HP BIOS unlock tool
  • RethoricalCheese
    • Mar 2013
    • 1517
    • Estonia
    #81
    Re: HP BIOS unlock tool
    Always the larger one. 25Q128A is 128Mb, 25Q16DVSIG is 16Mb. So 25Q128A is the one you need to work on.
    • tlfrance
      • Jan 2020
      • 18
      • france
      #82
      Originally posted by GabTal
      Hi everyone, i need help.
      I have a second-hand elitebook 850 g1 with bios locked by password.
      Understood that i need to unlock the BIOS is the ch431a programmer+soip8 with the software to dump my own bios file, to reprogram it and at last flash it. But i see on the motherboard two chips. Which is the correct one? I need to reprogram both bios?
      I've attached the img to be more clear.
      Thanks everyone
      Hello. I guess it is the chip with the orange dot on the left on your picture
        VIP Moderator
        • Aug 2018
        • 4386
        • Bulgaria 🇧🇬
        #83
        Thanks everyone
        Left one (with the pink dot on it) 25Q128A 13EC0 - you need to read this chip only.
        Become a Badcaps supporter
        Thanks to all supporters.
        • hallo51
          • Sep 2019
          first thanks for the great support here !
          A short feedback, the unlock with the provided file worked perfectly on my HP Probook 470 G2.
          Best,
          hallo51
          • tlfrance
            • Jan 2020
            • 18
            • france
            #85
            Originally posted by tlfrance
            Thanks for help. I saw 2 different ch341a programmers (black pcb and green pcb) . Difference seems around voltage (5v for black , 3,3 v for green). Which one should I take?
            I'll buy this https://rover.ebay.com/rover/0/0/0?m...2F153306934960
            Hope it will work for my 840 g3 bios
            • grzesiek3108
              • Jun 2019
              • 10
              • Poland
              #86
              840 G3 i5 cpu, Desolder W25q128, puted on EZP, read bios .bin, just drag and drop 16MB bin on your .exe, erase chip and write .unlocked.bin
              25min works fine. Great job.
              Can u tell me how this tool works ? Thx verry much
              @RethoricalCheese
              • RethoricalCheese
                • Mar 2013
                • 1517
                • Estonia
                #87
                It just uses some keywords to find the password area and deletes (writes 0xFF-s) a part of it.
                Planning on an update to make it a bit more user-friendly. Mostly to display an error message when somebody wants to unlock an unverified/broken bios dump.
                But it takes some time, I have other projects to finish first.
                • GabTal
                  • Jun 2019
                  • Italia
                  #88
                  Thanks, I'm waiting for the programmer I've just bought. Now the last question is: how can I know which is the voltage of the bios? Googling I found some datasheet which says it's 1.8 and another one that's 3.0.*
                  • grzesiek3108
                    • Jun 2019
                    • 10
                    • Poland
                    #89
                    Probably 3V , but you do not damage chip if its 1.8V (at least i never did) just programmer wont recognize it.
                    @RethoricalCheese Thx again for explain. I used try HxD when ive gote several SMC.bin files delivered from Hp support to figure out how to create it for myself, but never did
                    Confirmed : Probook 650 g1 i5 cpu, Desolder, puted on EZP, read bios .bin, just drag and drop .bin dump on your .exe, erase chip and write new created .unlocked.bin
                    Works great.
                    • RethoricalCheese
                      • Mar 2013
                      • 1517
                      • Estonia
                      #90
                      I know how SMC.bin files work but since I am unable to sign them without help from HP, it is useless knowledge. Right now editing bios is what works and is fast/easy enough for most people.
                      • tinto
                        • Jul 2017
                        • 74
                        • serbia
                        #91
                        work fine on my 2pcs HP 820 G2, but bios screen is little slower...when tap F10 i wait for 4,5 sec to open bios.... but works OK
                        very good job
                        thanks RethoricalCheese
                        • RethoricalCheese
                          • Mar 2013
                          • 1517
                          • Estonia
                          #92
                          very good job
                          Try updating BIOS to latest. Should fix that problem for you.
                          It seems to be slow on some older bios versions.
                          • gabucis
                            • Oct 2019
                            • 13
                            • united kingdom
                            #93
                            Originally posted by peste
                            try this..
                            Hi have tried that also ordered new chip all it does 3 long beeps and 2 short have flashed smaller chip too no change do you think motherboard is damaged?
                            • jg007
                              • Jan 2020
                              • uk
                              #94
                              Hi guys a complete n00b here.
                              I will attempt to flash my locked Elitebook 840 G1 over the weekend and I have a question.
                              If I understand correctly I just need to:
                              1. Get the bios dump from my laptop
                              2. Use the HPUnlocker tool located on the first page of this topic
                              3. Write the dump back to the bios chip
                              Do I need to worry about the ME region at all? Saw some posts mentioning you need to clean it? Or does the unlock tool already do this?
                                VIP Moderator
                                • Aug 2018
                                • 4386
                                • Bulgaria 🇧🇬
                                #95
                                1/2/3 - Yes
                                Don't worry about Me region, the tool doesn't change it, and since the bios is from your machine there is no need to alter the Me region, just write the unlocked bin file back to bios chip and you are good to go.
                                • jg007
                                  • Jan 2020
                                  • uk
                                  #96
                                  Originally posted by Vesko356
                                  1/2/3 - Yes
                                  Great, thanks!
                                  I'm thinking of using the ME Analyzer just to confirm the read did not corrupt the bios dump.
                                  Is there a way of confirming that the bios is really unlocked before I write it back to the chip?
                                    VIP Moderator
                                    • Aug 2018
                                    • 4386
                                    • Bulgaria 🇧🇬
                                    #97
                                    Great, thanks!
                                    This is a good practice, also you can read the chip twice and compare both dumps with Total Commander, just to make sure the dump is OK.
                                    There is no need to do that, the tooll is doing the job perfectly.
                                    • lostr
                                      • Feb 2018
                                      • 19
                                      #98
                                      Please help !
                                      SMC.bin for unlocking Bios : HP ProBook 650 G1
                                      Serial Sistem 5CG50716YS
                                      UUID Sistem 7F3B7601-3BB1E411-820378A5-3804C0FF
                                      Thanks !
                                        VIP Moderator
                                        • Aug 2018
                                        • 4386
                                        • Bulgaria 🇧🇬
                                        #99
                                        Originally posted by lostr
                                        Please help !
                                        Thanks !
                                        Nobody can't give you the smc file, just dump your bios and use the tool for unlock.
                                        • slaine
                                          • Feb 2020
                                          • 21
                                          • germany
                                          #100
                                          If there are any issues, please do let me know so I can improve this tool.
                                          no problem here - thanks a lot for the unlocker.exe - had some bios dumps in the past with manual VSS editing via hxd - thx to you the routine is much faster now. Gonna try it on some 840g3 this week after i figured the best way to read the chip without desoldering it (standard soic8 clip is not fitting since they use 8-WSON Package here for the eeprom)
                                          • salim5566
                                            loking for bio tool that hve all feature like ps5 bios and laptop bios unlock and repair 1 tool can do all please good tool?
                                            by salim5566
                                            Hi guys i like to buy tool that automatic unlock bios or find password also can flash and repair bios ic, looking for good tool have good software that have 1 click and unlock bios any recommend good tool? looking for sony ps5 and and laptop bios
                                            06-26-2025, 03:25 PM
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
                                          • Forest79
                                            by Forest79
                                            07-23-2023, 07:39 AM
                                          • Kesavan
                                            HP 245 G10 BIOS UNLOCK FILE REQUEST
                                            by Kesavan
                                            Hello, Need unlock BIOS password for HP 245 G10 MOBO PART NO: HOKIE22-MV-VGT-6050A3461901-MB-A01
                                            Attached my backup file
                                            SERIAL NO: 5CG4300CNT...
                                            06-16-2025, 06:42 AM
                                          • Sebastian Codrean
                                            BIOS file for ASUS F542UN laptop
                                            by Sebastian Codrean
                                            Hello to all of you! I need help with a BIOS file.
                                            The BIOS chip is fried on my Asus F542UN laptop, and I bought a new chip that needs programming. I have a CH341a programmer but I need a .bin BIOS file. On Asus support page the firmware has another extension, .310 and from reading on this forum I understand that that file is not complete BIOS.
                                            So, in short I need the "complete" BIOS .bin file to flash on the new chip. Another issue is that on back of the case the label says F542UN but on the sticker on the motherboard it's X542UN.
                                            02-20-2025, 10:25 AM
