lenovo v130-20igm bios
  • coumcoum
    • Dec 2015
    • 36
    • algerie
    hello
    pleas need dump with original dmi added i attach my old corrupted dump thanksss
  • peste
    • Dec 2016
    • 12822
    • ROMANIA
    Re: lenovo v130-20igm bios
    Originally posted by coumcoum
    hello
    look for another bios chip (8MB) on the board, and post the contents
    • coumcoum
      • Dec 2015
      • 36
      • algerie
      sorry here is org dump thankss
      • coumcoum
        • Dec 2015
        • 36
        • algerie
        thanks
        • peste
          • Dec 2016
          • 12822
          • ROMANIA
          thanks
          bios extracted from the Lenovo site update ..;
          • coumcoum
            • Dec 2015
            • 36
            • algerie
            thnaks work but same problem dmi missing invalid error 00ce can u inject dmi from my old dump bios pleas
            • peste
              • Dec 2016
              • 12822
              • ROMANIA
              try..
              • lapfix
                • Mar 2020
                • 2724
                • my workshop
                @peste what's tha number lines of dmi for this model thank you
                • coumcoum
                  • Dec 2015
                  • 36
                  • algerie
                  try..
                  same problem
                    • 20926
                    same problem
                    Post your current bios backup,not the previous one,the backup now since its been booted from the virgin bios.
                    • coumcoum
                      • Dec 2015
                      • 36
                      • algerie
                      ok
                      backup attached
                      info : machine type 10rx
                      model 000sum
                      sn yj00kxkd
                      mfg 1810
                      product id 10rx000sum
                      thank u
                        • 20926
                        You`ll have to use wflash2.exe to update the bios and add the DMI. Heres the instructions from the bios update readme
                        Bios update - https://download.lenovo.com/consumer...m1pjy27usa.exe
                        Bios README https://download.lenovo.com/consumer...m1pjy27usa.txt
                        3. Flash Program Options *
                        * To deploy this application, please open the Windows Command Prompt *
                        * with Administrator privilege. Then run "xxxJYnnUSA.EXE -s -e" *
                        * to unpack the installation files into the default path: *
                        * "C:\SWTOOLS\FLASH\xxxJYnnUSA". After that, run "flash.cmd /quiet" *
                        * to start the update process. If you like to customize the update *
                        * options, please edit the wflash2.exe command line in the flash.cmd *
                        * file to make changes to the flash program options. *
                        * Note that "flash64.cmd" and wflash2x64.exe are provided to be used *
                        * in an environment without WOW64 support such as Windows *
                        * Preinstallation Environment (Windows PE) 64bit. *
                        * Command options: *
                        * wflash2.exe [option1] [option2] ... [optionX] *
                        * [OPTIONS] *
                        * /h Show help messages. *
                        * /rsmb Preserve all SMBIOS structures. *
                        * /clr Clear BIOS settings. *
                        * /ign Ignore BIOS version check. *
                        * /sccm Support SCCM deployment *
                        * - see "Delaying Reboot in BIOS Update" below. *
                        * /sn:nnnnnnn Update system serial number (up to 20 characters). *
                        * /csn:nnnnnnn Update chassis serial number (up to 20 characters). *
                        * /mtm:nnnnnnn Update machine type and model number (up to 25 *
                        * characters). *
                        * /tag:nnnnnnn Update system asset tag (up to 25 characters). *
                        * /uuid The flash utility will generate an Universally *
                        * Unique Identifier (UUID), replacing the one that *
                        * is currently in the system.
                        • coumcoum
                          • Dec 2015
                          • 36
                          • algerie
                          thank uuu work perfectlyy
                          • alfredosn
                            • Jun 2016
                            • 19
                            • México
                            Hello friend, i have a Lenovo V130-20IGM, I recovered the bios with the dump from this post (Thanks), but I have an error and I don't know how to fix it, colud you help me please? "Error 0167: No Processor microcode update found"
                            • AHmad_Salal
                              Need BIOS Dump/ROM for Lenovo Thinkstation p500
                              by AHmad_Salal
                              Hello all,
                              I have a Lenovo Thinkstation P500 that is stuck at post with no display, it happened after I changed the memory timings in bios. I can not clear CMOS using the jumper on the motherboard, also tried re-flashing bios suing a USB stick but it also doesn't work. The only solution that I can think of right now is re-flashing the bios chip using an external programmer but the problem is that I don't have the bios dump of p500 for flashing externally and I don't know the location of bios chip. If someone can provide the bios dump and bios chip location it would be really helpful....
                              11-28-2023, 05:28 AM
                            • hyperwood
                              [REQUEST] 2MB BIOS Dump for Lenovo NM-E471 Rev 2.0 (Winbond 25Q16JWSIQ Chip)
                              by hyperwood
                              I’m looking for a 2 MB BIOS dump for a Lenovo IdeaPad 5 16ARH7H / Legion 5 with mainboard NM-E471 Rev. 2.0.
                              The BIOS chip is a Winbond W25Q16FW (1.8V, 2MB) and it's completely unresponsive / bricked. I tried recovery via USB but no success. Now I want to reflash it externally using a CH341A programmer.
                              I already found 32MB dumps (e.g. from Vinafix and Badcaps), but they are too large for the chip – and the last 2MB in those files are just FF FF FF....
                              ✅ What I need:
                              • A working 2MB BIOS dump
                              • Matching NM-E471 Rev. 2.0, e.g. JY575
                              06-25-2025, 02:28 PM
                            • Habble7
                              by Habble7
                              Suspected Cause:
                              Troubleshooting Attempts:
                              05-22-2025, 07:28 AM
                            • Joluvillas
                              Lenovo ThinkPad L15 Gen 1 i7 (20U4) Bios and EC dump needed
                              by Joluvillas
                              Hi all! I was reading on tutorials how to flash a bios to remove password from a bios, and I ended up reading the EC chip instead of the main bios chip, it only gave me a .bin file of 1,024kb, I learned later that that is the EC chip not the main bios chip (I should have read the tutorials here instead before attempting anything, my bad), I went to flash the original backup, the 1,024kb size file into the same chip and laptop is not powering up anymore. I may have screwed the chip or even the motherboard (Hopefully not), I am trying to see if there is a fix before I discard it. I had a couple...
                              06-18-2024, 10:35 PM
                            • Captaincrap420
                              Lenovo Tiny8 triple NVMe IQ6X0IL1 HQ670 NM-D581 Rev 0.5 M90q Gen 3 / P360 Tiny prototype board BIOS dump
                              by Captaincrap420
                              Hi, I hope this is the right place to post this. This is my first post on this forum.
                              A friend helped me get a prototype Lenovo motherboard from China, it's got a hole drilled in it but I'm working on trying to revive it to some degree. I dumped the bios in hopes that it might be useful to someone, since this board is configured with the 3rd NVMe SSD slot and maybe it is useful as a reference for modding another bios to support this function. For example the M90q Gen 2 / P350's unpopulated 3rd NVMe slot footprint maybe.
                              This bios dump is straight from the chip, nothing has been...
                              11-29-2024, 05:40 PM
