HP Elitebook 840 G6 bios password
help unlock bios password need to install new os because ssd defective
model : hp elitebook 840-g6
sn: 5CG031061PC
advance thanks for the helpAttached FilesComment
Attached Files↵
https://www.badcaps.net/donateComment
please unlock biospassword .tks
SN# 5CG9525SXG
ProdID 7KK23UT#ABAAttached FilesComment
First boot load bios factory defaults, save and exit and then at the next boot disable security options
You must fill your DMI manually.Attached FilesComment
Hello guys,
Need help to recover bios. Laptop start, blows fast, black screen and stop, again, again... Sometimes turn on with caps lock only turned on (no flashing) and no activity.
Serial Number : 5CG0103K35
Product Number : 4WG20AV
Description : HP EliteBook 840/846 G6
Hello guys,
Description : HP EliteBook 840/846 G6Attached FilesComment
I reconnect the cmos battery, the battery, and back cover the pc doesn't boot anymore.
no LEDs anywhere. I decide to remove the bottom cover and the pc boots up, but nothing appears on the screen.
I disconnect the battery, discharge the PC for 30 seconds, then connect the charger and press the power button: the PC starts up the fan blows hard but nothing is displayed during several seconds and finally the PC shuts down.
Orange LED on charging port, no longer possible to switch on laptop.Comment
I also tried your bios again this morning with another program. The pc did several startups, with recovery of its identity from the Embedded Controller due to data mismatch. After several restart corruption IME firmware so continue to complete the full recovery process on the Intel ME... after several restart the laptop seems to be behaving normally again. I go to the bios and reset the security settings and save. Laptop restart aks to confirm, etc...Everything seems to be back to normal.
Serial Number : 5CG016CLH4
Product Number : 4WG30AV
hello, can someone help me?i have bios pass.Attached FilesComment
Channel: BIOS Requests ONLY!
by traxformaniaHello,
I'm using TONGFANG "GM7TG7P" model laptop for over 3 years and i'm entering the same bios administrator password everyday. My laptop has Aptio BIOS (American Megatrends, AMI).
But today it's not accepting my password. I'm %100 sure i'm entering the correct password.
I'm trying to reset my bios without success.
I tried :
-I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries... -
by tlindiSublect line continuation: ... Jaguar IDS PC aka Panasonic
>Read BIOS guides, methods, resources and tools
Ack
>Try the method at BIOS guides, methods, resources and tools before requesting help
Ack
>Explain you were not able to succeed with the methods at BIOS guides, methods, resources and tools
python ./main.py "/mnt/c/temp/205605f9e1b60403a41787efeffe9cad-flas_maybe5.BIN" --output-dir "/mnt/c/temp/205605f9e1b60403a41787efeffe9cad-flas_maybe5.txt"
by NopslideHello everyone, I come here to tell you my problem regarding the power-on password. It is not a bios reset demand, and i can't have any access to windows. This is the bios and power-on password that is blocking all other things.
My Omen 15-dh0052nf purchased second-hand was configured with the bios password upon purchase (very simple password :P ).
Having decided to sell it in order to get something more powerful, I reset all BIOS settings and set a blank administrator password. But the power-on password cannot be changed to a blank one so I let the actual password set....-
by WutruHi guys,
If someone would be able to provide some expertise, I'd be very grateful.
BIOS Corruption - Cause
So I managed to corrupt my machine by installing linux and enrolling custom secure boot keys. I did choose to enroll the Microsoft keys as well, to prevent any potential bricking due to 3rd party drivers from HP being signed with those keys.
After doing that, and rebooting(it did boot, powerLED, fanspin etc.), the laptop did not give any video output on the LCD or video connectors. I think I was able to get in BIOS and trigger the beeper by pressing ESC....-
- Loading...
