Lenovo V510-15IKB LV6 corrupted BIOS
  • hoaca388
    Badcaps
    • Jan 2022
    • 12441
    Re: Lenovo V510-15IKB LV6 corrupted BIOS
    Originally posted by danro
    Hi, thanks for answer.
    For sure is V510-15IKB. On the bottom case is a sticker with SN: LR08PWA9, ID:CS20, MO: LRNXB741000W.
    The spi flash was come with solder/desolder traces, so maybe not original content or have some modified blocks
    If need other info, please let me know
    Ok, this file has changed serial number.
    • danro
      • Aug 2011
      • 55
      • Serbia
      thanks, but no changes, image only on external (
      the same problem with different dumps, so maybe hardware problem...
      this mainboard have Kaby Lake-U (SR2ZU) CPU and no AMD GPU
      all voltage is present, except +VCCGT
      • peste
        • Dec 2016
        • 13924
        • ROMANIA
        [QUOTE=danro;1116271]thanks, but no changes, image only on external (
        if you have an image only on the outside, there is no problem with the bios ... check the display, LVDS cable, video chipset (probably detached balls between the motherboard and chipset, lack of chipset voltage) .... l
        • danro
          • Aug 2011
          • 55
          • Serbia
          [QUOTE=peste;1116274]
          already try with new LCD and cable, same result
          will reflow the CPU (that have integrated graphic)
            • 22293
            [QUOTE=danro;1116285]
            reflow it if you want to use the laptop as a door stop or big paperweight. Start a new thread in the main laptop forum if you want any more help, the bios is ok.
            • danro
              • Aug 2011
              • 55
              • Serbia
              #26
              [QUOTE=SMDFlea;1116286]
              ok, thank you!
              • GabyCR
                • Mar 2015
                • 31
                • España
                #27
                Re: Lenovo V310-15IKB please bios
                I have a Lenovo V510-15IKB.
                when I put the DC cord, directly the fan spins at max rpm without touch the power button. No leds, nothing. Only fan at max rpm.
                Possible Bios???
                I attach the dump of BIOS.
                Thank you
                  • 22293
                  Possible Bios???
                  Thank you
                  Unlikely to be a bios issue. Check DC-IN mosfets,EC chip and look for liquid damage.
                  • Badcapsnet forum
                    • Jul 2022
                    • 4
                    • Croatia
                    #29
                    I need bios dump for
                    LENOVO V510-15IKB
                    Model Name: 80WQ
                    MTM: 80WQ00WWSC
                    F ID: CS20
                    SN: LR08AXZ5
                    MO: LRNXB722400J
                    • Badcapsnet forum
                      • Jul 2022
                      • 4
                      • Croatia
                      #30
                      LENOVO V510-15IKB
                      Model Name: 80WQ
                      MTM: 80WQ00WWSC
                      F ID: CS20
                      SN: LR08AXZ5
                      MO: LRNXB722400J
                      REV : F DA0LV6MB6F0
                      I try all files from thos theme and do not work for me.
                      • hoaca388
                        Badcaps
                        • Jan 2022
                        • 12441
                        #31
                        Post your original corrupt bios file here.
                        • Badcapsnet forum
                          • Jul 2022
                          • 4
                          • Croatia
                          #32
                          I don't have it. I don't save it.
                          • hoaca388
                            Badcaps
                            • Jan 2022
                            • 12441
                            #33
                            V510-15IKB Laptop (Lenovo) - Type 80WQ ( not have DMI )
                            • Badcapsnet forum
                              • Jul 2022
                              • 4
                              • Croatia
                              #34
                              I try it, don't work.
                              • umtbdk25
                                • Apr 2017
                                • Türkiye
                                #35
                                Re: Da0lv6mb6f0 rev : F lenovo v510-15ikb
                                Originally posted by Claudiomfa
                                try and report
                                Thank you. %100 working
                                • didouche1200
                                  • Oct 2016
                                  • 374
                                  • 82679911441
                                  #36
                                  da0lv6mb6f0 need ram disable
                                  • imedia00
                                    • Jul 2013
                                    • 5
                                    • spain
                                    #37
                                    Hello, can someone provide a file for this equipment my notebook have intel graphics only
                                    V510-15IKB
                                    80WQ
                                    MTM80WQ0000SP
                                    Thanks in advance
                                    • Ahmed M Alareqy
                                      • May 2024
                                      • Yemen
                                      #38
                                      I want a redo bios file for Lenovo V510-15IKB Core I7 7th Gen 80WQ0191AX BIOS 2wcn46ww 2WEC19WW
                                      • hoaca388
                                        Badcaps
                                        • Jan 2022
                                        • 12441
                                        #39
                                        Backup bios file + serial number ?
                                        • Ahmed M Alareqy
                                          • May 2024
                                          • Yemen
                                          #40
                                          Serial number LR06Z5K9
                                          Backup bios my original bios 2WEC19WW my bois after update 2wcn46ww
                                          https://download.lenovo.com/consumer...s/2wcn46ww.exe
                                          • TylerHyde21
                                            Lenovo TD350 ThinkServer BIOS v505 Corrupted BIOS,
                                            by TylerHyde21
                                            Hello, the bios on my Lenovo TD350 ThinkServer got corrupted during a bios update, the bios restore function killed the Server.
                                            I need to flash the bios inside the MX25L12835F SOP8, i have already desolder the chip and solder it into my SOP8 adapter and read it with a ROM programmer.
                                            I use the innoextract 1.9 software to extract the bios file from the .exe file that i download from lenovo website, can you help me edit the Hex file (removing the Index part and resize the file)?
                                            This guy claim to have done it https://forums.lenovo.com/t5/ThinkSe...doesnt-Start-u...
                                            06-29-2024, 10:38 AM
                                          • lucaszmn
                                            by lucaszmn
                                            Problem:
                                            Initial Findings:
                                            • I concluded that the
                                            08-12-2025, 03:01 PM
                                          • Wahaz
                                            by Wahaz
                                            10-30-2023, 08:42 PM
                                          • grimacelord
                                            Lenovo Legion T5-26AMR5 Desktop - Corrupt BIOS
                                            by grimacelord
                                            Hello there.
                                            I am working on a Lenovo Legion T5-26AMR5 desktop that currently has a corrupt BIOS and I have been unsuccessful thus far in trying to fix it myself.
                                            History:
                                            1. This computer came to me initially with an error message that said "BiInitializeLibrary failed 0xc0000001" or "0135 fan error". It would always be one of the two errors. It should be noted that when it produced the fan error, there was no physical problem with the fans. They were all spinning just fine.
                                            I searched for this error online and discovered...
                                            03-15-2023, 03:29 PM
                                          • to5it0
                                            Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e 2H1703-27220F Rev. A Marked as U2501 on the motherboard.
                                            by to5it0
                                            Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
                                            I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
                                            This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
                                            I have opened the laptop and identified the main BIOS chip...
                                            10-24-2025, 01:35 AM
