Lenovo 330S-15ikb model:81F5 330s_kbl_mb_v07 rev mp bios dump
  • ismaelstepheno
    • Jun 2020
    • 226
    • UE
    Hi PLEASE i need A WORKING bios dump lenovo ideapad 330S-15ikb model : 81F5
    mainboard : 330s_kbl_mb_v07 rev:mp
    THIS IS MY BACKUP NO IMAGE
  • Bonzas
    • 472
    • Indonesia
    Re: Lenovo 330s_kbl_mb_v07 rev mp bios dump
    Extracted From Lenovo
    • ismaelstepheno
      • Jun 2020
      • 226
      • UE
      Thank you very much for your help a have tried this one but still the same i think the problem is in ram onboard but i dont know how to disable it and use just external ram
      • melekh
        • Sep 2020
        • 3
        • madagascar
        did you manage to disable the onboard ram?.
        I need to disable my onboard ram also.
        • comaiel
          • Apr 2021
          • 9
          • Italia
          Hello, then someone answered you on how to disable the internal ram?
          Hi, the lenovo 330s notebook, if the ram soldered on the motherboard was good, should it start? Or do you still need secondary ram?
          Thank you
          • lapfix
            • Mar 2020
            • 2756
            • my workshop
            Yes it must start , if not than you have issue somwhere
            • vickey_vip
              • Mar 2016
              • 134
              • India
              Thanks Bro Working Fine for me
              • COREQCOMPUTER
                • Apr 2023
                • davao del sur
                Hi PLEASE i need A WORKING bios lenovo ideapad 330S-14ikb model : 81F4
                P/N: 431204230020
                please!
                • kalilinux25
                  • Mar 2018
                  • 2089
                  • ZAMBOANGA SIBUGAY
                  P/N: 431204230020
                  please!
                  Please try the post #2?
                • monreyes.rr@gmail.com
                  • Oct 2021
                  • 8
                  • Philippines
                  Hello everybody! Can I request for the EC bin file of this model? Unit's SIO is busted.
                  330s_kbl_mb_v07 rev: mp
                  ene9028q
                  TIA!
                • AHmad_Salal
                  Need BIOS Dump/ROM for Lenovo Thinkstation p500
                  by AHmad_Salal
                  Hello all,
                  I have a Lenovo Thinkstation P500 that is stuck at post with no display, it happened after I changed the memory timings in bios. I can not clear CMOS using the jumper on the motherboard, also tried re-flashing bios suing a USB stick but it also doesn't work. The only solution that I can think of right now is re-flashing the bios chip using an external programmer but the problem is that I don't have the bios dump of p500 for flashing externally and I don't know the location of bios chip. If someone can provide the bios dump and bios chip location it would be really helpful....
                  11-28-2023, 05:28 AM
                • Ahari
                  by Ahari
                  I...
                  08-13-2025, 06:12 AM
                • hyperwood
                  [REQUEST] 2MB BIOS Dump for Lenovo NM-E471 Rev 2.0 (Winbond 25Q16JWSIQ Chip)
                  by hyperwood
                  I’m looking for a 2 MB BIOS dump for a Lenovo IdeaPad 5 16ARH7H / Legion 5 with mainboard NM-E471 Rev. 2.0.
                  The BIOS chip is a Winbond W25Q16FW (1.8V, 2MB) and it's completely unresponsive / bricked. I tried recovery via USB but no success. Now I want to reflash it externally using a CH341A programmer.
                  I already found 32MB dumps (e.g. from Vinafix and Badcaps), but they are too large for the chip – and the last 2MB in those files are just FF FF FF....
                  āœ… What I need:
                  • A working 2MB BIOS dump
                  • Matching NM-E471 Rev. 2.0, e.g. JY575
                  06-25-2025, 02:28 PM
                • Habble7
                  by Habble7
                  Suspected Cause:
                  Troubleshooting Attempts:
                  05-22-2025, 07:28 AM
                • Joluvillas
                  Lenovo ThinkPad L15 Gen 1 i7 (20U4) Bios and EC dump needed
                  by Joluvillas
                  Hi all! I was reading on tutorials how to flash a bios to remove password from a bios, and I ended up reading the EC chip instead of the main bios chip, it only gave me a .bin file of 1,024kb, I learned later that that is the EC chip not the main bios chip (I should have read the tutorials here instead before attempting anything, my bad), I went to flash the original backup, the 1,024kb size file into the same chip and laptop is not powering up anymore. I may have screwed the chip or even the motherboard (Hopefully not), I am trying to see if there is a fix before I discard it. I had a couple...
                  06-18-2024, 10:35 PM
