ThinkBook 15 G2 ITL bios password
  • Mx7Nine
    • Jul 2020
    • 15
    #61
    Hi all. Could someone help me remove the BIOS password from this dump please.
    Thinkbook 15 G2 ITL
    S/N: MP1YHV4Z
    MB: LA-K052P Rev 1.0
    • volinakis
      • Jan 2021
      • 2790
      • N/A
      #62
      Thinkbook 15 G2 ITL
      S/N: MP1YHV4Z
      write only 16Mb file.
      • Mx7Nine
        • Jul 2020
        • 15
        #63
        Perfect, thank you. And I think I've finally figured out how to find it in the file so I wont have to ask again.
        • volinakis
          • Jan 2021
          • 2790
          • N/A
          #64
          you are welcome. Yep, comparing my file with your original file you can figure out where it is. Usually for this machine pass is in VSS2 Store/padding but you have to merge both files to open with UEFITool.
          • zlr8r
            • Feb 2023
            • 82
            Originally posted by zlr8r
            Hey guys, i would be grateful for any assistance with this board bios files.
            Original Problem: ESC, CAPS and NUMLOCK lights on. Batt light flashing. Wont power on to Bios. Suspect it is corrupted.
            What I tried: Replaced a noticeably hot ic - which seems to have cured the flashing amber batt light, as it is now white, but still no boot.
            I also replaced the BQ chip just for the hell of it - no difference. Battery is Good. Bios battery is good. PSU is good.
            I've attached dumps from #1 Bios: XMC 0H64AHIC + #2 Bios: 0H128AHIC (might be ...AHIG) see pics
            I see a third bios chip, Winbond 25Q80DVNIG over near the USB-C ports, I uploaded that Bios too.
            Could someone check my dumps please , or upload replacements I can use to flash back onto my board ?
            Model: Lenovo ThinkBook 15 G2 ITL
            Mfg: 21/12/2021
            S/N: MP239D8M
            MTM: 20VE00RPUK
            MO: MPNXB1C27061
            Factory ID: PRC4
            Many Thanks
            can someone please check these dumps are even valid, before i go any further trying to repair the board ? thanks
            see post
            https://www.badcaps.net/forum/troubl...64#post3674064
            • Jovica123
              • Oct 2017
              • 80
              • N/A
              #66
              Hi, can you help me remove the BIOS password from this dump,or tell me what the password is ?
              Thinkbook 15 G2 ITL
              S/N: MP23XB4D
              MB: LA-K051P Rev 1B
              • hardware1
                • Sep 2021
                • 2943
                • N/A
                #67
                Thinkbook 15 G2 ITL
                S/N: MP23XB4D
                MB: LA-K051P Rev 1B
                Try this Password:
                21ELEMENTE
                all donations are welcome,
                • Jovica123
                  • Oct 2017
                  • 80
                  • N/A
                  #68
                  Try this Password:
                  21ELEMENTE
                  After reinstalling the chips, the laptop no longer powers on. The symptoms are as follows:
                  • The power button blinks in the following pattern: stays lit for about 2 seconds, then turns off for about 10 seconds, and repeats in a loop.
                  • I left the laptop in this state for at least 10 minutes – nothing changed, it still keeps blinking.
                  • The screen remains black, with no sign of POST.
                  Note: This is not my first time working with BIOS chips. I have experience with programming and soldering, so I’m not sure what could have gone wrong in this case.
                  Does anyone know exactly what this blinking pattern means, and whether it indicates a corrupted BIOS or possibly another type of fault?
                  Should I open a new thread for this issue, or is it okay to ask here?
                  • hardware1
                    • Sep 2021
                    • 2943
                    • N/A
                    #69
                    You didn't erase the chip, so the problem could be a bad soldering, missing component or a broken (chip even if you can still read and write it).
                    • Jovica123
                      • Oct 2017
                      • 80
                      • N/A
                      #70
                      No, I did not erase the chip. I even desoldered and read both chips again, then compared the dumps with the ones I had previously posted here on the forum – the contents are identical.
                      As for my soldering work, I’m attaching a photo below so you can see it yourself. I’m confident that I haven’t accidentally removed any components during the desoldering/soldering process.
                      If you believe the chips might be damaged, would it be possible to replace the QH64 and QH128 with Winbond 25Q64 and Winbond 25Q128 instead?
                      Are these fully compatible in terms of pinout, voltage, and performance, or could there be any issues when using them as replacements on this board?
                      And of course, should I actually go ahead and replace them, or would you recommend further testing before doing so?
                      • hardware1
                        • Sep 2021
                        • 2943
                        • N/A
                        #71
                        Is that a Capacitor or just a light reflection?
                        According to the Schematic, Boradview and another similar board picture, it should be a Resistor in that place.
                        Everything else looks the same.
                        • Jovica123
                          • Oct 2017
                          • 80
                          • N/A
                          #72
                          You’re right, there should be a resistor there. I accidentally moved it, and when I put it back, I placed it upside down, so the white bottom side was facing up. I’ve now corrected it – great observation!
                          What do you think could still be the issue? The only thing I’m certain of is that the BIOS battery was connected when I removed the chips. However, this has never caused problems for me before, and I doubt it’s the case this time either.
                          And just a correction regarding the power button blinking pattern I mentioned earlier: the button stays lit for 5 seconds, then turns off for 5 seconds, and repeats like that.
                          • hardware1
                            • Sep 2021
                            • 2943
                            • N/A
                            #73
                            Yes, you can use Winbond W25Q64JV/W25Q64FV and W25Q128JV/W25Q128FV.
                            Okay, I can't see anything else.
                            • Jovica123
                              • Oct 2017
                              • 80
                              • N/A
                              #74
                              In the end, it turned out that the problem was not related to the BIOS at all, but to the motherboard itself.
                              When I first received the laptop for repair, I powered it on and saw that it was locked. I turned it off and began the unlocking process. However, after I first removed both chips, read their contents, and soldered them back onto the board, on the next power-on attempt the laptop would no longer display an image (power LED stays on for 5 seconds, off for 5 seconds).
                              This morning, out of curiosity, I decided to try again. I noticed that the CPU was heating up, so I thought everything was fine. However, on the second power-on – after connecting the display – the laptop again refused to start.
                              I decided to try one method: I placed the motherboard in the fridge for 15 minutes, then powered it on again. Amazingly, the laptop started, displayed an image, and I shut it down using the power button. When I tried to power it on again, it wouldn’t start.
                              Is there anything that can be done in this case?
                              • Lurky
                                • Feb 2021
                                • 26
                                • Rwanda
                                #75
                                Hello
                                NEED HELP WITH THINKBOOK 15 G2 BIOS NO POST
                                THINKBOOK_15_G2_ITL_FLV35_LA_K052P_REV_1_0
                                SN : MP26AYVK
                                • peste
                                  peste commented
                                  Editing a comment
                                  post merged...next time look for a thread with the name and model, motherboard model of the laptop, and post there, if you can't find it, then make a new thread..
                              • peste
                                • 13142
                                • ROMANIA
                                #76
                                Originally posted by Lurky
                                Hello
                                SN : MP26AYVK
                                post S/N, full name and model, motherboard model, TYPE,etc.
                                • Lurky
                                  • Feb 2021
                                  • 26
                                  • Rwanda
                                  #77
                                  Thanks , i will check Next time
                                  Model : LENOVO THINKBOOK 15 G2 ITL
                                  SN: MP26AYVK.
                                  • Lover1abd
                                    • May 2023
                                    • 14
                                    Lenovo v14 G2 ITL
                                    MO : PF9XB2511021
                                    S/n : PF3Q49ZX
                                    please need admin password
                                    • m1ch43lzm
                                      • Mar 2019
                                      • 616
                                      • Peru
                                      #79
                                      Originally posted by Lover1abd
                                      Lenovo v14 G2 ITL
                                      MO : PF9XB2511021
                                      S/n : PF3Q49ZX
                                      Please upload BIOS backup as .zip or .rar
