NM-C361 no VCCSA power MP2949A firmware
  • bushmann
    • Feb 2014
    • 149
    • Slovakia
    I have a problem with the power supply for the CPU.
    This motherboard had a burnt MP2949A.
    After exchanging for a new piece the same problem.
    I got the same board, but the functional one from which I used this chip and the board started working.
    Someone can't advise me if this chip does not need to be programmed before use but somehow set up.
    Thank you in advance for any help
  • bushmann
    • Feb 2014
    • 149
    • Slovakia
    Re: NM-C361 no VCCSA power MP2949A
    So I will answer myself.
    Yes, it must be programmed otherwise it will not work.
    This programmer can be used EVKT-USBI2C-02.
    https://www.monolithicpower.com/en/e...Dc2OS42MC4wLjA.
    • tomodachi
      • Apr 2012
      • 612
      • Turkey
      You learn a lot everyday... I didn't know that. Thanks for sharing
      • bushmann
        • Feb 2014
        • 149
        • Slovakia
        Today I replace this IC to new on the board NM-C362 and all work fine.
        Not need programming IC.
        This motherboard have Intel and Nvidia GPU.
        Motherboard NM-C361 have only Nvidia.
        Maybe need programing only, if not use Intel GPU.
        • Maxim Skridonenko
          • Apr 2018
          • 17
          • Украина
          I think that you bought a not new chip, and its firmware matched for this MB sir
          seen this very often
          • andreynew1
            • Jul 2021
            • 19
            • Ukraine
            If you look at the NM-C362 scheme.
            The IT8586E has access via the I2C bus (EC_SMB_DA, 3 EC_SMB_CK3) to the two ICs LV5075BGQV and MP2949AGQKT. Maybe there is part of the firmware for the MP2949AGQKT in the program for the IT8586E.
            And as an option for NM-C362, is the erased or not ICs MP2949AGQKT.
            IT8586E at startup configures MP2949AGQKT (EC_SMB_DA, 3 EC_SMB_CK3) in any case.
            • wacd
              • Jun 2014
              • 37
              We should start saving dump firmwares of MP series pmic's from working laptops.
              • hopkok
                • Oct 2014
                • 179
                • Slovakia
                Hi bros, anyone here succesfully programmed MP2949A firmware in NM-C361 or know where to get dump for try?
                • hopkok
                  • Oct 2014
                  • 179
                  • Slovakia
                  Hi, I finally succesfully programed MP2949A on Lenovo L340 using SVOD 4.
                  • andreynew1
                    • Jul 2021
                    • 19
                    • Ukraine
                    MP2949A FIRMWARE attachment, motherboard FG541_FG741_NM-C362_REV1_0
                    • mon2
                      • Dec 2019
                      • 14737
                      Excellent research and updates by everyone on this thread!! Will be helpful to future readers.
                      Could you please attempt to attach the dump again? Do not see it in your last post. Perhaps zip or winrar the memory file.
                      • andreynew1
                        • Jul 2021
                        • 19
                        • Ukraine
                        FG541_FG741_NM-C362_REV1_0.zip​
                        • testinglaptops
                          • Oct 2022
                          • 86
                          • United Arab Emirates
                          Hello, I'm using vertyanov successor Base 2. can you I program MS2949A with this programmer? can you share how find SDA SCL - RX TX pinout on vertyanov successor? Thank You
                          • andreynew1
                            • Jul 2021
                            • 19
                            • Ukraine
                            MP2949A FIRMWARE attachment,motherboard EG530_NM-B671_REV_1_0.rar
                            • andreynew1
                              • Jul 2021
                              • 19
                              • Ukraine
                              • LotteGZO
                                • Sep 2024
                                • 7
                                • Thailand
                                Do tou have NM-C871 MP2949A FIRMWARE​?
                                • andreynew1
                                  • Jul 2021
                                  • 19
                                  • Ukraine
                                  Try this one. nm_c871_mp2949a.rar
                                  • vinit bhandari
                                    • Feb 2019
                                    • 5
                                    • india
                                    I ALSO NEED NM-C371 MPS FIRMWARE DOES ANYONE HAVE ? SHARE PLZ
                                    • peste
                                      • Dec 2016
                                      • 13793
                                      • ROMANIA
                                      post S/N, full name and model, motherboard model, TYPE,etc.
                                      post the contents of the bios chip even if it is corrupted..
                                      • Wachenaggo
                                        • Jul 2018
                                        • 66
                                        • Philippines
                                        how do you connect that?? you have instruction to do that??
                                        • PantherDave
                                          by PantherDave
                                          Hi all!
                                          05-29-2024, 02:01 PM
                                        • GLISIT
                                          by GLISIT
                                          01-16-2025, 02:29 PM
                                          by sam_sam_sam
                                          03-31-2024, 02:12 PM
