HP 250 G8 (2X7L0EA) dead
  • m.tech
    • Aug 2024
    • 25
    • Italy
    this is my first post on the forum, I hope I don't make any mistakes, I apologize in advance.
    I am writing to ask for help about a pc of mine, HP 250 G8 (2X7L0EA).
    The computer months ago, did not turn on. I tried several keystrokes, and it gave no signs, suddenly then it turned on and worked smoothly.
    Now again it won't turn on, I tried Win+V and Win+B keystroke comminution, it won't log on. No screen.
    I created a bios reset pendriver with hp software, but it won't boot.
    I opened the notebook case.
    When I press the boot key, the fan starts for about 3 seconds and a biacno led lights up, the display remains black. After these 3 seconds everything goes dead again.
    Can you please help me? Thank you all in advance.
    Marco
  • m.tech
    • Aug 2024
    • 25
    • Italy
    Could it be a bios problem?
    • m.tech
      • Aug 2024
      • 25
      • Italy
      The fan no longer turns on. Only a white LED for a few seconds and then everything turns off.
      I installed a new motherboard. The PC started, worked for a few minutes, and began to install some updates. Suddenly the monitor turned off and did not respond to any commands.
      After several minutes I turned off the PC from the power button. I tried to turn it on, it did not turn on anymore. Same problem as the first motherboard.
      The LED lights up for a few seconds and then turns off.
      Can someone help me please?
      Could it be a corrupted bios update on the hard disk?
      Help me please. Thanks
      PS sorry, I use the translator, if something is not clear, I can repeat.​
      • mon2
        • 14713
        To confirm, the bios update never did proceed since the laptop failed to boot? Correct? For now, we do not know if it is the bios so leave the bios alone for now.
        Often, the faults are in the power path from the power adapter to the logic board. Be sure your power supply is the original. No liquid spills?
        Would you have a multimeter for testing?
        The schematic for your logic board is available and is the last post here:
        https://www.badcaps.net/forum/troubl...board-scematic
        From this schematic, need to review the power path and also review the charger circuit sticky by piernov - see above.
        Remove all power. Meter in resistance mode.
        Measure the resistance across the DCin mosfets @ PQB11 and PQB12. Often, the faults are between these 2 parts.
        These mosfets have source pins 1-2-3 shorted; pin 4 = gate pin; 5-6-7-8 = drain pin cluster.
        Use the meter (with no power / no battery to the board) to check each mosfet.
        Test source
        (1-2-3) & drain (5-6-7-8) ; select one pin from each group
        source (1-2-3) & gate (4)
        gate (4) & drain (5-6-7-8)
        Post each measurement. Repeat for the 2nd dcin mosfet. Each measurement should be hundreds of k ohms or higher. If not, the part may be shorted and needs to be replaced.
        Would you have access to hot air tools + soldering tools + flux + tweezers? If not, after the diagnostics, will have to work with a local phone repair shop that is able to perform low level component repairs.
        • mon2
          • 14713
          To confirm, the bios update never did proceed since the laptop failed to boot? For now, we do not know if it is the bios so leave the bios alone for now.
          Test source
          Need hot air tools + soldering tools + flux + tweezers. If not available, after the diagnostics, will have to work with a local phone repair shop that is able to perform low level component repairs.​
          • mon2
            • 14713
            Post was censored. Spam bot will need to be corrected before you can view the post.
            Found a work around Eat this autistic spam bot.
            • m.tech
              • Aug 2024
              • 25
              • Italy
              Click image for larger version  Name:	reply.png Views:	0 Size:	71.6 KB ID:	3518044
              Hi, thanks for your reply.
              I use the original power supply, and I have a multimeter to test.
              can you tell me the full link?​
              • mon2
                • 14713
                Here is where you can download the full schematic & boardview file to hunt down the referenced mosfets:
                • m.tech
                  • Aug 2024
                  • 25
                  • Italy
                  I found the two mosfets
                  pins 1 2 3 of both are shorted
                  I don't see pins 6 7 8 from the diagram, can you help me?
                  Thanks​
                  • m.tech
                    • Aug 2024
                    • 25
                    • Italy
                    PQB11
                    1-5 = 1,37 M ohm
                    1-4 = 107 K ohm
                    4-5 = 6,50 M ohm
                    PGB12
                    1-5 = 13 M ohm
                    1-4 = 106 K ohm
                    4-5 = 12,75 M ohm
                    • mon2
                      • 14713
                      Your posted values make sense. Do not worry about pins 6-7-8 in the schematic since we know they are bonded (internally) inside the body of the mosfet to pin # 5. So if you can measure pin 5, you are good for the drain pin check.
                      From these values, to me, each is showing a short due to the low 1-4 resistance values.
                      Flux and remove PGB12 - take a pic for the orientation of the part. Then measure the mosfet again after it has cooled down. Still with this low resistance? If not, the mosfet is ok and can be placed back onto the board.
                      • m.tech
                        • Aug 2024
                        • 25
                        • Italy
                        I also measured the second motherboard. The one I installed today and it worked for 10 minutes until the PC installed updates.
                        The values are very similar.
                        If it is possible, for the moment I prefer to avoid unsoldering, I am not very expert for such small components
                        Can you help me anyway to check something else? Please
                        I don't understand why the second motherboard, which worked for 10 minutes, stopped working
                        The monitor had gone black (as if it was installing video drivers) and remained like that for several minutes. Then I forced it to turn off, and it did not turn on again​
                        • mon2
                          • 14713
                          It is possible that the screen went black due to device driver installations but you should be able to power it back up on the next cycle. Attempt to power and boot in SAFE MODE. In safe mode, the video and other device drivers will not be loaded so if there is a video driver that is not behaving, it will not load in safe mode. On this note, the video will look very coarse and not high resolution because the video resolution will be in basic mode.
                          If you have this second board, check the voltage to ground at the first mosfet - check the source pins (1-2-3). Any of these pins to red meter probe. Black meter probe to ground. Meter in DC volts (30v or higher) setting.
                          What is the voltage to ground? It should be the adapter voltage of ~19v. Then carefully, check pin # 4 which is the GATE voltage. The gate voltage defines whether this mosfet (electronic switch) is ON or OFF.
                          On N-channel mosfets, the gate voltage needs to be higher than the voltage being passed between source / drain pins. Often, the gate voltage should be ~25 volts to enable this mosfet. Same for the 2nd dcin mosfet in this power path. Test the gate voltage and also the drain voltage of each mosfet. In the end, the main power rail should be ~19v and then the logic board should power on.
                          • m.tech
                            • Aug 2024
                            • 25
                            • Italy
                            I can't boot into safe mode, the bios doesn't even start.
                            I'll tell you what happened.
                            Today I had a motherboard identical to mine, I connected everything and started the PC. Everything started regularly. After Windows started, it started installing some updates, suddenly the monitor went black, the fan was spinning high. I waited a long time, but the monitor was still black. I tried to click the keyboard but the caps lock didn't light up.
                            I forced it to shut down with the power button. I tried to turn it on and it didn't turn on anymore. The same defect as the first motherboard. A white LED light comes on for a few seconds, and then turns off. I remember that when the problem occurred, the first motherboard was doing updates.
                            My fear is that there is a corrupted bios update on the SSD, and somehow it also ruined the second motherboard.
                            The motherboard has an integrated CPU. Only the SSD, RAM, battery and monitor are connected.
                            Same for both mosfets
                            Voltage on pin 1 19.94v
                            Voltage on pin 4 25.81v
                            Voltage on pin 5 19.94v
                            • mon2
                              • 14713
                              Your bios may be corrupt. Request a good bios in the bios forum. However, you will need the proper tools to remove and reflash the flash chip on this board using another working PC.
                              • m.tech
                                • Aug 2024
                                • 25
                                • Italy
                                Is this kit okay? Thanks
                                • m.tech
                                  • Aug 2024
                                  • 25
                                  • Italy
                                  I flashed the bios, but the pc did not turn on.
                                  The white led stays on for 3 seconds and then turns off.
                                  Can you help me? Thanks​
                                  • m.tech
                                    • Aug 2024
                                    • 25
                                    • Italy
                                    I'll recap the story.
                                    When I press the power button, a white LED lights up for a few seconds (about 3 / 5), the monitor remains off, nothing happens. The LED turns off and there is no sign of life.
                                    I bought a new motherboard (GPT52 LA-K201P), I installed the SSD, the RAM and the various connectors (the processor is integrated), and the PC started up correctly, it worked for several minutes, suddenly, the screen went black, the fan was spinning at full speed. I waited, but nothing happened, I forced the PC to shut down.
                                    I tried to turn on the PC, and it no longer turns on. Same problem as the first motherboard. The LED lights up for a few seconds and then turns off, no sign of life.
                                    Considering that the PC was performing updates, I thought it was the bios. I flashed the bios using the CH341A kit but the problem was not solved.
                                    Now I have two motherboards that have the same problem, and I don't know what to do, I ask you for help.
                                    On the first motherboard, I found that the +3.3VS are shorted to the GND with a resistance of 27.8 ohms. On the second motherboard, there is no such short circuit.
                                    I thank in advance all those who will help me.​
                                    • zklgfs
                                      Anker SoundCore 2 Bluetooth Speaker Turns Off After a Few Seconds (Possibly Firmware Issue?)
                                      by zklgfs
                                      I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...
                                      08-11-2025, 02:14 PM
                                    • twonk9098
                                      Lenovo Legion 5 high fan spin turns off after 34 seconds
                                      by twonk9098
                                      I have a Lenovo Legion 5 with a Ryzen 7 series CPU and RTX 3070 GPU. My issue is that it turns on and all seems fine except after a few seconds the fans spin up high and the laptop turns off after 34 seconds.
                                      I can get into bios and can even boot and login to Windows however after 34 seconds no matter if Im at the bios screen or booted into Windows it will just turn off.
                                      I have managed to run HWmonitor and the temperatures of the CPU and GPU are fine, I can also touch the heatsync which is warm but not hot.
                                      I have tried a few new bios but exactly...
                                      07-14-2024, 11:19 AM
                                    • double_DD
                                      How can I be sure that my EC chip is dead?
                                      by double_DD
                                      As the title suggests, how can I be sure that my EC chip is really dead?
                                      I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
                                      Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
                                      03-12-2025, 07:47 AM
                                    • liquidzorch
                                      Lenovo 15iml05 Power led lights for 12 seconds then off 12 seconds
                                      by liquidzorch
                                      Hello. I bought a faulty Lenovo ideapad 3, but it turns out the 3Valw buck converter burnt a hole through the board. I was able to clean it up, and remove all the shorts. I now can power the 3.3v rails from a bench power suppy while connecting the laptop to its psu, and I get the additional 5valw, 1.8v, and 1.05v, form what I can tell in the schematics, those are the only 4 voltages I should see before turning on, and they are present. When I hit the power button, the power indicator on the left side turns on (not the one on the power button), stays on for about 12 seconds, then turns off for...
                                      10-18-2024, 05:19 PM
                                    • zunasthegreat
                                      Chieftec GPS-450-AA with dead 20N60C3
                                      by zunasthegreat
                                      Hello everyone hope all doing well!
                                      I have this PSU (GPS450-AA delta oem) around for like 4-5 years and I had it recapped early 2020 or 2021 with mostly UCC KY and Nichicon PW's. The bulk was and still is fine, the original Ltec's were bloated and empty. The previous issue was some major coil whine noise and at times random shutdowns when going idle. Today it started tripping the mains breaker and I think I have dead APFC mosfets (20N60C3). Right now upon checking I have the Q1 and Q3 FETs dead so far and I guess those are responsible for the PFC circuit. The only thing I care is If there...
                                      09-01-2024, 07:12 PM
