HP BIOS unlock tool
  • Expired
    • Feb 2023
    • 34
    Re: HP BIOS unlock tool
    Originally posted by kolabi
    try this one
    Code:
    After entering BIOS, go to security tab and reset security settings to default!
    Model: HP EliteBook 745 G5
    Serial: 5CG93100X6
    Mac:
    SKIJ: 31JP50EA#ABU
    auildld:
    Board PGWJEOOWBCK3W2
    Feature byte: 3X476J6S6b787H7M7Q7W7m7saBaEapaqauawbUbhcAdUdpdqhKhkjh.F5
    COA: J4XFW-PN3K20FX83-2JBP8-RX8XC
    ME version: 25525525565535
    try and reply with results
    • hoaca388
      Badcaps
      • Jan 2022
      • 12419
      #1482
      try this one
      Your problem is that you can't extract the complete bios file, you just need to extract the bios and use RC unlocker to be fine
      • kolabi
        • Apr 2023
        • 12
        • France
        #1483
        Originally posted by Expired
        Code:
        Serial: 5CG93100X6
        Mac:
        SKIJ: 31JP50EA#ABU
        auildld:
        tried it , now does not boot or anything (dead)
        • Ademerlac
          • Jul 2023
          • 5
          • Poland
          #1484
          I put HPunlocker on c: but I still have an error: Failed to executed script HPunlocker"
          Plese help.
          • Ademerlac
            • Jul 2023
            • 5
            • Poland
            #1485
            Sorry, did it wrong way
            • Ademerlac
              • Jul 2023
              • 5
              • Poland
              #1486
              I have the trouble to reset my password.
              Unfortunately after used HpUnlocker , the laptop do not start!
              My 2 files bios are attached.
              Please help me to find out what's wrong?
              Is there anything what Im doing wrong?
              Please help
              • hoaca388
                Badcaps
                • Jan 2022
                • 12419
                #1487
                Please help
                Find RC Unlocker .
                • uritech
                  • Jun 2022
                  • Mexico
                  #1488
                  HI, someone can help me to disable absolute persistence module, here are both dump 16MB and 32MB.
                  • hoaca388
                    Badcaps
                    • Jan 2022
                    • 12419
                    #1489
                    Post your request in its correct topic with the serial number.
                      • 22100
                      • kaltmond
                        Default
                        • 13
                        i've a Zbook G9 with Xe and discrete graphic installed. In BIOS there is only UMA and Hybrid option available, so is there a way to unlock the discrete card alone?
                        In my G7 i can set disdrete in BIOS and completely disable optimus, but in G9 no such option available.
                        Ive tried with UEFITool and IFR Extractor with RU.efi to change a Variable but ended with a blackscreen with backlight. reset cmos back to normal again.
                        Any help to unlock the hidden option is appreciated. THX in advance. XD
                        • Slimat
                          • Nov 2023
                          • 10
                          Hi all, real newbie here - lots to read on this topic, but before I get my first problem, which is sure to happen... I just wanted to say thanks to everyone who has worked so hard on this and provided so much fantastic information
                          • RethoricalCheese
                            • Mar 2013
                            • 1519
                            • Estonia
                            #1493
                            Your first problem is that you should be using RCUnlocker instead of this outdated tool
                            • Arkangelus
                              • Feb 2021
                              • 20
                              • Chile
                              #1494
                              I tested this tool with an HP 420 and it removed the password without problems.
                              Thanks a lot!!!
                              • GAV86
                                • Jan 2024
                                Hello. I have a problem with the administrator password on the HP Probook 650 G2. I tried with HPUnlocker and RCUnlocker and the laptop does not work. It turns on, after 30 seconds the fan spins strongly, the screen is always black. Can anyone help me?
                                I returned the password-protected dump, and everything was the same. It seems I initially read the firmware incorrectly...​
                                  Vesko356 commented
                                  Editing a comment
                                  Should work, most probably you didn't program or solder the chip properly. Check surrounding area for moved/knocked components.
                                  Don't use a clip, erase the chip before programming the unlocked dump, use verification.
                              • GAV86
                                • Jan 2024
                                I desoldered the chip and soldered it to the programmer board. I tried other firmware with which the laptop does not respond to the power button. At the same time, my firmware turns it on a little, but with a black screen. Visually I do not see any damaged components and the chip is sealed correctly. When turned on, there is a 3.3V (8 pin) power supply. I'm interested in the correctness of my dump, I'm afraid there's something wrong there.​
                                • DAHOUD
                                  • Sep 2023
                                  • 36
                                  • Tanzania
                                  #1497
                                  I tried to use RC unlocker but come with this error Help please someone with idea
                                    Vesko356 commented
                                    Editing a comment
                                    Use the search engine before asking questions. It has already been commented on in earlier posts.
                                    You MUST:
                                    • Use search function in case someone already answered your request
                                • areylo
                                  • Jan 2024
                                  • Česko
                                  #1498
                                  Could someone help me what to do and how to do it? I bought an HP probook 650g3 laptop and found a locked bios at home. I tried various tutorials, none of them helped. I finally found a forum where I could unlock the bios. I downloaded RCUnlocker v1.0, I move the bin file to it, it says bios unlocked. After restarting the laptop, where I try f10 in the bios, it still needs a password. What am I doing wrong?
                                  Click image for larger versionName:	rcunlocker.pngViews:	0Size:	102.4 KBID:	3204361
                                    Vesko356 commented
                                    Editing a comment
                                    Read the rules please
                                    You MUST:
                                    • Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
                                    • Provide a BIOS/EC dump if possible
                                • areylo
                                  • Jan 2024
                                  • Česko
                                  #1499
                                  Machine model number: X4N07AV
                                  Serial number: 5CG7261RTW
                                  board model number: HP 82AA PGDQK00WB832Y2 KBC Version 49.35
                                  bios: P83 Ver. 01.03 5CG7261RTW HPQOEM - 0
                                    Vesko356 commented
                                    Editing a comment
                                    Upload your original bios backup
                                • areylo
                                  • Jan 2024
                                  • Česko
                                  #1500
                                  I don't have any original bios backup. Could I get some advice here or some post here how can I do this?
                                • salim5566
                                  loking for bio tool that hve all feature like ps5 bios and laptop bios unlock and repair 1 tool can do all please good tool?
                                  by salim5566
                                  Hi guys i like to buy tool that automatic unlock bios or find password also can flash and repair bios ic, looking for good tool have good software that have 1 click and unlock bios any recommend good tool? looking for sony ps5 and and laptop bios
                                  06-26-2025, 03:25 PM
                                • to5it0
                                  by to5it0
                                  10-24-2025, 01:35 AM
                                • zenius
                                  by zenius
                                  12-08-2024, 06:13 AM
                                • Citymin
                                  by Citymin
                                  S/N : 5RNK9FFT70...
                                  08-05-2025, 05:12 AM
                                • m1ch43lzm
                                  by m1ch43lzm
                                  Hi everyone
                                  09-06-2025, 05:47 PM
