HP BIOS unlock tool
    VIP Moderator
    • Aug 2018
    • 4386
    • Bulgaria 🇧🇬
    #1441
    Re: HP BIOS unlock tool
    Originally posted by tmax
    hello my name is tom I am new I have a lost hp elitebook pass I read the mix25l3255 chip I did several tests in hex in dump but it does not want to skip the security who could help me please
    Welcome to the Badcaps.net Forums.
    Add full model name of the device, serial number, and attach the bios dump to your request.
    Read forum rules please.
    BIOS guides, methods, resources and tools
    Become a Badcaps supporter
    Thanks to all supporters.​
    • tmax
      • Apr 2023
      • angleterr
      #1442
      Hello sir, I'm sorry
      hp elitbook 645 g9 notebook pc
      5cd248fzrh
      • tmax
        • Apr 2023
        • angleterr
        #1443
        file is here thanks all
          VIP Moderator
          • Aug 2018
          • 4386
          • Bulgaria 🇧🇬
          #1444
          No, 362.0 KB is not good enough for a good read. Try again.
          • tmax
            • Apr 2023
            • angleterr
            #1445
            I think my reading is good so I think I am not on the eeprom any info please
              VIP Moderator
              • Aug 2018
              • 4386
              • Bulgaria 🇧🇬
              #1446
              No, as I said it's not good at all. This model should have 32MB bios.
              • 0x888816
                • Mar 2023
                • 5
                Does this unlock look suspicious? This is on an EliteBook 745 G3. I tried booting with the unlocked rom but all I got was black screen with power & caps lock light on.
                I also tried the unlock on a rom from a water damaged 755 G5 and the unlock "looks" much more believable. Too bad I can't boot this one up.
                • RethoricalCheese
                  • Mar 2013
                  • 1519
                  • Estonia
                  #1448
                  Yes, your first read is bad. Did you verify what you read?
                  Oh and thatswhy RCUnlocker is the one to use. It will kinda let you know if you have a bad read.
                  • 0x888816
                    • Mar 2023
                    • 5
                    Ah ok I was only aware of HPUnlocker. I'll re-read & verify the rom and try RCUnlocker tomorrow. Thanks.
                    • RethoricalCheese
                      • Mar 2013
                      • 1519
                      • Estonia
                      #1450
                      If you already messed up the first read and then wrote a faulty file then it's no use. Already corrupted.
                      • 0x888816
                        • Mar 2023
                        • 5
                        I wrote my "read1.bin" back to the rom and it is booting. Is my read actually bad?
                        • RethoricalCheese
                          • Mar 2013
                          • 1519
                          • Estonia
                          #1452
                          Probably using Ch341A?
                          I guess it fails to read/write second half of the file properly so that would explain it.
                          Try reading and verifying, see if it passes.
                          • 0x888816
                            • Mar 2023
                            • 5
                            Yes I am using CH431A
                            I have a new read which I also verified. Checksum is the same as my 2 original reads.
                              VIP Moderator
                              • Aug 2018
                              • 4386
                              • Bulgaria 🇧🇬
                              #1454
                              You just chose the wrong chip - U366, that's your problem. It is near the RTC battery. The password is in the other with board positional name U365, located next to the CPU fan. Upload a dump of it here and I'll remove the password. Read it twice and compare the contents beforehand.
                              • 0x888816
                                • Mar 2023
                                • 5
                                Thank you RCUnlocker recognized it and unlocked it BUT I accidentally made a huge mess while soldering and now it wont boot into bios
                                My immediate repair didn't work so I'll have to get my multimeter out and figure out what's going on
                                • animorca11
                                  • Apr 2023
                                  • 8
                                  Hello Brother, Can you please help i Managed to read the BIOS finally, can you please unlock it
                                    VIP Moderator
                                    • Aug 2018
                                    • 4386
                                    • Bulgaria 🇧🇬
                                    #1457
                                    Why don't you use the tool yourself? BIOS guides, methods, resources and tools
                                    Next time don't post your request in two threads at the same time.
                                    Find the topic for the specific laptop model and post a request there.
                                    This thread is for requests in case you didn't succeed on your own or the tool can't unlock the dump.
                                    Read the rules.
                                    RULES UPDATE for BIOS requests/offers *AVOID BANNING, READ BEFORE POSTING*:
                                    • Mojtabasultani
                                      Soulless
                                      • Jan 2020
                                      • Afghanistan
                                      #1458
                                      Hello Everybody:
                                      I am try to open the Hp Bios Unlock Tool i have received an error, in Win 10 Pro 64b.
                                      Thankyou very much.
                                        VIP Moderator
                                        • Aug 2018
                                        • 4386
                                        • Bulgaria 🇧🇬
                                        #1459
                                        Originally posted by Mojtabasultani
                                        Hello Everybody:
                                        Thankyou very much.
                                        Read the rules before posting:
                                        Use the search engine and read the thread carefully, especially post #1:
                                        When you have your dump, just drag and drop your file on my HPUnlocker tool and it will create a new file. It will add "_unlocked" to the name of your locked file.
                                        https://www.badcaps.net/forum/showth...55#post1203555
                                        • aldagale83
                                          • Apr 2023
                                          • Guatemala
                                          #1460
                                          Hi. Im new with this. I want to unlock an HP 455 G7 Bios. Can you help. Sorry for my english. Im from Guatemala.
                                          • salim5566
                                            loking for bio tool that hve all feature like ps5 bios and laptop bios unlock and repair 1 tool can do all please good tool?
                                            by salim5566
                                            Hi guys i like to buy tool that automatic unlock bios or find password also can flash and repair bios ic, looking for good tool have good software that have 1 click and unlock bios any recommend good tool? looking for sony ps5 and and laptop bios
                                            06-26-2025, 03:25 PM
                                          • to5it0
                                            by to5it0
                                            10-24-2025, 01:35 AM
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
                                          • Citymin
                                            by Citymin
                                            S/N : 5RNK9FFT70...
                                            08-05-2025, 05:12 AM
                                          • m1ch43lzm
                                            by m1ch43lzm
                                            Hi everyone
                                            09-06-2025, 05:47 PM
