Hp gpt52 la-k201p bios
  • killersoft
    • Apr 2017
    • 75
    • algeria
    #61
    Originally posted by SMDFlea
    What is the laptop serial number ? https://www.badcaps.net/forum/troubl...before-posting
    serial number is CND1082H6B
    • peste
      • 13641
      • ROMANIA
      #62
      you have everything you need at post #4...0881D
      https://www.badcaps.net/forum/troubl...os#post1799811
      • GB1999
        • Mar 2023
        • 73
        • Malaysia
        #63
        Hi , please edit the bios below provided.
        internal no diSplay, external have display
        BOARD:LA-K201P REV 1
        SN : CND14357TD
        Thanks in advance
          • 21948
          SN : CND14357TD
          Thanks in advance
          99 times out of 100 it isn`t a problem with the bios when you have an external display (some lenovos behave this way until the bios is downgraded). Check hardware ,screen, cable, connector, resistors, fuse etc.
          • GB1999
            • Mar 2023
            • 73
            • Malaysia
            #65
            Hi there this is not lenovo. Its HP
              SMDFlea commented
              Editing a comment
              I know that...
          • GB1999
            • Mar 2023
            • 73
            • Malaysia
            #66
            Hi already check the resistor value, and already tried changing the lcd still no display. Can i get a new bios file.
            • lapfix
              • Mar 2020
              • 2765
              • my workshop
              #67
              As smdflea said : It's not a bios issue
              you can try the one posted at post #24 ..a virgin bios withe same BID
              • reeza_plus
                • Aug 2015
                • 58
                • canada
                #68
                Hp 15s-du3517TU
                SN: CND1504FXN
                GPT52 LA-K201P rev:1.0
                No Display
                • m1ch43lzm
                  • Mar 2019
                  • 954
                  • Peru
                  #69
                  Try this one, ver F.59 with serial/win key inserted
                  HP Laptop 15s-du3517TU (637X2PA)
                  BID 881D
                  S/N CND1504FXN
                  DMI+Win key 500000-50103Fh
                  • atanutikadar
                    • Oct 2018
                    • india
                    #70
                    ANY ONE HAVE LA-K205P EC BIOS.THANKS
                      • 21948
                      Type the laptop serial number, full name and model, motherboard model, etc.
                      post the contents of the bios/EC chip even if it is corrupted..
                      read the forum rules..https://www.badcaps.net/forum/troubl...before-posting
                      • microhard
                        • Jan 2022
                        • turkey
                        #72
                        hello masters
                        i have an hp 250 g8 i5-1135G7
                        MB GPT52 LA-K201P REV 1.0 UMA Version
                        18-09-2020
                        SN:CND31937XV
                        PRODID: 853U8ES#AB8
                        first control its working with no display and overheating on cpu missing DDR volt it was 0.22v on power supply 1.700 mA
                        after i trying so many bios files it just blink the white light no cpu volt no ddr volt on power supply 52 mA
                        GND to Cpu Coil 65 Ohm
                        GND to ddr Coil 477 Ohm
                        please do you have any suggestion or solution
                        old bios bin: in Attachment
                        • lleonardolima2
                          • Aug 2021
                          • brasil
                          #73
                          I need the bios la-k203p
                            • 21948
                            https://www.badcaps.net/forum/troubl...14#post3713614
                            • macabook
                              by macabook
                              đź§© Initial Issue
                              07-24-2025, 02:17 PM
                            • pirati
                              by pirati
                              10-27-2025, 04:20 PM
                              by Vesko356
                              08-11-2023, 03:27 AM
                            • Waly411
                              Bios Clear Password HP 15-dw3212nia gpt52 la-k201p rev 3.0
                              by Waly411
                              Necesito quitarle la contraseña a la bios
                              cnd1468024
                              gpt52 la-k201p Rev 3.0
                              I need to remove the bios password
                              cnd1468024
                              gpt52 to-k201p Rev 3.0
                              in English please.....
                              07-14-2025, 09:11 AM
                            • jbonavita
                              by jbonavita
                              Some issues
                              Things I tried
                              04-29-2025, 09:38 PM
