HP ZBOOK 14U G6 Bios
hi I have problem on bios hp zbook 14u g6, i try another bios but sound and battery not charging here old dumps
hp zbook 14u g6
motherboard/ 6050A3022501
SN/5CG0416BSCComment
Hello
I need help with a BIOS file for my laptop
current condition : when i turn on the Caps Lock LED blink once and laptop doses not boot
Attached my current Bios backup.
could someone please share a clean BIOS file for this board?
🖥️ Laptop Model: HP ZBook 14u G6
🔢 Serial Number: 5CG0010KY6
🔧 Product ID: 4YP13AV
🔢 Mother Board part Number: 6050a3022501-mb-a01Attached FilesComment
post merged..next time look for a thread with the name and model, motherboard model of the laptop, and post there, if you can't find it, then make a new thread..Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Every donation made will go towards server fees and maintenance costs.Comment
HP Zbook 14U G6
6050A3022501-MB-A01
SN : 5CG92914G2
ProdID : 4YP12AV
Please remove BIOS password, I have already tried HPUnlocker.Comment
Attached Files↵
https://www.badcaps.net/donateComment
Good morning.
Can you help me fix this BIOS?
It updated and stopped showing video.
HP ZBook 14u G6
S/N: 5CG0236B99Attached FilesComment
Hello, I would need some help with this bios. I have two machines with problems; will start with the first one. I will attach the original bios that I read, it has problems with blinking lights, sadly forgot how many but looked like bios issue so I tried to flash from post #17 here, and when I turn it on I get 7 blinks from caps lock, when I plug in the usb c charger the white charger led is on and then once I get a 6 blinks of orange. For the previous person with 7 blinks you said to check hardware; what should I check? I have plugged everything in except battery, ssd and wifi card; the laptop should work without those?
HP ZBook 14u G6
PID: 6TP69EA
SN: 5CG9507MX2
BID: 19WWCFBT601#SAK8#DAK8
MOBO: 6050A3022501-MB-A01(A1)
Thanks in advance!
HP ZBook 14u G6
PID: 6TP69EA
SN: 5CG9507MX2
Thanks in advance!Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Yes, those I had plugged in, but sadly I am getting the 7 blinks. I wanted to try the other bios files here but accidentally knocked one of the small black things (i think resistor) to the side and when I tried to place it back I accidentally lost it and cannot find it; does anyone has a boardview/schematic where I can find the value of it of it is possible to bridge it, or maybe take one from somewhere else on the board? It looked like there was similar ones at the debug pins.Comment
Yes, those I had plugged in, but sadly I am getting the 7 blinks. I wanted to try the other bios files here but accidentally knocked one of the small black things (i think resistor) to the side and when I tried to place it back I accidentally lost it and cannot find it; does anyone has a boardview/schematic where I can find the value of it of it is possible to bridge it, or maybe take one from somewhere else on the board? It looked like there was similar ones at the debug pins.Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Yes, attached pictures of what I accidentally lost; and how it should look based on the other same laptop I have.
How it should look:
Similar ones at debug port?
Got schematic from here:
https://www.badcaps.net/forum/troubl...itebook-840-g6
The board number matches even tho they say elitebook 840, hp reusing same board with different cpu etc?
Anyway it looks to be R369 in the boardview, but I havnt found it in the schematic pdf yet.
Thank for all the help once again!
edit: found it:
edit2: also found the debug ones; R4866 however they are 50k, the one I removed looked to be 100k
by macabookHello everyone,
🧩 Initial Issue- Board powers on (fans spin, keyboard lights up and can be adjusted, caps lock led lights), but no display or backlight
- External display (HDMI) shows
Channel: BIOS Requests ONLY!
07-24-2025, 02:17 PM -
by Vesko356First of all thanks to all of our members who have posted previously all methods posted here.
Operating system and OS version.If...-
by jbonavitaHi, my laptop wont boot at all
Some issues
Things I tried
1- Update / clear ME: Took the non working bios, made a backup, and did this: https://www.badcaps.net/forum/troubl...theory/trouble...-
by WahazHello,
I found 3 bios chips on the board, which I read with a bios programmer: two XMC model bios chips and a Winbond model bios chip. Each XMC model bios chip has two partitions named XM25QH128A [3.3V] and XT25F128A [3.3V]. And the Winbond model bios chip has three partitions named W25Q80BL 3.3V, W25Q80xV 3.3V and W25Q80DV 3.3V....-
- Loading...
