Extracting a bios from lenovo bios update tool
  • yorfax
    • Jan 2017
    Hello
    I have downloaded a BIOS update tool from the Lenovo site 9dcn34ww.exe when I opened it in 7zip I saw a file called ZIWB2304.ROM which I assumed was the bios file and it loads into UEFItool. The issue is the file size, it is 10,101,992 bytes whereas the dump file I downloaded from the motherboard is 8,388,608 bytes why is there a discrepancy? Also, if I used a plain .bin file from Lenovo would that automatically update the pertinent information from the laptop on first boot? (or does the bios update tool do this?).
    Thanks in advance
    Matthew
  • gestalt.exe
    Lenovo Legion Y540 – Need help repairing BIOS after bad downgrade
    by gestalt.exe
    My Lenovo Legion Y540 (i7-9750H, RTX 2060) bricked after I downgraded from BHCN44WW to BHCN21WW.
    Laptop stopped booting entirely.
    I used a CH341A programmer to dump the corrupted 16MB BIOS.
    i then attempted the following:
    1. Downloaded stock BIOS BHCN39WW from Lenovo
    2. Trimmed it to 16MB
    3. Extracted the BIOS region from the corrupted dump
    4. Extracted the BIOS region from the stock 39WW
    5. Replaced the corrupted BIOS region with the stock one (within hxd , opened the corrupted dump and replaced its region by the stock)
    6. Injected back my LDGB / DMI
    11-30-2025, 10:38 AM
  • Thomas Dunlap
    Corrupted/Interrupted Bios Update Lenovo Legion S7 15ACH6
    by Thomas Dunlap
    I have a Lenovo Legion S7 15ACH6 that was interrupted during a BIOS update and is now bricked. Symptoms: fans spin, RGB keyboard lights up, but no display/POST.
    The BIOS chip is a Gigadevice GD25LR128. I’m using a CH341A with a 1.8 V adapter. In AsProgrammer I selected GD25Q128 (since GD25LR128 isn’t listed) and successfully made a dump (BiosDump2_pf3eg12j.rar).
    My understanding is that I’ll need a known good BIOS dump for this exact model, ideally matched to my laptop’s serial number (PF3EG12J), and that the Windows license key/serial should also...
    09-26-2025, 12:45 PM
  • to5it0
    by to5it0
    10-24-2025, 01:35 AM
  • mkdj
    Lenovo IdeaPad 3 - Hard Disk not recognized in BIOS
    by mkdj
    Dear all,
    I have recently fixed a Lenovo IdeaPad 3 15 ALC6 that was not booting due to a BIOS issue. After flashing the BIOS, the laptop boots up, but hard disk is not recognized in BIOS. Is says "Hard Disk : Not Installed". I have tried with 2 different drives (one that I know is working on another laptop) but I get the same result. I do not know if disks were recognized before I got the laptop and fix it, but I don't see any reason why not. I can boot on USB though.
    Here the steps I have taken to fix the laptop:
    - downloaded latest BIOS from Lenovo Website...
    10-18-2025, 03:43 AM
  • Zarithya
    Lenovo ThinkPad X1 Carbon 7th gen not booting after failed BIOS update
    by Zarithya
    I have a ThinkPad X1 Carbon 7th gen that stopped booting after a failed BIOS update. There is no life from the machine when the power button is pressed, but when the charger is plugged in, the amber charging indicator turns on and the power button blinks three times. The battery does charge, eventually turning the amber light white. I've dumped the BIOS and tried to fix it (but I don't know what I'm doing or how to use Lenovo's update files in this way) and even attempted to overwrite it with other uploads I've found here to no avail. I've posted the dump in the request forum and...
    11-02-2025, 06:26 AM
