HP BIOS unlock tool
Re: HP BIOS unlock tool
Log in as guest user and reset security settings.
Or maybe try using RCUnlocker. HPUnlocker is a very outdated.Comment
Guest user will not allow you to reset security. I have alteady fixed it by setting a new Administrator password and then deleteing the user that way and then clearing the BIOS Admin password again.
I would argue with that because that's the way I do it. But since I have never seen your exact case...Comment
No. And please, always try RCUnlocker first because it has error handlings but HPUnlocker doesn't.Comment
Hello. Please help me reset the bios password, I did all the dumps. I can't do it on my own. Well, or at least tell me the right direction where to look.Attached Filesif you find these attachements useful please consider making a small donation to the site
@alimcorp
Only U365 is needed, enter MPM after unlocking.
MPM Product information:
1. Feature Byte: 3X476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUbhcAdUdpdqfPhKhkjhk8.gn
2. Build Id: 19WWTLCT601#SACB#DACB
3. Serial Number: 5CG0257WZB
4. SKU Number: 8ML12ES#ACB
5. Product Family: 103C_5336AN HP EliteBook
6. SB CT Number: PJBVR00WBDV60B
7. Product Name: HP EliteBook 745 G6
Note: The following product information must be re-programmed into the system board.
The (Feature Byte) is case sensitive and do not leave any blanks while filling the Build Id.Comment
Are you sure it's unlocked? There are only 7 differences here.@alimcorp
I mean only 7 bytes are different between the original dump and your unlocked one.
Yes, I flashed it, installed it, there is no password.
Now I enter a long line Feature Byte. Is there really a gap there? There is no space in your screenshot, but there is one in the text view. Please clarify.Comment
@alimcorpI mean only 7 bytes are different between the original dump and your unlocked one.
It is very easy to add MPM data
https://www.youtube.com/watch?v=qSTKvQnUzPEComment
I figured out how to change MPM data, I have a question about Feature Byte. Is there a blank (space) there or not?
3X476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUbhcAdUdpdqfPhKhkjhk8.gn or 3X476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUbhcAdUdpdqfPhKhkjhk8.gn ?Comment
Exactly, that's why this option for me is the best, the BIOS remains within the original standards, only the MPM data is temporarily turned off.Comment
I've done everything. And why is the red line "system is booting in manufacturing program mode" now shown at the top? What does this mean?Comment
by salim5566Hi guys i like to buy tool that automatic unlock bios or find password also can flash and repair bios ic, looking for good tool have good software that have 1 click and unlock bios any recommend good tool? looking for sony ps5 and and laptop bios
Thanks-
Channel: BIOS Requests ONLY!
by to5it0Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
I have opened the laptop and identified the main BIOS chip...2 Photos-
by CityminHi all,
S/N : 5RNK9FFT70...-
by m1ch43lzmHi everyone
There's also an extra OTP Secu.R...-
- Loading...
