x513ea r5.3
    • 20898
    Originally posted by albologna
    Yes, sorry
    Asus service bios + your DMI . .If it doesn`t work its not a bios problem.
    • albologna
      • May 2022
      • 28
      • italy
      #62
      Thank You. Tested and it is NOT working. It is the same. I think the Gpu is done even though the the vdd resistence is 3 ohm. I will check the led lines on the monitor, maybe the fault is there
      I think I found the problem. It has 4 ohm on ram 1.2V power supply. Found that one of 4 slot on voltage injection was consuming 1,2A. Removed that slot and the short was gone. Still the pc is not working. Can someone help on disable the ram Onboard?
    • narpa
      • Aug 2017
      • 11
      • France
      #63
      Hello, i hope to be in the right place for my bios issue : (Black screen, chip is unreadable, can't do backup, I tried several times, chip unsoldered. chip model Gigadevice 25B128E)
      Asus X513EA Rev 5.3
      Here is the information in text and image too
      Serial number And QRcode fan side
      SN 24M : MAN0CV10T95541A
      MFD : 2021.10
      MODEL : X513EA
      Main Board Serial and révision : X513EA MAIN BOARD Rev 5.3
      I hope you have enough information to create a .bin of the right size for me. Thank you
        • 20898
        Asus X513EA Rev 5.3
        MFD : 2021.10
        MODEL : X513EA
        Post moved to X513EA Rev 5.3​ thread. Attach pictures to your post as an attachment. What model is your programmer and software version, and is the chip in the support list
        • narpa
          • Aug 2017
          • 11
          • France
          #65
          sorry, here are the attached picture and my programmer is a revelprog-is, software is updated to version 1.9.1... i'm searching for supported chip, i used a 25Q128 to test other bios, i can program and read 25Q128 without problem
          the GD25B128 chip is in supported list
          • kalilinux25
            • Mar 2018
            • 2089
            • ZAMBOANGA SIBUGAY
            #66
            Asus X513EA Rev 5.3
            MFD : 2021.10
            MODEL : X513EA
            try this bin rebuilded and fresh bin
            • narpa
              • Aug 2017
              • 11
              • France
              #67
              thank you kalilinux25​ i will try as soon as possible
              • narpa
                • Aug 2017
                • 11
                • France
                #68
                i tried this morning but nothing more, same thing, when i connect the power, white led on power button and still black screen, fan not spinning, cpu is hot (60°). Must be a cpu or gpu issue. Thank you for your help again !!! I made a paypal donation to support your work.
                • kalilinux25
                  • Mar 2018
                  • 2089
                  • ZAMBOANGA SIBUGAY
                  #69
                  thank you
                  • shamanizator
                    • Apr 2021
                    • Poland
                    #70
                    Please, can you fix BIOS?
                    Problem with the RAM
                    • hoaca388
                      Badcaps
                      • Jan 2022
                      • 11736
                      #71
                      Serial number ?
                      • sourcebf
                        • Jul 2016
                        • 431
                        • N/A
                        #72
                        hi for all,
                        I have an ASUS X513AE R4.3 that powers on and consumes 0.33 amps. All voltages are present except for +VCCIN (see attached picture). I checked the BIOS dump and found that the KBC is IT8985, but the board has IT5125, so this dump is not the original. I have attached this dump. I hope someone can help me with a working dump for this board or provide any advice.
                        • peste
                          peste commented
                          Editing a comment
                          merged post..
                      • sourcebf
                        • Jul 2016
                        • 431
                        • N/A
                        #73
                        Originally posted by sourcebf
                        hi for all,
                        I looked for it but couldn’t find anything I could start working on, so any help is appreciate
                        • cuongphampq1993
                          • Nov 2020
                          • florida
                          #74
                          help me unpass bios
                          • cuongphampq1993
                            • Nov 2020
                            • florida
                            #75
                            unpass bios, help me
                            • hoaca388
                              Badcaps
                              • Jan 2022
                              • 11736
                              #76
                              Serial number . Don't forget.
                              • s_l_c
                                • Nov 2024
                                • Poland
                                #77
                                X513EAN doesn't turn on, black screen. Battery light flashes white 2 times, several times and then shuts down. I found a BIOS update file in ESP, so I assume this may be a failed BIOS update by windows.
                                I have attached bios dump.
                                Serial Number: N2N0CV12369708B
                                Thanks for help in advance.
                                  • 20898
                                  Try this bios.
                                  • s_l_c
                                    • Nov 2024
                                    • Poland
                                    #79
                                    Originally posted by SMDFlea
                                    Try this bios.
                                    It worked! Thank you very much!
                                      SMDFlea commented
                                      Editing a comment
                                      You`re welcome :-)
                                  • ariffine
                                    • Aug 2023
                                    • indonesia
                                    #80
                                    X513EAN doesn't turn on, black screen, can anyone help repair this bios Original
                                    • mikeybass
                                      by mikeybass
                                      04-23-2025, 04:30 PM
                                    • akwky
                                      by akwky
                                      Hi!
                                      04-14-2025, 01:56 PM
                                    • al3m0di
                                      Update bios EFCN58WW to EFCN59WW
                                      by al3m0di
                                      Update bios EFCN58WW to EFCN59WW for solving The Connected AC adapter has a lower wattage than the recommended AC adapter
                                      I have a Lenovo Legion 5 15imh05a device that I bought used online. It came with a 20V 8.5A 170W charger.
                                      The BIOS version is EFCN58WW.
                                      When I turn on the device, it displays the message:
                                      "The Connected AC adapter has a lower wattage than the recommended AC adapter..."
                                      The device rarely charges the battery, and even when it does, it doesn't show that it's charging.
                                      I've tried
                                      07-29-2024, 10:32 AM
                                    • trix11
                                      Dell Precision T1650 MT Workstation bricked after BIOS update
                                      by trix11
                                      I have a Dell Precision T1650 MT workstation (of the following spec.) that was bricked yesterday when attempting to update the BIOS from A27 to A28 per:
                                      - https://www.dell.com/support/home/en...-t1650/drivers > Dell Precision T1650 System BIOS
                                      - Dell Precision T1650 mid tower Workstation
                                      - Xeon E3-1225 V2
                                      - 32Gb PC3-12800E RAM
                                      - 4Tb SATA HDD
                                      - motherboard: Dell part: 0C3YXR CN-0C3YXR-72200-39C-01GR-A02
                                      I see now that others have experienced like issues e.g.:
                                      - https://www.dell.com/community/Prec...
                                      10-24-2022, 10:35 PM
                                    • electrono
                                      Bios unlock for Asus Vivobook X513EA
                                      by electrono
                                      The situation is as follows:
                                      I set a supervisor password for my bios and forgot it because my laptop boots directly into Windows. So apparently there is no need to remember the password, my brain thought, so here I am
                                      System Specs:
                                      • Operating System: Windows 11 Pro 64-bit (10.0, Build 26100) (26100.ge_release.240331-1435) (Updated from original Windows 11 Home to 11 Pro using a key)
                                      • System Manufacturer: ASUSTeK COMPUTER INC.
                                      • System Model: VivoBook_ASUSLaptop X513EA_K513EA
                                      • BIOS: X513EA.310 (Type: UEFI)
                                      • Processor: 11th generation Intel(R)
                                      01-11-2025, 02:59 PM
