x513ea r5.3
    Originally posted by albologna View Post
    Yes, sorry
    Asus service bios + your DMI . .If it doesn`t work its not a bios problem.
      Thank You. Tested and it is NOT working. It is the same. I think the Gpu is done even though the the vdd resistence is 3 ohm. I will check the led lines on the monitor, maybe the fault is there
      I think I found the problem. It has 4 ohm on ram 1.2V power supply. Found that one of 4 slot on voltage injection was consuming 1,2A. Removed that slot and the short was gone. Still the pc is not working. Can someone help on disable the ram Onboard?
      Hello, i hope to be in the right place for my bios issue : (Black screen, chip is unreadable, can't do backup, I tried several times, chip unsoldered. chip model Gigadevice 25B128E)
      Asus X513EA Rev 5.3
      Here is the information in text and image too
      Serial number And QRcode fan side
      SN 24M : MAN0CV10T95541A
      MFD : 2021.10
      MODEL : X513EA
      Main Board Serial and révision : X513EA MAIN BOARD Rev 5.3
      I hope you have enough information to create a .bin of the right size for me. Thank you
        Asus X513EA Rev 5.3
        MFD : 2021.10
        MODEL : X513EA
        Post moved to X513EA Rev 5.3 thread. Attach pictures to your post as an attachment. What model is your programmer and software version, and is the chip in the support list
          sorry, here are the attached picture and my programmer is a revelprog-is, software is updated to version 1.9.1... i'm searching for supported chip, i used a 25Q128 to test other bios, i can program and read 25Q128 without problem
          the GD25B128 chip is in supported list
            Asus X513EA Rev 5.3
            MFD : 2021.10
            MODEL : X513EA
            try this bin rebuilded and fresh bin
              thank you kalilinux25 i will try as soon as possible
                i tried this morning but nothing more, same thing, when i connect the power, white led on power button and still black screen, fan not spinning, cpu is hot (60°). Must be a cpu or gpu issue. Thank you for your help again !!! I made a paypal donation to support your work.
                  thank you
                    Please, can you fix BIOS?
                    Problem with the RAM
                      Serial number ?
                      Become a Badcaps supporter
                      Thanks to all supporters.
                        hi for all,
                        I have an ASUS X513AE R4.3 that powers on and consumes 0.33 amps. All voltages are present except for +VCCIN (see attached picture). I checked the BIOS dump and found that the KBC is IT8985, but the board has IT5125, so this dump is not the original. I have attached this dump. I hope someone can help me with a working dump for this board or provide any advice.
                        • peste
                          peste commented
                          Editing a comment
                          merged post..
                        #73
                        Originally posted by sourcebf View Post
                        hi for all,
                        I looked for it but couldn't find anything I could start working on, so any help is appreciate
                          help me unpass bios
                            unpass bios, help me
                              Serial number . Don't forget.
                                X513EAN doesn't turn on, black screen. Battery light flashes white 2 times, several times and then shuts down. I found a BIOS update file in ESP, so I assume this may be a failed BIOS update by windows.
                                I have attached bios dump.
                                Serial Number: N2N0CV12369708B
                                Thanks for help in advance.
                                  Try this bios.
                                    Originally posted by SMDFlea View Post
                                    Try this bios.
                                    It worked! Thank you very much!
                                      SMDFlea commented
                                      Editing a comment
                                      You`re welcome :-)
                                    #80
                                    X513EAN doesn't turn on, black screen, can anyone help repair this bios Original
