Bios Password Dell Latitude 5510
    Re: Bios Password Dell Latitude 5510
    No display
      there's another chip that you ust upload
        8m bit
          Originally posted by didouche1200 View Post
          8m bit
          Try and commet back
            please unlock my bios
              Try!
                password is in bios region? is it correctly if I will change bios region?
                  Originally posted by partner View Post
                  Try!
                  this work! thank you!
                    Try!
                    work but i cannt deactivate Absolute...
                      with new bios you had to deactivate Absolute, write service tag, save, then press alt+F to exit manufacturing mode.
                        in this bios enable, disable and permanently disable is not active and i cannt change
                          man, write back bios provided by partner and your motherboard will be in manufacturing mode. Press F2, disable Absolute, write service tag, save, restart, then press alt+F to exit manufacturing mode.
                            these items are not active! they are written in gray!
                              can't be grayed if you are in factory mode, you have full acces on ALL bios settings. what you don't understand is that you have to write again unlocked bios provided by partner.
                                I haven't pressed Alt+F yet, This is the first inclusion after the firmware
                                  Latitude 5510
                                  Service Tag: BHSZZ53
                                  For the steps to do , follow post 92.
                                  https://www.badcaps.net/forum/showpo...8&postcount=92
                                    Originally posted by lapfix View Post
                                    Latitude 5510
                                    This work!!! Thank you!!!
                                      you just have to reset bios to factory settings in factory mode. I did this many times and worked.
                                        Please could someone help me with this bios from a Latitude 5510 (FDW50 LA-J381P), i need to change the service tag, can i just edit it with HxD or is there another way?
                                        Or if someone could please clean the bios for me so that after flash i can set the service tag, there is no password, only need to change the service tag, many thanks.
                                        Last edited by Vesko356; 07-25-2023, 11:18 AM. Reason: Rules violation. Attached bios removed.
                                          Your request doesn't meet the rules. Deliberately changing ID numbers (including VIN, IMEI and so on) is illegal and not condoned or encouraged in any way or for any reason here.
                                          You may contact an official Dell representative office for further resolution of the matter by presenting proof of purchase/ownership.
                                          Originally posted by piernov View Post
                                          3. Password removal by laptop brand
                                          DISCLAIMER: badcaps.net and its members do no support unlocking stolen or company-owned devices. The information given here is for personal use only, ie. you accidentally set a password on your own machine, you forgot the password you set a long time ago or you mistyped the password when setting it and cannot get in again.
                                          Note that a device bought locked might also have been stolen if the previous owner cannot give the correct password. This is especially common with business-grade equipment (Lenovo ThinkPad…) that employees sneak out or do not return.
                                          Become a Badcaps supporter
                                          Thanks to all supporters.​
