Extract bios password from EliteBook 840 G8 Bios dump, possible?
  • babydoll8867
    • Nov 2014
    • 91
    • romania
    #761
    Originally posted by hoaca388
    Unlocked
    Thank you very much, it worked!
    • Ghost18_07
      Zakaria
      • Mar 2018
      • 78
      • Algeria
      #762
      Originally posted by Ghost18_07
      Same, can't access the BIOS menu, the password is still there.
      Well, it seems like i have an uncommon case here, i hope that someone can find a solution, thanks in advance for your help.
      • hoaca388
        Badcaps
        • Jan 2022
        • 11768
        #763
        Post EC file. 32BM other.
        • Ghost18_07
          Zakaria
          • Mar 2018
          • 78
          • Algeria
          #764
          Here it is.
          • hoaca388
            Badcaps
            • Jan 2022
            • 11768
            #765
            Here it is.
            Unlocked
            • Ghost18_07
              Zakaria
              • Mar 2018
              • 78
              • Algeria
              #766
              Unlocked
              It worked just fine, thank you Hoaca.
              • Kiki Cares
                • Feb 2022
                • 28
                • Nigeria
                #767
                HELLO GOOD AFTERNOON FRIEND
                I HAVE HP 840 G8 WITH COMPOTRACE LOCK
                SN::::5CG14299DN
                HAVE TRIED MANY FILE BUT NOT POWERING
                PLS HELP ME
                • Blaze Tech
                  Learner
                  • 205
                  • Ghana
                  #768
                  SN::::5CG14299DN
                  PLS HELP ME
                  Try
                  • hoaca388
                    Badcaps
                    • Jan 2022
                    • 11768
                    #769
                    SN::::5CG14299DN
                    PLS HELP ME
                    Unlocked
                    • c0nfig
                      • May 2023
                      • Slovenia
                      #770
                      I need this bios password unlocked.
                      Prod ID 19X35AV
                      S/N#5CG1247M00
                      CORVETTE-6050A3217501-MB-A01 (A1) (1086) L2
                      If you need anything else, do tell.
                      Thanks.
                      • hoaca388
                        Badcaps
                        • Jan 2022
                        • 11768
                        #771
                        Prod ID 19X35AV
                        S/N#5CG1247M00
                        Thanks.
                        HP EliteBook 840 G8 Notebook PC
                        CT Number_6LGWUNCGWF4H2Y
                        Serial_5CG1247M00
                        Product_19X35AV
                        Fearture byte_3X476J6S6b7B7H7M7Q7W7m7saBapaqauawb8bUcAdUdpdqeMfAfPguhKhkjhk8mEmVmwnVng.Nt
                        Build Id_21WWCVCT601#SAK8#DAK8
                        • kingkong computers
                          • Sep 2018
                          • 189
                          • pakistan
                          #772
                          840 g8
                          sno=5CG2227X2B
                          6050A321750-MB-A01
                          REBUILD FILE POWER ON ISSUE
                          • carloseddie83
                            • Nov 2019
                            • 12
                            • México
                            #773
                            Can someone help me?
                            Laptop EliteBook 840 G8.
                            I read your posts and the instructions on how to remove the password, and I did it... it's working. I was able to install Windows, etc. But now, every time it starts, the following error appears:
                            HP Endpoint Security Controller problem.
                            Attached are the BIOS and EC that I unlocked.
                            And maybe you can tell me a post to read and learn how to clean it
                            Thank you
                            • hoaca388
                              Badcaps
                              • Jan 2022
                              • 11768
                              #774
                              Thank you
                              • carloseddie83
                                • Nov 2019
                                • 12
                                • México
                                #775
                                Now it show manufacturing programin mode - 30
                                it seems that dmi is missing. but in the HEX it show the data.
                                can you help me? thanks
                                  • 20961
                                  You can use HP Bios Config Utility to lock MPM or enter any missing DMI.
                                  • carloseddie83
                                    • Nov 2019
                                    • 12
                                    • México
                                    #777
                                    Perfect, thank you, i enter all dmi data, use RCunlock. i look at some videos... and split de bios to fit the 16mb, and use partsurfer hp.
                                    Thank you
                                    • carloseddie83
                                      • Nov 2019
                                      • 12
                                      • México
                                      #778
                                      Thank you for the bios.
                                      • jatt93
                                        • May 2023
                                        • bucaramanga
                                        #779
                                        Hi! Can you please help me unlock SWAT and HP Endpoint Security Controller? Thank you.
                                        SN: 5CG1392PGH
                                        • hoaca388
                                          Badcaps
                                          • Jan 2022
                                          • 11768
                                          #780
                                          SN: 5CG1392PGH
                                          SWAT removed
                                          • Buzzfuzz2k
                                            Bios password removal on a Unowhy dump
                                            by Buzzfuzz2k
                                            Hi Everyone,
                                            I'm facing a problem with a locked bios with a password and i can't find how to remove it...
                                            The small computer is only booting on a M2 ssd Windows partition and i get a "signed partition error" if i try to boot on the same SSD with another Os (linux for example).
                                            the Computer is a Unowhy small pc
                                            N° UYM6524702229
                                            After failling trying to boot on other "none Windows" partition, i wanted to try to remove the bios password.
                                            My first attempt was to get the bios dump from windows...
                                            11-13-2023, 07:37 AM
                                          • traxformania
                                            TONGFANG "GM7TG7P" Bios Password Problem?
                                            by traxformania
                                            I'm using TONGFANG "GM7TG7P" model laptop for over 3 years and i'm entering the same bios administrator password everyday. My laptop has Aptio BIOS (American Megatrends, AMI).
                                            But today it's not accepting my password. I'm %100 sure i'm entering the correct password.
                                            I'm trying to reset my bios without success.
                                            I tried :
                                            -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
                                            11-15-2023, 07:32 AM
                                          • Nopslide
                                            HP Omen 15-dh0052nf power-on & bios password
                                            by Nopslide
                                            Hello everyone, I come here to tell you my problem regarding the power-on password. It is not a bios reset demand, and i can't have any access to windows. This is the bios and power-on password that is blocking all other things.
                                            My Omen 15-dh0052nf purchased second-hand was configured with the bios password upon purchase (very simple password :P ).
                                            Having decided to sell it in order to get something more powerful, I reset all BIOS settings and set a blank administrator password. But the power-on password cannot be changed to a blank one so I let the actual password set....
                                            04-01-2024, 04:27 PM
                                          • outsider
                                            Panasonic FZ-G1 MK5 - BIOS password returning
                                            by outsider
                                            Hello
                                            I removed the BIOS password thanks to the help of one of the friends of this forum.
                                            https://www.badcaps.net/forum/troubl...61#post3637661
                                            The batch from which the password was removed works correctly but... after some time, the BIOS password is set again, I reprogrammed the batch with the removed password, it's ok, there is no password, I set my password, ok, I can enter the BIOS with my password but...
                                            06-17-2025, 12:51 AM
                                          • Habble7
                                            by Habble7
                                            Suspected Cause:
                                            Troubleshooting Attempts:
                                            05-22-2025, 07:28 AM
