Macbook M1 bypass FMM / EFI Unlock
This topic is closed.
Re: Macbook M1 bypass FMM / EFI Unlock
If you have a t2 bypassed make a zip with a password of this folder and upload:
I'm working on T2 latest bridgeOS, can be pwn and i think is possible to bypass!Code:/usr/libexec/
You can't just edit ipsw like iphone/ipad, devices will refuse the flash. I need an m1 locked and see where we can play around.hello genhack, thank you for your observations.
I was thinking about the UniversalMac_11.0.1_20B29_Restore.ipsw we can edit it and instead of the diagnostic options we change it to the terminal file what would happen?
Considering that I can load by DFU. I do not know how to edit it but it is an option that occurs to me, what do you think?
Cheers!Last edited by genhack; 10-27-2022, 11:36 AM.Comment
I'll see if I can get my hands on one and share it ASAP.Comment
When you start diagnostics there is dmg image (FieldServiceDiskImagePersonalized) downloded via internet, which contains another dmg image (like 012-94675-003.dmg). That last dmg contains apps, libs, lua scripts and so on, for running diagnostics, but this image is trustcache protected, so if you have control over network it is not possible to change... almost.
assume, you've found a way to change on this image whatever you want, what would you do?Comment
I fully agree. Diagnostics do not help the purpose, starting a shell from there wouldn't allow us to do anything.When you start diagnostics there is dmg image (FieldServiceDiskImagePersonalized) downloded via internet, which contains another dmg image (like 012-94675-003.dmg). That last dmg contains apps, libs, lua scripts and so on, for running diagnostics, but this image is trustcache protected, so if you have control over network it is not possible to change... almost.
I've got a couple of bypassed T2s and one that won't unlock due to it having Monteray on it.
I also have a water-damaged M1 that won't charge its battery, and it doesn't seem to have sound but other than that, it's running fine and an identical locked M1 that someone could probably make an easy repair of.Comment
Hello Mario,
In order:
You can't edit and flash this ipsw, Bootchain will refuse any mod. so this try is usless untill m1 is pwn (*Like t2* with checkm8).Code:Through DFU I have been able to reverse the firmware of the locked mac I have installed the UniversalMac_11.0.1_20B29_Restore.ipsw even so I have not been able to skip the icloud step.
Ok i think you need to check how boot m1m1 by usb. Just a Ps: M1 will refuse to boot other os in activation, secure state is enbaled but you can try.Code:I have tried to start with linux but the operating system does not recognize me or it does not show me the memory or at least I do not know how to boot the operating system that is already combatable.
About diagnostic, i check myself and i think there is no way to use external drive for boot something or open app. Diagnostic is designed for just save do that and can't be the skip part of the process, you need to sign binary inside the other volume and make full bypass, this mean if i press activate you go on this flow and do all things you need for boot proper. if mobileactivationd don't make the necessary cert of the devices i think you will never boot inside the real os.Code:The hidden diagnostic system allows me to store all the analysis on a usb stick.
the important thing is to find how to unlock it.I've got a couple of bypassed T2s and one that won't unlock due to it having Monteray on it.
Couldn't upload the whole libexec folder here as it was too large (42mb after compression). However, I have uploaded the mobileactivationd file from the bypassed mac if that is enough for your research.Attached FilesComment
actually you can get kernel privileges, bypass the FileVault, mount main partition and do whatever you want. I'm on this stage now, and have already booted linux with success. But my goal is to bypass activation lock and install normal macos.Last edited by fshadow; 11-02-2022, 09:30 AM.Comment
i'm not gonna expose it right now, because it is huge hole in macos security and seems like nobody know it. at first i'll post a vidio next week with poc without ditails, next i'll contact apple bug bounty(i know it's weak) , next... anyway i'll get profit and then i'll tell uComment
If you weren't going to share how you managed to bypass filevault, why talk about it?i'm not gonna expose it right now, because it is huge hole in macos security and seems like nobody know it. at first i'll post a vidio next week with poc without ditails, next i'll contact apple bug bounty(i know it's weak) , next... anyway i'll get profit and then i'll tell uComment
hi guys, has anyone managed to find where the sn is recorded?OK, I found a quick way to pull serial info from locked boards. Going to go through and pull more M1 ROM dumps later this week to check for emails; I still haven't found any in the dumps I've checked (over 25 checked now--including 2 more A2442 boards), but going to play with different scenarios (will take time).
After reading through the entire thread I only found information that it is somewhere on the first nand and you can not get to it.Comment
I'm working on, i can't find the original mobileactivationd version for understand where they make the patch. But, i have an idea and in the free time i work on python program, i think this can work easy with a macbook just bypassed. So just for proof of t2 can be pwn:
J40aap key latest bridgeos.
IBSS:
IV: 120402A7168E7AAAC1F94C6A5D58F8F1,
key: 5C1E07A0EA5A8F48D09FA568182172CA74880896761CFA6992006558CDD9981D
IBEC:
IV: 6909A0A0D9675B5BAEFB9ECFAA00386C,
key: C7DA39AF1DB80189C27F5D3A39C01F13D4FD7C7B6453DAADE018DC6188BAD24A
About diagnostic i have no idea how you can boot m1n1 with security on. If you wonna make this a bit of sense send me a pvt thanks.Comment
Hi fshadow;
Can you share with us how you were able to start in linux?Comment
Hello every one,
i want to thank you all for effort and contribution,
I was wondring if any one had tried to replace the ssd nand ships and reset the mac from dfu mode using Apple configurator App ? like replacing a normal ssd would that bypass FMM ? i am new so forgive me if iam saying bullshits.
Regards.Comment
by tobeend1. RESET MACOS WITH IPSW
a. Power off MacBook, press and hold the power button to enter Recovery
b. Open Disk Utility, remove Macintosh HD
c. Reboot, connect to the network to Activate Mac.
d. Plug the C cord in the first port of the MacBook into the other Mac, then power off the MacBook
d. Hold down the Control (L) + Option (L) + Shift (R) + Power key combination for 10 seconds
e. Release the other keys, but keep holding the Power key for another 10 seconds
f. MacBook is returned to DFU, open Apple Configurator 2 on the other Mac, right-click... -
by oxonaterHi everyone hope all are well
I need a little expert advice on a issue I have and seeing as this forum is full of clever people I thought ask here as you never know.
I recently repaired a logic board 820-01700 which belongs to a 16" 2019 Macbook Pro, however I seem to be missing a component near the T2 Rom chip and is U4730.
The schematics say this chip is (M34128-FCS6_P/T) and it also says there is a bypass for it wondered if anyone come across either the IC or the bypass method.
I suppose it's worth noting googling the part package brings up various... -
by keats11I was hoping someone could point me to a tutorial on MDM unlock. Basically, I picked up a Macbook (A1989) from someone which did not have OS installed. The guy said it started software update and but did not finish. Long story short, the touchbar on this device has some kind of a short, so after unplugging it, I was able to install the OS on it, when I found out that it is also MDM locked by his company. I tried changing the serial number on the ROM by only changing a couple of digits of the original serial number. Now after installing the ROM back, the Macbook appears dead = DFU mode. When I...
Channel: BIOS Requests ONLY!
by envymHi everyone!
I tried using the built-in tool to restore the MacBook (Settings > General > Transfer or restore > Delete) but it got stuck when trying to remove the Find Device configuration (it asked me for the password for my old Apple ID -now I use the same account but...06-27-2025, 08:54 AM -
by Flasman90I have a 2020 Macbook Pro A2289 and after many attempts managed to get it into DFU mode, using my older 2017 A1706 Macbook Pro (Running Ventura 13.7.8). However, when attempting 'Restore', it fails at step 4 of 4, showing the following error:
- "The operation couldn’t be completed. (AMRestoreErrorDomain error -1 - Failed to handle message type StatusMsg (Generic error)) [AMRestoreErrorDomain – 0xA (10)]
- "The system cannot be restored on this device. Failed to create new state machine for restore [com.apple.MobileDevice.MobileRestore - 0xFB1 (4017)]
...08-30-2025, 10:27 AM - Loading...
