Bios Clear Password HP 15-dw3212nia gpt52 la-k201p rev 3.0
  • Waly411
    • Jul 2025
    • 7
    • San Marcos
    Necesito quitarle la contraseña a la bios
    cnd1468024
    gpt52 la-k201p Rev 3.0
    I need to remove the bios password
    cnd1468024
    gpt52 to-k201p Rev 3.0
    in English please..
  • Expired
    • Feb 2023
    • 34
    try and reply with results...
    • Waly411
      • Jul 2025
      • 7
      • San Marcos
      When I turn on the laptop, only LED 1 lights up, and it waits 5 seconds before turning off. Nothing happens, and the fans and screen don't turn on. I correctly read, erase, program, and verify the data.
      • miyagik
        • Jun 2018
        • 32
        • Mexico
        Try this one and report pls.
        • Waly411
          • Jul 2025
          • 7
          • San Marcos
          I tested it and the same problem persists. When I press the power button, the LED indicator light only comes on for 5 seconds and then turns off. Nothing else happens. I've already tried reverting to the original BIOS and the same problem.
          • minhdigital
            • Nov 2022
            • 765
            • Vietnam
            Send to you
            • Waly411
              • Jul 2025
              • 7
              • San Marcos
              The same problem persists, the chip is a UC2 (XMC QH128BAHIG) it also has an EC kb9052 chip, the laptop is clean with no hardware problems, I am just carefully using the SOIC clip, the program recognizes it well, I don't know what is happening, I need help.
              • peste
                • Dec 2016
                • 13641
                • ROMANIA
                write back the original contents of the bios chip and see what happens...
                • Waly411
                  • Jul 2025
                  • 7
                  • San Marcos
                  I already tried that, it was the first file I sent in the post, it's my original BIOS, I already tried putting the original BIOS on it and the problem still persists.
                  • peste
                    • Dec 2016
                    • 13641
                    • ROMANIA
                    The bios chip must be unsoldered from the board before writing or reading..
                    do not use the clip, you may have errors..if you do not have anything to unsolder it with,
                    solder wires between the programmer and the bios chip..
                    here is a video for example..https://www.youtube.com/watch?v=DWWi...nnel=ThisIsHow
                    you have everything you need at post #4...0881D...
                    https://www.badcaps.net/forum/troubl...os#post1799811
                    the bios from post #4 is virgin, use the HxD program (it's free on the internet), enter both bios into the program (your laptop and the virgin one),
                    select that interval mentioned in both bios, copy the interval in your bios and pass it to the virgin bios (copy - paste)....and that's it...
                    • zenius
                      by zenius
                      12-08-2024, 06:13 AM
                    • traxformania
                      TONGFANG "GM7TG7P" Bios Password Problem?
                      by traxformania
                      I tried :
                      -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
                      11-15-2023, 07:32 AM
                    • Nopslide
                      by Nopslide
                      04-01-2024, 04:27 PM
                    • outsider
                      Panasonic FZ-G1 MK5 - BIOS password returning
                      by outsider
                      Hello
                      I removed the BIOS password thanks to the help of one of the friends of this forum.
                      https://www.badcaps.net/forum/troubl...61#post3637661
                      The batch from which the password was removed works correctly but... after some time, the BIOS password is set again, I reprogrammed the batch with the removed password, it's ok, there is no password, I set my password, ok, I can enter the BIOS with my password but...
                      06-17-2025, 12:51 AM
                    • BlackVisor
                      How to Decode BIOS password for RedmiBook Pro15 2022 6800H
                      by BlackVisor
                      RedmiBook Pro 1542022 6800H
                      SKU: TM2113-39463
                      Model Number: RMA2204-AB
                      CMIIT ID: 2022AP1835
                      SN: 39463/22WD01355
                      BIOS version: RMARB5B0P1010 20230628
                      1. I bought this laptop from flea market, and the seller said that he had never set a password, however here is a password required when pressing F2 to enter BIOS.
                      2. And after entering incorrrect password 3 times, there is no any useful information like "recovery code"
                      3. I used universal bios backup tool, and dumped 8MB bin file, but hex code after "SystemSupervisorPw" is...
                      01-14-2024, 06:35 AM
