HP Stream 14-ds0006nc, DA0P9EMB6D0 rev.D
  • hopkok
    • Oct 2014
    • 178
    • Slovakia
    Hi friends, I accidentally lost BIOS chip from DA0P9EMB6D0 rev.D motherboard. Unit is HP Stream 14-ds0006nc, so I would like to get a working dump and type of BIOS chip I need to use.
    From photos I found on internet should be Winbond.
    Thanks for any help.
  • lapfix
    • Mar 2020
    • 2742
    • my workshop
    Re: HP Stream 14-ds0006nc, DA0P9EMB6D0 rev.D
    what's your serial , you will find it at the back of your lap
    • hopkok
      • Oct 2014
      • 178
      • Slovakia
      5cd0012tox
      • hopkok
        • Oct 2014
        • 178
        • Slovakia
        Nobody can help?
        • ebarduil
          • Feb 2016
          • 29
          • Argentina
          Originally posted by hopkok
          Nobody can help?
          Check please and inform.
          • hopkok
            • Oct 2014
            • 178
            • Slovakia
            Laptop turn on, but black screen...maybe problem is BIOS chip, I lost original one, so used 1,8V Winbond, can this be problem too?
            • peste
              • Dec 2016
              • 12945
              • ROMANIA
              did you write something on the bios chip ??? what programmer do you use ??? what does it write on the bios chip ??
              • Rebirth
                • Sep 2022
                • 50
                • Myanmar
                Try this bios. already tested 100% working
                • kyaw5712
                  • Nov 2021
                  • myanmar
                  ok bios
                  • corona100
                    • Mar 2020
                    • 145
                    • U.S.A
                    work perfect but protected by a password ( A D04C4365 )
                    • Noreddin
                      • Jan 2020
                      • 73
                      • mostaganem
                      THANKS IS WORKING
                        by SMDFlea
                        Bad...
                        09-02-2021, 04:40 PM
                      • CapThatBrass
                        RT809F Chip Write Failure - Winbond 25R256JV
                        by CapThatBrass
                        I've managed to take an image dump in BIN format of my Dell Latitude 5420, which had a Winbond 25R256JV chip installed.
                        I used an RT809F programmer to obtain the BIN, using the supplied iFix RT809F programmer application (latest version being 20220830).
                        The programmer automatically found the settings to read the chip but selected the Winbond W25Q256FV instead (my actual model isn't available on the listing within the software). The image came out fine - I did this multiple times to clarify the data being read was the same each time.
                        10-04-2022, 11:56 AM
                      • TamFishe
                        ThinkPad X1C6 winbond 25q80dvsig chip dump request
                        by TamFishe
                        Hi, I got a ThinkPad x1 carbon 6th gen from a friend after in an attempt to fix it he ended up bricking the motherboard. today i tried plugging the laptop to the wall and i got no signs of life, despite the connections being proper. i've found out this winbond 25q80dvsig chip under a label near the usb c ports and i gave it a read, and the output has massive chunks of 0000 0000 0000 0000 followed by FFFF FFFF FFFF FFFF and sometimes some proper values scattered across the whole chip. I've attached the file because I've read people request it in order to fix it. Moderators, if I've posted this...
                        08-22-2025, 02:20 AM
                      • hyperwood
                        [REQUEST] 2MB BIOS Dump for Lenovo NM-E471 Rev 2.0 (Winbond 25Q16JWSIQ Chip)
                        by hyperwood
                        I’m looking for a 2 MB BIOS dump for a Lenovo IdeaPad 5 16ARH7H / Legion 5 with mainboard NM-E471 Rev. 2.0.
                        The BIOS chip is a Winbond W25Q16FW (1.8V, 2MB) and it's completely unresponsive / bricked. I tried recovery via USB but no success. Now I want to reflash it externally using a CH341A programmer.
                        I already found 32MB dumps (e.g. from Vinafix and Badcaps), but they are too large for the chip – and the last 2MB in those files are just FF FF FF....
                        āœ… What I need:
                        • A working 2MB BIOS dump
                        • Matching NM-E471 Rev. 2.0, e.g. JY575
                        06-25-2025, 02:28 PM
                        HP Stream Stream 14 Pro Notebook PC Notebook 14 Specification for Upgrade or Repair
                        This specification for the HP Stream Stream 14 Pro Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Stream 14 Pro Notebook PC boardview and Stream 14 Pro Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
                        09-06-2024, 06:40 AM
