Macbook M1 bypass FMM / EFI Unlock
This topic is closed.
  • techman9510
    • Jul 2018
    • 10
    • usa
    #101
    Re: Macbook M1 bypass FMM / EFI Unlock
    so in order to get a MDM activation key the MacBook has to be supervised and in order to do that you need a business or school Apple ID. I'm in the process of getting the business Apple ID and I will test the mdm activation key on a iPad that is jailbroken.
    • betonel
      • Nov 2015
      • 32
      • romania
      #102
      I need an external drive bootable/working hard drive image for M1 mac, for the situation when secureboot is disabled. It might work to bypass activation on those devices with secureboot disabled. Anyone here have an working M1 device to install a fresh copy on external drive, then dump image with something like acronis and upload on mega?
      • techman9510
        • Jul 2018
        • 10
        • usa
        #103
        By working you mean non iCloud locked right? I have MacBook Pro and MacBook Air m1 but they are both locked
        • TheSynthax
          • Nov 2020
          I assume the the secure boot switch is more than just a bit flip, right? Anyone taken a dump before and then after turning off secure boot? With secure boot off it should be possible to use M1N1 or Asahi and just hacktivate macOS like an old iPhone. Obviously a bit more complicated than that, but with secure boot off it should be quite easy to access the filesystem and bypass setup.
          • betonel
            • Nov 2015
            • 32
            • romania
            #105
            Yes, need you to have a fully functional M1 mac, install os on external drive, then upload image for us.
            • curiositymaster
              • Apr 2021
              • 45
              • Nigeria
              #106
              What do you intend to do with this image?
              • betonel
                • Nov 2015
                • 32
                • romania
                #107
                In case secure boot is disabled, I think you can start from external drive. After we can try to access nand from OS.
                • curiositymaster
                  • Apr 2021
                  • 45
                  • Nigeria
                  #108
                  I never knew you could access the Nand through your installed MacOS
                  • VHS
                    • Oct 2020
                    • 15
                    I have one M1 that is file vault locked, it's attached to an iCloud account, but it is not reported lost or remotely managed.
                    I also have one that is activation-locked due to it being erased. (not reported lost)
                    So far, I have not been able to get either one to boot from an external drive.
                    Both machines belong to a client that was allowing sales staff unfettered access to company-owned devices.
                    Unfortunately, he purchased both machines used on the secondary market, and Apple will not accept his proof of purchase.
                    • mazoot
                      iFixit
                      • Jan 2019
                      • 41
                      • Moldova
                      #110
                      How to bypass MDM on M1 books? Manually who know the steps?
                      Kill the state in yourself and you will be free like a wind...
                      • .::iRizwan::.
                        Banned
                        • Apr 2016
                        • 63
                        • Pakistan
                        #111
                        Yes what you wanna do?
                        is it MDM only or MDM+iCloud?
                        • mazoot
                          iFixit
                          • Jan 2019
                          • 41
                          • Moldova
                          #112
                          I found steps do bypass MDM....Good luck to all....
                          • betonel
                            • Nov 2015
                            • 32
                            • romania
                            #113
                            Post it here, so we all can see it.
                            • mazoot
                              iFixit
                              • Jan 2019
                              • 41
                              • Moldova
                              #114
                              1. Open Utilities-"Terminal" and type
                              $ csrutil disable
                              $ reboot
                              2. Hold `command-R` during the reboot to enter Recovery Mode again
                              3. Enter Disk Utility, and mount the `Macintosh HD` volume (or whatever your main volume is named). (It might already be mounted.)
                              4. Exit Disk Utility, open Utilities"Terminal", and type
                              $ cd "/Volumes/Macintosh HD/System/Library"
                              $ cd ../../etc
                              $ echo "0.0.0.0 iprofiles.apple.com" >> hosts
                              $ echo "0.0.0.0 mdmenrollment.apple.com" >> hosts
                              $ echo "0.0.0.0 deviceenrollment.apple.com" >> hosts
                              $ echo "0.0.0.0 gdmf.apple.com" >> hosts
                              $ csrutil enable
                              $ reboot
                              sure to not select a wireless network, but continue without an internet connection
                              After a normal boot, you can verify the DEP status in Terminal:
                              $ profiles status -type enrollment
                              Enrolled via DEP: No
                              MDM enrollment: No
                              • mazoot
                                iFixit
                                • Jan 2019
                                • 41
                                • Moldova
                                #115
                                • alerm
                                  • Mar 2022
                                  • 16
                                  • Deutschland
                                  #116
                                  I made an account just to ask if you guys could use the files I got from mounted reboot folder on an locked Macbook Air m1?
                                  • heatorious
                                    • Apr 2020
                                    Sure lets have a peak
                                    • Marietta_GA
                                      Banned
                                      • Mar 2022
                                      • 6
                                      Hi, Any news on M1 icloud bypass ?
                                      • alerm
                                        • Mar 2022
                                        • 16
                                        • Deutschland
                                        #119
                                        Here you go
                                        I put in some images for you to see from where I got them (If you don't already have them)
                                        I hope this helps a little bit
                                        • alerm
                                          • Mar 2022
                                          • 16
                                          • Deutschland
                                          #120
                                          I forgot one folder
                                          • tobeend
                                            Bypass mdm macbook m2 ventura
                                            by tobeend
                                            1. RESET MACOS WITH IPSW
                                            a. Power off MacBook, press and hold the power button to enter Recovery
                                            b. Open Disk Utility, remove Macintosh HD
                                            c. Reboot, connect to the network to Activate Mac.
                                            d. Plug the C cord in the first port of the MacBook into the other Mac, then power off the MacBook
                                            d. Hold down the Control (L) + Option (L) + Shift (R) + Power key combination for 10 seconds
                                            e. Release the other keys, but keep holding the Power key for another 10 seconds
                                            f. MacBook is returned to DFU, open Apple Configurator 2 on the other Mac, right-click...
                                            05-26-2023, 07:18 AM
                                          • oxonater
                                            Apple MacBook Pro A2141 16" IC BYPASS
                                            by oxonater
                                            Hi everyone hope all are well
                                            I need a little expert advice on a issue I have and seeing as this forum is full of clever people I thought ask here as you never know.
                                            I recently repaired a logic board 820-01700 which belongs to a 16" 2019 Macbook Pro, however I seem to be missing a component near the T2 Rom chip and is U4730.
                                            The schematics say this chip is (M34128-FCS6_P/T) and it also says there is a bypass for it wondered if anyone come across either the IC or the bypass method.
                                            I suppose it's worth noting googling the part package brings up various...
                                            10-23-2024, 11:21 PM
                                          • keats11
                                            T2 Macbook MDM Unlock by S/N change.
                                            by keats11
                                            I was hoping someone could point me to a tutorial on MDM unlock. Basically, I picked up a Macbook (A1989) from someone which did not have OS installed. The guy said it started software update and but did not finish. Long story short, the touchbar on this device has some kind of a short, so after unplugging it, I was able to install the OS on it, when I found out that it is also MDM locked by his company. I tried changing the serial number on the ROM by only changing a couple of digits of the original serial number. Now after installing the ROM back, the Macbook appears dead = DFU mode. When I...
                                            05-15-2023, 06:46 AM
                                          • envym
                                            by envym
                                            Hi everyone!
                                            06-27-2025, 08:54 AM
                                          • Flasman90
                                            Macbook Pro DFU Restore Issues
                                            by Flasman90
                                            I have a 2020 Macbook Pro A2289 and after many attempts managed to get it into DFU mode, using my older 2017 A1706 Macbook Pro (Running Ventura 13.7.8). However, when attempting 'Restore', it fails at step 4 of 4, showing the following error:
                                            - "The operation couldn’t be completed. (AMRestoreErrorDomain error -1 - Failed to handle message type StatusMsg (Generic error)) [AMRestoreErrorDomain – 0xA (10)]
                                            - "The system cannot be restored on this device. Failed to create new state machine for restore [com.apple.MobileDevice.MobileRestore - 0xFB1 (4017)]
                                            08-30-2025, 10:27 AM
