RT809F Chip Write Failure - Winbond 25R256JV
  • CapThatBrass
    • Oct 2021
    • 46
    I've managed to take an image dump in BIN format of my Dell Latitude 5420, which had a Winbond 25R256JV chip installed.
    I used an RT809F programmer to obtain the BIN, using the supplied iFix RT809F programmer application (latest version being 20220830).
    The programmer automatically found the settings to read the chip but selected the Winbond W25Q256FV instead (my actual model isn't available on the listing within the software). The image came out fine - I did this multiple times to clarify the data being read was the same each time.
    The problem is that I'm not able to write the image back. The write process starts, it then states 'write successful' but then upon chip verification it states 'chip verification error, start position 0x1046E', 'Verification Failure', 'Write error, operation terminated'.
    I've been told that the W25Q256FVsettings can be used as a substitute for my actual chip model (I've noticed the W25Q256FV has a slow clockspeed compare to my actual 25R256JV chip).
    Has anyone come across something similar?
    Any help would be great.
    Cheers
    • 22236
    Re: RT809F Chip Write Failure - Winbond 25R256JV
    Choose XM25QH256B@WSON8 6X5 ,don`t use auto detect
    • CapThatBrass
      • Oct 2021
      • 46
      Thanks for the info SMDFlea.
      I selected the XM25QH256B WSON8 6x5 setting, still getting the error though with the same logs being made - basically failing upon chip verification.
        • 22236
        disable verify as well,see what happens.
        • CapThatBrass
          • Oct 2021
          • 46
          Thanks SMDFlea. This might sound a bit dumb, but where would the option to disable verification be? I've tried unticking the 'Auto verification af' and 'Auto verification after' within the 'software config' menu with RT809F Serial ISP Programmer software but this makes no difference (it still auto verifies at the very end).
          Out of curiousity, I downloaded a BIN from another thread on the forum related to unlocking of a latitude 5420. After flashing with this BIN, the laptop booted but goes into a continuous cycle of a fast fan spin, LED flashes 3amber 6white, the screen turns on (no Dell logo though) and then it reboots and does the same thing. Randomly it will show multiple coloured screens, as though its testing the RGB screen capability but no functioning laptop.
          Any pointers would be great please. Thanks
            • 22236
            I don`t have an RT809F so i can`t help you any further with the settings.
              • 22236
              If the bios you tried didn`t have clean ME firmware then that could be why, or the bios chip could be duff,that could explain the verification .
              • CapThatBrass
                • Oct 2021
                • 46
                I've been using a Pogo burn probe to flash the chip - could this be the issue? Thanks
                The RTC/CMOS battery has been disconnected as well as the battery whilst performing flashes.
                • ahmedtou
                  HOW CAN I UPDATE HL-DT-ST BD-RE GGW-H20N XA02
                  by ahmedtou
                  help me please
                  I have an HL-DT-ST BD-RE GGW-H20N with ROM version: XA02.
                  When I tried to burn a 25GB Blu-ray disc using ImgBurn, I got an error.
                  I will share all the details with you, including the disc information.
                  Code:
                  HL-DT-ST BD-RE  GGW-H20N XA02 (ATA)
                  Current Profile: BD-R
                  Disc Information:
                  Status: Empty
                  State of Last Session: Empty
                  Erasable: No
                  Free Sectors: 12,219,392
                  Free Space: 25,025,314,816 bytes
                  Free Time: 2715:27:17 (MM:SS:FF)
                  Next
                  08-27-2025, 08:49 AM
                • npielawski
                  MacBook Pro late 2016 (820-00239) with multiple failure modes.
                  by npielawski
                  I will just preface all this by saying that I have a fairly technical background but have never attempted SMD electronics diagnostics and repair before, I really like the idea and want to learn.
                  I have a MacBook Pro late 2016 that died maybe four years ago. Over the course of 30 seconds, it got slower and stuttered, until it froze for a second and died. No click from the trackpad anymore, nothing. I started getting interested in electronics repair and decided to give it a shot, so I opened it, removed the battery (one cell was puffy), took out the motherboard and experimented with...
                  10-15-2025, 01:53 AM
                • ktmmotocross
                  how to read/write XMC25RU256CIX0 with RT809F
                  by ktmmotocross
                  have new A15 tuf that have this bios ic XMC25RU256CIX0 but my RT809F cannot find it in database. i have newest version of software 20240116. found nothing to be help on ifix forum
                  how to manually add it?
                  10-12-2024, 01:11 AM
                • araxnido
                  Programming KBC IT8987VG ASUS TUF FX506L RT809F+PEB
                  by araxnido
                  Dear friends, I want to share my experience repairing an ASUS TUF FX506L gaming laptop motherboard: DABKXDMB8E0_F_BKXD. Boardview and schematic are available, as well as the BIOS and ITE ROM.
                  When the customer brought in this laptop, it was initially dead; it showed no signs of booting for any reason. After hours of measurements, checking each stage, MOSFET, and seeing if there was a short circuit in any capacitor, I discovered a strange 0.7V leakage voltage on the 3V_S5 rail, particularly on the PL9 coil, with the board not powered on. There were 3V_LDO and 5V_LDO voltages, which...
                  06-10-2025, 09:26 PM
                • cr4zychriss
                  by cr4zychriss
                  • Rebrand: PC Specialist
                  11-14-2025, 04:04 PM
