to update the...-
- Loading...
