Lenovo V510-15IKB LV6 corrupted BIOS
https://www.badcaps.net/donate -
Re: Lenovo V510-15IKB LV6 corrupted BIOS
thanks, but no changes, image only on external
the same problem with different dumps, so maybe hardware problem...
this mainboard have Kaby Lake-U (SR2ZU) CPU and no AMD GPU
all voltage is present, except +VCCGTComment
[QUOTE=danro;1116271]thanks, but no changes, image only on external
if you have an image only on the outside, there is no problem with the bios ... check the display, LVDS cable, video chipset (probably detached balls between the motherboard and chipset, lack of chipset voltage) .... lDue to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Every donation made will go towards server fees and maintenance costs.Comment
[QUOTE=peste;1116274]already try with new LCD and cable, same result
will reflow the CPU (that have integrated graphic)Comment
[QUOTE=danro;1116285]reflow it if you want to use the laptop as a door stop or big paperweight. Start a new thread in the main laptop forum if you want any more help, the bios is ok.Comment
Re: Lenovo V310-15IKB please bios
I have a Lenovo V510-15IKB.
when I put the DC cord, directly the fan spins at max rpm without touch the power button. No leds, nothing. Only fan at max rpm.
Possible Bios???
I attach the dump of BIOS.
Thank youAttached Filesif you find these attachements useful please consider making a small donation to the site
Unlikely to be a bios issue. Check DC-IN mosfets,EC chip and look for liquid damage.Comment
I need bios dump for
LENOVO V510-15IKB
Model Name: 80WQ
MTM: 80WQ00WWSC
F ID: CS20
SN: LR08AXZ5
MO: LRNXB722400JComment
Post your original corrupt bios file here.↵
https://www.badcaps.net/donateComment
V510-15IKB Laptop (Lenovo) - Type 80WQ ( not have DMI )Attached Filesif you find these attachements useful please consider making a small donation to the site
Hello, can someone provide a file for this equipment my notebook have intel graphics only
V510-15IKB
80WQ
MTM80WQ0000SP
Thanks in advanceAttached Filesif you find these attachements useful please consider making a small donation to the site
Serial number LR06Z5K9
Backup bios my original bios 2WEC19WW my bois after update 2wcn46ww
https://download.lenovo.com/consumer...s/2wcn46ww.exe1 PhotoComment
by TylerHyde21Hello, the bios on my Lenovo TD350 ThinkServer got corrupted during a bios update, the bios restore function killed the Server.
I need to flash the bios inside the MX25L12835F SOP8, i have already desolder the chip and solder it into my SOP8 adapter and read it with a ROM programmer.
I use the innoextract 1.9 software to extract the bios file from the .exe file that i download from lenovo website, can you help me edit the Hex file (removing the Index part and resize the file)?
This guy claim to have done it https://forums.lenovo.com/t5/ThinkSe...doesnt-Start-u...-
by lucaszmn
Summary of BIOS Whitelist Removal Problem
Problem:
Initial Findings:- My current BIOS version is N1KET58W (1.45).
- I have a CH341A programmer and have successfully created two full backups of my BIOS.
- I have the ability to use command-line tools on a Linux machine.
- I attempted to use several automated and manual patching methods on my N1KET58W (1.45) BIOS, including using hex strings. These attempts all failed.
- I concluded that the
Channel: BIOS Requests ONLY!
08-12-2025, 03:01 PM -
by WahazHello,
I found 3 bios chips on the board, which I read with a bios programmer: two XMC model bios chips and a Winbond model bios chip. Each XMC model bios chip has two partitions named XM25QH128A [3.3V] and XT25F128A [3.3V]. And the Winbond model bios chip has three partitions named W25Q80BL 3.3V, W25Q80xV 3.3V and W25Q80DV 3.3V....-
by grimacelordHello there.
History:
I searched for this error online and discovered...-
by to5it0Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
I have opened the laptop and identified the main BIOS chip...2 Photos-
- Loading...
