Macbook M1 bypass FMM / EFI Unlock
This topic is closed.
Re: Macbook M1 bypass FMM / EFI Unlock
hello Mario,
thank your for your reply,
for replacing the ssd nand iam already aware that is soldered to the motherboard, and i didn't say that it will be easy to replace it even more to bypass FMM if the swap is successful.
but i already read that it is possible with the right skills: https://www.google.com/url?sa=t&sour...q4tYb80tIOUmJ_. (link for an article about Chinese upgrading ram and ssd on m1 model)
regards.Comment
hello Mario,
regards.
hi killeur
If it is what I have seen in the information of all the research reading. I haven't tried it because I don't have the tool and the other one is like hitting the tower if I can't make it work again. But this sure the hard drive has to do with the whole crash. And more as it is designed. Look at this.
https://eclecticlight.co/2021/01/18/...l-and-m1-macs/Comment
hi I have m1 macbook pro max device MDM. I deleted ssd and install new OSX MONTEREY after I said no internet connecting full installed device. I am going to recovery mode
terminal csrutil disable. gives an error message
csrutil: the Os environment doesnt allow changing security configuration options.
Ensure that the system was booted into Recovery OS via the standart user action.
I need helpComment
HI ive been doing some research back 2 years ago and i can tell you that it is possible to open terminal on activation recovery only on T2. the command is you press repeatedly command+T (terminal) right after you select language.There is some guy on youtube showing how he open terminal inside activation window on M1/T2 mac.
keywords: M1 terminal inside Internet recovery MacOS Monterey
How is this possible? We need to find key combination, for the moment found way to open log window / save logs to usb.
ive tried this on M1 but doesnt work.
SOLVED:I showed ssd as startup disk. after restart.hi I have m1 macbook pro max device MDM. I deleted ssd and install new OSX MONTEREY after I said no internet connecting full installed device. I am going to recovery mode
I need help
recovery mode and terminal csrutil disable
bingo worked .
after I paid check_m8 for mdm bypass software. it is working now without MDM.Comment
hello ethiogsm,
may i ask you how to open terminal on T2 mac on wich step you did that ? i need your assistance to reproduce it please. i tried to hold cmd+t with no success.
thanks in advance.Comment
hello
I share that yesterday I started to compare the information of my mac M1 unlocked and locked.
I used the hidden menu on the unlocked M1 and found that the preboot drive had 3 files and the locked mac only had 2.
What I see is that the unlocked one has a file called active.
Do you think this is the one in charge of having the pc unlocked, I tried to copy it but I have no way, how do you see? what do you think?
Cheers!Comment
Hi killeur
you just press the key command+T repeteadly in recovery screen while you are at the language selection part.Comment
hello ethiogsm
thanks for your return, even with internet recovery does that work ? another question does the workaround also work with Monterey?Comment
Broh this is so.... I have no idea how you spwn. I can't dm you idk why, so if you can pls do it. If not, you edit some info.p and change the iA_springboard?Comment
Has anybody tried to startup a locked M1 with a working OS installed on external drive?
Maybe someone could share a image of a running MACOS installation for M1 to try it myself.
Thanks in advance and thanks to everybody for sharing your knowledge.Comment
by tobeend1. RESET MACOS WITH IPSW
a. Power off MacBook, press and hold the power button to enter Recovery
b. Open Disk Utility, remove Macintosh HD
c. Reboot, connect to the network to Activate Mac.
d. Plug the C cord in the first port of the MacBook into the other Mac, then power off the MacBook
d. Hold down the Control (L) + Option (L) + Shift (R) + Power key combination for 10 seconds
e. Release the other keys, but keep holding the Power key for another 10 seconds
f. MacBook is returned to DFU, open Apple Configurator 2 on the other Mac, right-click... -
by oxonaterHi everyone hope all are well
I need a little expert advice on a issue I have and seeing as this forum is full of clever people I thought ask here as you never know.
I recently repaired a logic board 820-01700 which belongs to a 16" 2019 Macbook Pro, however I seem to be missing a component near the T2 Rom chip and is U4730.
The schematics say this chip is (M34128-FCS6_P/T) and it also says there is a bypass for it wondered if anyone come across either the IC or the bypass method.
I suppose it's worth noting googling the part package brings up various... -
by keats11I was hoping someone could point me to a tutorial on MDM unlock. Basically, I picked up a Macbook (A1989) from someone which did not have OS installed. The guy said it started software update and but did not finish. Long story short, the touchbar on this device has some kind of a short, so after unplugging it, I was able to install the OS on it, when I found out that it is also MDM locked by his company. I tried changing the serial number on the ROM by only changing a couple of digits of the original serial number. Now after installing the ROM back, the Macbook appears dead = DFU mode. When I...
Channel: BIOS Requests ONLY!
by envymHi everyone!
I tried using the built-in tool to restore the MacBook (Settings > General > Transfer or restore > Delete) but it got stuck when trying to remove the Find Device configuration (it asked me for the password for my old Apple ID -now I use the same account but...06-27-2025, 08:54 AM -
by Flasman90I have a 2020 Macbook Pro A2289 and after many attempts managed to get it into DFU mode, using my older 2017 A1706 Macbook Pro (Running Ventura 13.7.8). However, when attempting 'Restore', it fails at step 4 of 4, showing the following error:
- "The operation couldn’t be completed. (AMRestoreErrorDomain error -1 - Failed to handle message type StatusMsg (Generic error)) [AMRestoreErrorDomain – 0xA (10)]
- "The system cannot be restored on this device. Failed to create new state machine for restore [com.apple.MobileDevice.MobileRestore - 0xFB1 (4017)]
...08-30-2025, 10:27 AM - Loading...
