Hp gpt52 la-k201p bios
I have extracted my bios (0881D), I don't know if it is corrupted, my pc does not start, the white led lights up for 3 seconds and goes back off.
How can I enter my serial number in the bios you published? For me it is the first time.
Thanks a lot,
Marco
SN CND11744W8
Model: HP 250 G8Attached FilesComment
read post #25..
Thanks a lot,
Marco
SN CND11744W8
Model: HP 250 G8Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Every donation made will go towards server fees and maintenance costs.Comment
use the HxD program (you can find it for free)...enter both bios in the program (of the laptop and the virgin one from the website),
select the interval from post #25, where the DMI interval is passed and (COPY-PASTE) from the bios- the laptop, in virgin bios...
and that's it..The DMI range is the range where the S/N, model, TYPE, etc. are found...isn't that what you asked for???Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Thank you very much,
Does the bios version have to be the same or can I use a more updated version?Comment
try..Attached FilesDue to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Thank you, but it didn't work.
The white LED on the PC lights up for 3 seconds and then turns off. The PC doesn't start.
I bought an identical motherboard, I mounted the new motherboard, the PC turned on and was on for several minutes. Suddenly while installing updates, black screen and fan at maximum.
I forced it to shut down after several minutes. The PC didn't turn on anymore, even the second motherboard, turns on the white LED for 3 seconds and then turns off, it doesn't start.
I thought and hoped that it was a bios problem, but I didn't solve it.
I saw that several users here on the forum had this problem, but I didn't find how they solved it.
Can you help me? What can I do?
Many thanksComment
if it's not a bios problem, move the discussion to the main forum..
Many thanks
https://www.badcaps.net/forum/troubl...mobile-devicesDue to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Ok, thanks for the help.if it's not a bios problem, move the discussion to the main forum..
I updated my thread (https://www.badcaps.net/forum/troubl...8-2x7l0ea-dead)
If anyone can help me, I am very grateful.
Thanks to allComment
post S/N, full name and model, motherboard model, product number,post the original contents of the bios chip..,,etc.
GPT52 LA-K201P
0881D
POWER on off
sn CND1416CZYAttached FilesComment
Use the Guides to find and extract a virgin bios
[Guide] How to find the right HP bios version to flash https://www.badcaps.net/forum/troubl...flash?t=122195
[Guide] How to extract ready for programming dump from HP update executable file https://www.badcaps.net/forum/showthread.php?t=121948
Copy the DMI (serial,feature Byte,win key) from your backup to the virgin bios using a hex editor.Select the same offsets (select block in HxD) in both bios,copy from the old,paste to the new.
Offsets: 500000 - 50103F
HxD Hex editor https://mh-nexus.de/en/hxd/Comment
my laptop model HP 15-dw3012nk has a BIOS password.
Motherboard: GPT52 LA-K201P Rev 1.0
Any solution please ?Attached FilesComment
the bios posted is not ok...read the chip again and post...
The bios chip must be unsoldered from the board before writing or reading..
do not use the clip, you may have errors..if you do not have anything to unsolder it with,
solder wires between the programmer and the bios chip..
here is a video for example..https://www.youtube.com/watch?v=DWWi...nnel=ThisIsHow
i unsoldered the chip and here is the dumpthe bios posted is not ok...read the chip again and post...
by macabookHello everyone,
Channel: BIOS Requests ONLY!
07-24-2025, 02:17 PM -
by piratiHello everyone,
by Waly411Necesito quitarle la contraseña a la bios
cnd1468024
gpt52 la-k201p Rev 3.0
I need to remove the bios password
cnd1468024
gpt52 to-k201p Rev 3.0
in English please.....-
by jbonavitaHi, my laptop wont boot at all
Some issues
Things I tried
1- Update / clear ME: Took the non working bios, made a backup, and did this: https://www.badcaps.net/forum/troubl...theory/trouble...-
- Loading...
