ASUS L406M BIOS Error
  • mferna14
    • Jun 2018
    • 1015
    Hi, can anyone do me a favour to re-do this ASUS L406M Bin files again & make it working 100%. There is no display at all but I see it takes 11milli amp (Up & down a bit) when I attach the amp meter. Copy of the original Bin File is attach. Thanks in advance.
  • hoaca388
    Badcaps
    • Jan 2022
    • 11635
    Re: ASUS L406M BIOS Error
    seri number ?
      • 20665
      Post a picture of the long white barcode sticker. It will have a model number on it, that number is sometimes different to the silkscreened number https://www.badcaps.net/forum/showthread.php?t=96604
      • mferna14
        • Jun 2018
        • 1015
        Thank you so much guys for your help... I have attached the photo of the sticker on the motherboard & the Unit serial # KCN0CV08R32151A... really appreciate
        • hoaca388
          Badcaps
          • Jan 2022
          • 11635
          thank you so much guys for your help... I have attached the photo of the sticker on the motherboard & the unit serial # kcn0cv08r32151a... Really appreciate
          • mferna14
            • Jun 2018
            • 1015
            Thanks, I will re-program & inform you guys ASAP.....
            • mferna14
              • Jun 2018
              • 1015
              Originally posted by hoaca388
              Not working at all. On the orignal BIOS teh motherboard was drawing about 10mlli amp but the one Bin FIles which you sent me, I programmed the chip & the amp meter, DRAWS NO CURRENT, still on ZERO. I think a bit of more fixing required in the bin files.
              • hoaca388
                Badcaps
                • Jan 2022
                • 11635
                try this file
                • mferna14
                  • Jun 2018
                  • 1015
                  try this file
                  Thanks for your help. I will program first thing in the morning & inform you the result. Wait for my answer please.
                  • mferna14
                    • Jun 2018
                    • 1015
                    Hi., Bin Files Not working, Same Status, the White Power LED stays on & no current drawn stuck at 0 amp, I even turn it on from the keyboard on/off button. But with the original Bin file at least 10~14 milli amp were drawn. Please rectify if any you or anyone can. Thank you.
                    • mferna14
                      • Jun 2018
                      • 1015
                      Anyone here to help me fix this ASUS L406M BIOS Bin files, I would really appreciate. Thanks
                        • 20665
                        I don`t think the bios is the problem,but try it anyway.
                        • mferna14
                          • Jun 2018
                          • 1015
                          I will surely try SMDFlea & let you know, thank you so very much...
                          • razor_amd
                            by razor_amd
                            12-15-2020, 07:07 PM
                          • grimacelord
                            by grimacelord
                            07-10-2025, 02:52 PM
                          • throwaway327
                            by throwaway327
                            Model No: RC72LA
                            Serial No: SBNVKD001014459
                            06-18-2025, 05:52 PM
                          • jbonavita
                            by jbonavita
                            Some issues
                            Things I tried
                            04-29-2025, 09:38 PM
                          • greg.chalk
                            Asus strix b660-i itx, bios unlock, FPT Error 167: Protected Range Registers
                            by greg.chalk
                            I updated my pc, from Evga z270 itx to Asus b660-i itx motherboard. In my old z270 motherboard everything whas easy because everything in bios was unlocked (fd, me etc), and could do everything I want.
                            Now in my Asus b660 everything is locked (except main bios region). I dont mind so much but I want to unlock bios so I can flash a new splash screen (I have done it with my old motherboard).
                            I made a bios dump with FPT (fptw64 -d mod.rom -bios), I modded it and I tried to flash back
                            (fptw64 -f mod.rom -bios). I got Error 167: Protected Range Registers are currently...
                            10-02-2022, 10:54 PM
